GregW 28 Posted May 20, 2016 Share Posted May 20, 2016 I'm thinking of changing to a furling jib. I've had a look at whats available and there seem a few options. I'd be interested to hear from owners of smaller multihulls who have used a jib furler, what brands tried, experiences good bad etc. things to watch out for. My tri is 25' long jib size is around 11 sq meters. If you recommend a particular model I'd be interested to know why. Also, if anyone has a used unit lying around surplus to requirements that is suitable I'd be interested in buying it. Link to post Share on other sites
Tim C 23 Posted May 21, 2016 Share Posted May 21, 2016 It's a small boat with a small jib. I'd suggest running a light retrieve line up the jib to positively pull it down and retain on deck, before going to the expense and complexity of a fuller. Also, fully battened jibs don't flog when things are going pear shaped... Link to post Share on other sites
Freedom GBE 27 Posted May 22, 2016 Share Posted May 22, 2016 Great idea Tim. A small retrieval line on the luff of the jib is much safer. Furling our screecher has gone pear shaped more often than not. But then we tend to furl it up way too late and try and furl it in too much breeze. You would go really well with a small prod and a light weight overlapping code 0. In five knots of breeze you would probably do 10 knots. Link to post Share on other sites
Ed 153 Posted May 22, 2016 Share Posted May 22, 2016 maybe look at the small (inshore?) furler from KZ Furlers. No personal experience, but NZ made and seems to be Farriers furler of choice for the jib on the F22 Link to post Share on other sites
Black Panther 1,818 Posted May 22, 2016 Share Posted May 22, 2016 Who is the guy in the BoI who makes them? Link to post Share on other sites
Clipper 382 Posted May 22, 2016 Share Posted May 22, 2016 http://beaumarine.co.nz Link to post Share on other sites
Tim C 23 Posted May 22, 2016 Share Posted May 22, 2016 Great idea Tim. A small retrieval line on the luff of the jib is much safer. Furling our screecher has gone pear shaped more often than not. But then we tend to furl it up way too late and try and furl it in too much breeze. You would go really well with a small prod and a light weight overlapping code 0. In five knots of breeze you would probably do 10 knots. Being ready to furl and then dumping the screecher sheet completely sometime works for a better furl, rather than easing the sheet. But bearing away works best, which is often not possible. Not sure if you are referring to my boat regards screecher or not? Yes I have one and use one, just I neatly tidy away the pole when not in use in the cat walk. And yes it is on one of my furlers. I find we can take it to 6 knots of boat speed upwind in the very light. After that the tacking angle is so wide it's not worth having up. The trick is not to get greedy, and get rid of it early. But that is always a trick decision. Link to post Share on other sites
Banzai 0 Posted May 22, 2016 Share Posted May 22, 2016 Incidentally Greg: great shot of Mysterex cheers Banzai Link to post Share on other sites
erice 732 Posted May 23, 2016 Share Posted May 23, 2016 ^ Graeme Delaveau took that pic Greg took this 1 back Link to post Share on other sites
madyottie 82 Posted May 23, 2016 Share Posted May 23, 2016 Hey Greg, are both of those boats the 7.6? They are great looking boats! And why didn't these pics make it into the "old multi pics" thread? I know they're not old, but certainly good shots! Link to post Share on other sites
GregW 28 Posted May 23, 2016 Author Share Posted May 23, 2016 Thanks Bryan, and madyottie, we like 'em. The pics are quite recent. They are both 7.6's although there are some differences between the two. The white one has only recently been relaunched by Graeme D after around 10 years sitting in a paddock. I think it was built in the '90s?? Graeme? The reason I want a furler on the jib is purely for convenience sake. Yep, its an expense but I expect to have the boat long enough to get my moneys worth. Link to post Share on other sites
paxfish 5 Posted May 23, 2016 Share Posted May 23, 2016 Greg - I bought one of these a couple of months ago, but have yet to use it on my boat. Hoeever, I did try out an identical unit on my buddy's F28R code zero and it was smooth as silk. it is a big upgrade from his Harken unit. Link to post Share on other sites
