GBE fore beam replacement
15 replies to this topic
#11 ScottiE
ScottiE
  • 3,925 posts
  • LocationAuckland
Posted 07 February 2018 - 09:41 AM
yup - they all do it - except perhaps Hooters with her sockets but I've never sailed on her.
Anthony
#12 Clipper
Clipper
  • 3,598 posts
  • LocationAuckland
Posted 07 February 2018 - 09:51 AM
I was replacing mind proactively ( hadnt seen cracks but had broken back beam) and as i undid the last bolt it buckled in front of my eyes due to seagull striker tension. It was well f&cked and the last sail i had we had been giving it death, nearly hull flying with masthead kite. After that i kept a very close eye in things...
#13 erice
erice
  • 3,520 posts
Posted 10 February 2018 - 07:55 AM
i'd agree it's the lack of sleeving that did it
on multis all those wracking loads are at the corners
and the strength there needs to be at least double the mid-beam
so with alloy beams you can either use a simple section, that's far too strong-heavy in the middle
or find a way to get double or triple the strength at the ends
any bicycle with pretensions of light weight - high performance uses butted tubing for exactly that reason
carbon ones would tend to have 4 - 5x the carbon at the corners than at the middle
when capricorn was out we found that after 10? years of thrashing there some minor cracking around the rear beam to float join
nothing on the front, presumably as the front beam is twice as thick so spreads the loads better
ground off the bog
and laid down lots of carbon in all directions, over a much bigger area
but yeah, alloy beams that aren't telegraph poles in the middle
are going to need to be about twice as strong at the ends somehow
sleeving being the obvious solution
sure you're getting far better advice from others but you could buy the same beam extrusion and sleeve it with 1mtr? bits of the broken beam that had a correctly sized 1mtr section cut from them
the problem would be compressing them down
or you could cut these 1mtr sections of the old beam in half to use as half molds, wax the inside, and glass in a few mm of boat cloth 1 mtr long, half-cure with the tubes strapped shut and some blown up wine bags against dry? cloth? forcing the wet cloth to shape, then deflate and remove bags to lay 900mm carbon strips inside that, half-cure again with the bags, lay more 700mm carbon, half-cure 600mm etc
try and bake your final mold  on a the dash of a closed up car on a hot sunny day, (reaches about about 50C), all day
crack them open the next day to remove your glass insulated carbon sleeves, ready for sanding rough, latering in an epoxy, adhesive mix and slipping into new beam ends
not going to be quick or pretty but the end result won't be seen and can be as strong as you want it
start begging carbon scraps
if posts offend .. or even too hard
please "ignore" :thumbup:
http://crew.org.nz/f...ea=ignoredusers
#14 Clipper
Clipper
  • 3,598 posts
  • LocationAuckland
Posted 10 February 2018 - 08:02 AM
Not sure where you found cracks, and apologies if stating the obvious, but you need to ensure the stainless straps do not touch the ali at all or the corrode out real fast. I sleeved my front beam when i did it, prick of a job to get them in there. So when i did my main beam, i got john at sparloft to sleeve for me.
#15 Kiwifish
Kiwifish
  • 141 posts
  • LocationHamilton
Posted 10 February 2018 - 08:10 AM
My fore beam goes into glassed tubes. I had to replace it because the rivets had reacted with the Ali under the seagull striker (they used stainless rivets and also no separation)
The grass is greenest where you water it......If light is the fastest thing. Then how did the dark get there first?
Www.gulfwanderers.blog
#16 MartinRF
MartinRF
  • 215 posts
  • LocationStockholm, Sweden
Posted 10 February 2018 - 09:55 PM
Re sleeving, here is a summary of work I did to help a Belgian Spyder owner.
/Martin
