Battleship 100 Posted April 20, 2015 Share Posted April 20, 2015 Get hold of the owner of NotNegotiable and have a look at the floors on that. (I have his number if you need it). That has a bulb keel. Link to post Share on other sites
boots 1 Posted April 21, 2015 Share Posted April 21, 2015 Not Negotiable was originally a 1034 and modified to a Y99 before launching in 1989. It had the wings cut off and the scoop put on the back before 1991 Suva race. Link to post Share on other sites
double n 0 Posted April 22, 2015 Share Posted April 22, 2015 Keel on Not Negotiable. I have looked into changing to a more modern one but there are some issues. There are substantial floors in the hull which would carry it but there is also a stub molded into the hull which protrudes about 150mm underneath which is same as Fastlane. To do it properly this would need to be cut off if a smaller fin was attached. This problem has been worked many ways on Y11's and photos can be found on the web. Having raced against Fastlane many times she is quicker in the very light and Not Negotiable is quicker when it blows above 10knots as she stands up to her sail better. Not Negotiable has a more powerful rig with masthead gear. Link to post Share on other sites
smithy09 50 Posted April 27, 2015 Share Posted April 27, 2015 I did the keel of The Entertainer recently and it made a huge difference (given my sailing hasn't really improved). Do not underestimate what it will cost. I didn't cut corners (I didn't do any of the work myself) and put in completely new floors which tie into a partial ring frame which has also made it possible to carry alot more rig tension. I just used a top plate (recessed flush with the hull) on the can bolted through to big washers in the floors and there is absolutely no movement. Mike Rees (Rees Castings) helped heaps and did a great job on the bulb and can, talk to Mike if you want a straight-up opinion. PM me if you want pics, drawings and idea on costs. Hey Ptown! I'm looking at upgrading the Marshall's keel to get some real righting moment, and I'm really interested on what it cost you, as I will be getting everything done by others. I'm under no illusions about costs, but I need to figure out just how big the bill will be!! If you could pm me how YOU got on, I'd appreciate it. Loving this thread.. Cheers, Smithy. Link to post Share on other sites
drbob 0 Posted August 5, 2015 Share Posted August 5, 2015 Well, I'm about to actually get the keel done on Airship - boat comes out Monday. The can is ex-Recreation and 1840mm long, new 720kg bulb by Mike Rees Castings. The fin will be faired to a new profile from Brett Bakewell-White. The work will be done by Matt at MG Composites in Welly. I'm currently trying to work out what documentation is needed - based on series date of around 1983 the YNZ regs indicate full-on ISO certification is not required unless I want Cat 2 or better. But obviously I want to know the structure will support the new loads, and to get Cat 3 I need a level of design documentation to satisfy the Safety Inspector (that bit at least is stated in the regs). If budget allows I want to also replace the cockpit. Here's a big shout out to Redline and Ptown for pics and advice from their keel jobs. Link to post Share on other sites
ballystick 83 Posted August 5, 2015 Author Share Posted August 5, 2015 Great, keep us informed about your progress, I'm interested in the bulb cost and the keel strut costs mainly. Link to post Share on other sites
drbob 0 Posted August 15, 2015 Share Posted August 15, 2015 Airship keel is now off. Apparently the nuts were loose, but the bolts tight as a whatzit. Was planning to go the Redline route and put in new floors between the existing, but thinking now just to go the Entertainer route and just replace with what we need. The logic is: 1. we don't actually know much about the existing ones; 2. we can put new ones in to align with new bolts. Link to post Share on other sites
drbob 0 Posted October 15, 2015 Share Posted October 15, 2015 Realised I didn't close the loop on this one. Airship keel upgrade is complete and we've sailed four race days on it with great results. What a difference! Photos of the job are here: https://www.facebook.com/AirshipR930 Link to post Share on other sites
Ptown 14 Posted October 18, 2015 Share Posted October 18, 2015 Great job Bob These are such great boats with the keel done! I just got the mast back in TE after our slight mishap so was out having a shakedown yesterday before the Coastal. You'll have to come up one year! Link to post Share on other sites
