jonathan 4 Posted June 7, 2015 Share Posted June 7, 2015 My teak wheel has a few slight splits , nothing too serious so worth filling. I am going to sand it and use uroxsys, but first what to fill the gaps with? tech sheet for Uroxsys says below , would any marine epoxy do ? Any cracks in the timber should be epoxy filled or splined with timber. Radius all edges to ensure that no sharp corners remain. Substrates should be thoroughly sanded to clean, even coloured timber working through the sandpaper grades to P150 grit (sanding with the grain using the 150 grit) to provide a keyed surface. Quote Link to post Share on other sites
Black Panther 1,591 Posted June 8, 2015 Share Posted June 8, 2015 Mix some epoxy and mix in some dust from sanding the same bit of wood? Quote Link to post Share on other sites
jonathan 4 Posted June 8, 2015 Author Share Posted June 8, 2015 you posted as I edited, but great idea using the sanding dust like that.... will make the epoxy easier to handle as its as runny as runny sh*t otherwise Quote Link to post Share on other sites
Black Panther 1,591 Posted June 8, 2015 Share Posted June 8, 2015 I like West epoxy, you can change the consistency depending on the job you are doing. But there are others on here more experienced than I, let's see what they say. Quote Link to post Share on other sites
jonathan 4 Posted June 8, 2015 Author Share Posted June 8, 2015 I have some west stuff, will probably use as This stuff is never cheap and I only need tiny amounts for this job. Quote Link to post Share on other sites
Island Time 1,239 Posted June 8, 2015 Share Posted June 8, 2015 I've tried that method with the epoxy - it comes out darker than the original timber, and you need mostly sawdust and VERY little epoxy to get close to the right color.... Quote Link to post Share on other sites
Kevin McCready 83 Posted June 8, 2015 Share Posted June 8, 2015 And test a tiny bit or bits perhaps out of sight first to see how it goes. Quote Link to post Share on other sites
John B 106 Posted June 8, 2015 Share Posted June 8, 2015 Yes , same timber dust inevitably comes out darker than the original.MDF dust gets you a lighter colour , might be ok with teak. I've used that, oxide , graphite , coffee, to get various colours. Quote Link to post Share on other sites
