Battgirl 23 Posted December 19, 2015 Share Posted December 19, 2015 Hi everyone some advice please on changing the large anode on the Volvo sterndrive ie the one behind the prop housing. Is this an easy diy or should it be left to so-called professionals? It doesn't need doing right now I am just being proactive. Cheers Quote Link to post Share on other sites
Bogan 8 Posted December 19, 2015 Share Posted December 19, 2015 If it's a 120 sail drive then the prop has to come off to change the anode. Can be done pretty quickly, eg: on the floating dock when getting a scrub down. The time is in taking off the prop and cleaning that up, and putting it all back together well. Make sure you tighten the two screws that hold the anode on real tight - you don't want the anode coming loose. The guys at the floating dock are pretty experienced and will likely give you a hand. Quote Link to post Share on other sites
Battgirl 23 Posted December 19, 2015 Author Share Posted December 19, 2015 Awesome Bogan. Thanks. Have a great Christmas Quote Link to post Share on other sites
Island Time 1,239 Posted December 19, 2015 Share Posted December 19, 2015 Yeah, easy enough, but the prop does have to come off. By the way, it's a saildrive, not a sterndrive - that is what some powerboats have I sometimes change my anodes in the water - like tomorrow! The Kiwi Prop is pretty easy to remove - the volvo 3 blade folder was a PITA! Quote Link to post Share on other sites
Young Entertainer 59 Posted December 19, 2015 Share Posted December 19, 2015 what is the issue with the anode coming loose? I noticed mine was loose when I washed last time so planning on fixing it after xmas when I am out of the water mid Feb, doe sit just mean that the other three on the saildrive after the housing might deteriorate faster? Quote Link to post Share on other sites
Island Time 1,239 Posted December 19, 2015 Share Posted December 19, 2015 Unfortunately this type of anode never stays tight. The zinc erodes behind the screws, effectively making them loose. I've never found a solution for that. I think it does make the anode less effective, as I'd expect it reduces the electrical connection to the boat - but I've never measured it. I have had the screws come out completely - once loose the anode can move a bit, and I guess over time they vibrated out. Did not seem to do any damage though... A better anode has a galv bar thru it to bolt it to the boat, the bolt does not go thru the zinc, but with a saildrive anode of this type there is no option I know of. Quote Link to post Share on other sites
Battgirl 23 Posted December 19, 2015 Author Share Posted December 19, 2015 Indeed IT it is a sail drive. Thank you for the correction and advice Quote Link to post Share on other sites
Farrari 4 Posted December 19, 2015 Share Posted December 19, 2015 I watched Grant from Allvo marine replace my anode on my 120S the other day. Some of the observations I made He was meticulous about cleaning the surfaces where the anode butts up to the saildrive and used a cleaner that didn't leave a residue He used a lead based grease on the mounting bolts He went through a process of tightening the bolts, tapping them with a mallet and re-tightening three times over He used a punch on the anode where it butted up against the bolts to reduce the chance of them coming undone I have had a number of people mention to use the genuine parts because some of the third party products don't last as long. There also seemed to be a couple of different anode part numbers that needed to be matched with the saildrive. Using the model 120S wasn't enough to determine what anode to use in my case. My observation was that it didn't take that long to do and while I could easily do it myself, it didn't cost that much to get a professional to do it for me and I had the confidence of a job well done. EDIT: Mine was a single piece anode that required removal of the prop. Quote Link to post Share on other sites
The big T 41 Posted December 19, 2015 Share Posted December 19, 2015 Some Volvo saildrives have a three piece anode which is secured into a slot around the saildrive by three bolts which need an Allen Key. Real easy to do underwater. You should have a quick snorkel to check before committing to a haul out. Quote Link to post Share on other sites
Island Time 1,239 Posted December 19, 2015 Share Posted December 19, 2015 If it's a 120s, there are models 120s thru 120s D. There have been 3 part numbers for the anodes, now all superceeded by the final one. Yes, a good, clean flush surface and tight bolts is the best way on these one piece anodes. The idea is to try to get the electrical connection to the SD thru as much of the connection surface as possible, so that the current runs thru that surface, not just the bolts. The larger the good contact area, the longer the anode lasts before eventually coming loose as zinc is lost. If it's only the bolts, it does not take long at all! Quote Link to post Share on other sites
