Marshy 30 Posted April 21, 2020 Share Posted April 21, 2020 One thing you want to do is add as little friction as you can to the masthead halyard, especially from the fractional point to the top - thats often when the gennaker just about sets, with the foot in the water and you need the guys to get it that last metre as quick as you can - often the difference between a glamour set, or a nice trawl and a visit to the sailmakers. So the bungy might add just enough friction to cause issues 1 Quote Link to post Share on other sites
Deep Purple 512 Posted May 9, 2020 Share Posted May 9, 2020 Okies, I've discovered there's a fractional halyard camcleat already so I've spliced a ring on the end of some 3mm uncovered dyneema then on to some covered 6mm dyneema for the bit that exits the mast and cleat. Next job is some sexy genny sheets. What sizes do you recommend KM. Gennaker is 60sqm on a boat displacing 900kg including crew. Crew is a mix of old farts with accountant type hands and a couple of girls young and old. In other words, no gorillas immune to pain Quote Link to post Share on other sites
Ex Machina 366 Posted May 9, 2020 Share Posted May 9, 2020 53 minutes ago, Deep Purple said: Okies, I've discovered there's a fractional halyard camcleat already so I've spliced a ring on the end of some 3mm uncovered dyneema then on to some covered 6mm dyneema for the bit that exits the mast and cleat. Next job is some sexy genny sheets. What sizes do you recommend KM. Gennaker is 60sqm on a boat displacing 900kg including crew. Crew is a mix of old farts with accountant type hands and a couple of girls young and old. In other words, no gorillas immune to pain Bugger it that’s light ! Our crew weight is 320kg ish so takes us a wee bit over a ton Quote Link to post Share on other sites
Deep Purple 512 Posted May 9, 2020 Share Posted May 9, 2020 11 minutes ago, 44forty said: Bugger it that’s light ! Our crew weight is 320kg ish so takes us a wee bit over a ton It’s only going to snubbing ring that captures the masthead halyard 3mm core was what the rope god suggested earlier in the thread Quote Link to post Share on other sites
Deep Purple 512 Posted May 9, 2020 Share Posted May 9, 2020 Spent the last 2 days learning how to do sh*t. YouTube is amazing 1 Quote Link to post Share on other sites
Brien 22 Posted May 9, 2020 Share Posted May 9, 2020 Nice work. Quote Link to post Share on other sites
Ex Machina 366 Posted May 9, 2020 Share Posted May 9, 2020 14 hours ago, Deep Purple said: It’s only going to snubbing ring that captures the masthead halyard 3mm core was what the rope god suggested earlier in the thread Sorry didn’t mean your halyard was light but your overall boat/crew weight Quote Link to post Share on other sites
Ex Machina 366 Posted May 9, 2020 Share Posted May 9, 2020 Are there any vids on YouTube on creating an eye in the middle of a sheet ? Would love a single gennaker sheet like the 18s use Quote Link to post Share on other sites
Deep Purple 512 Posted May 9, 2020 Share Posted May 9, 2020 12 minutes ago, 44forty said: Sorry didn’t mean your halyard was light but your overall boat/crew weight According to Rob displacement is 886kg with 320kg crew and 20kg outboard, but up to 50kg above that. I know the bare hull and decks was 125kg. I'll know once I put it on the scales Quote Link to post Share on other sites
Ex Machina 366 Posted May 9, 2020 Share Posted May 9, 2020 Way lighter than us then ! I should weigh ours but apparently it was 750kg empty with rig when built Quote Link to post Share on other sites
Marshy 30 Posted May 10, 2020 Share Posted May 10, 2020 I would highly recommend against a single endless gennaker sheet... If you have a cock up (which happens when going quick and rushing things) its very hard to unstitch it all. You want to be able to un-tie a single sheet while the other is loaded up. the 18's can do it because tehy arent changing kites, and its rigged up on the beach and left rigged up - plus issues = swim immediately. whereas on our boat it means a spilt beer and a tidy up. We think Smoke wagon is 700kg (just checked and Steve T says 760kg as launched so might be lighter than that now we have done some lightening up and also put a carbon rig in). Quote Link to post Share on other sites
mattm 98 Posted May 10, 2020 Share Posted May 10, 2020 I had an endless system in a sport boat for, I forget now, at least 5 years. Worked really well and never got in trouble with it once (the endless sheet bit anyway), and it ran big kites. Trick is having the right amount of sheet, enough it can flog when need be. I find it better, otherwise both sheets need enough to flog and it’s all over the cockpit floor all the time. New owner has changed it to separate, I find it’s a mess. A nifty knot/splice to allow it to gybe around the forestay is handy, but it didn’t matter as much once we got blow through gybes sorted. Quote Link to post Share on other sites
Ex Machina 366 Posted May 10, 2020 Share Posted May 10, 2020 Thanks for the info I was thinking of a single sheet but not continuous . Hole in the centre and soft shackle/luggage tag for quick change from gennaker to code zero etc Quote Link to post Share on other sites
