vic008 17 Posted January 4, 2021 Share Posted January 4, 2021 So if cut down, basically remove the plain shank part, will it still lock in the jaws? Quote Link to post Share on other sites
aardvarkash10 960 Posted January 4, 2021 Share Posted January 4, 2021 maybe, but if it slips, it makes a mess of the chuck. It should have a stepped land on the cutting face so the grip will be tenuous at best. Just get a cheap one, cut it off to length on the cutty bit, then regrind the tip Quote Link to post Share on other sites
erice 732 Posted January 10, 2021 Share Posted January 10, 2021 A - it'll be ready hard to cut the shaft off B - it may be very difficult to seat in a small 3 jaw chuck, you "might" get a better grasp with a larger chuck and/or wrapping the end with some shim stock .... however if you're drilling to drill in a confined space this is what you really need, an air-drill with right-angle head and compressor? Quote Link to post Share on other sites
Island Time 1,235 Posted January 10, 2021 Share Posted January 10, 2021 You can buy a 10mm right angle attachment, like this https://www.trademe.co.nz/building-renovation/tools/power-tools/drills-screwdrivers/listing-2927869341.htm?rsqid=00bcf61e69a04dd8a79f1d692c2412d6-001 Quote Link to post Share on other sites
vic008 17 Posted January 10, 2021 Author Share Posted January 10, 2021 Thanks for that OT, looks good, but in description it says max rpm 500 and think the Ryobi spins a bit quicker? Quote Link to post Share on other sites
erice 732 Posted January 10, 2021 Share Posted January 10, 2021 what are you trying to cut through and how thick? the air tools spin very fast but you often can't use the speed in deep frp as the resin melts most electric drills are variable speed now, you'll know when the little gearbox in the right angle is unhappy then you back off on the drill trigger a bit Quote Link to post Share on other sites
Fish 0 Posted January 10, 2021 Share Posted January 10, 2021 We've got one of these, for doing difficult jobs on the boat. 'Naked' they don't cost much (no battery), but we've got a few other milwakee tools that all take the same batteries. https://www.milwaukeetool.co.nz/power-tools/drills/right-angle-drills/C12RAD-0.html Quote Link to post Share on other sites
SloopJohnB 322 Posted January 11, 2021 Share Posted January 11, 2021 Most of my drills are short.....................broken.😉 Quote Link to post Share on other sites
