Psyche 843 Posted November 15, 2021 Share Posted November 15, 2021 Anyone made them, any comments on lifespan etc. Like the idea for cost and simplicity, always wondered how slippery Dyneema epoxied onto glass discs last, but was looking at a heavy penny washer and thought even a diamond knot or dogbone on one side and a bit of sika could be made into a very tidy high load solution. Quote Link to post Share on other sites
Clipper 375 Posted November 15, 2021 Share Posted November 15, 2021 Yes, made a few. I sandwiched dyneema between carbon layers. Came out very well. No massive loads applied to the ones i made, but they seemed very strong. Quote Link to post Share on other sites
Ex Machina 390 Posted November 15, 2021 Share Posted November 15, 2021 5 minutes ago, Psyche said: Anyone made them, any comments on lifespan etc. Like the idea for cost and simplicity, always wondered how slippery Dyneema epoxied onto glass discs last, but was looking at a heavy penny washer and thought even a diamond knot or dogbone on one side and a bit of sika could be made into a very tidy high load solution. Have a couple of mates who make these…not exactly sure of the process but It was dyneema sandwiched in carbon and I think silicone muffin trays were used in one version to get nice disc . Very strong but I think watertightness in the deck core is an issue ? Quote Link to post Share on other sites
Clipper 375 Posted November 15, 2021 Share Posted November 15, 2021 These ones Quote Link to post Share on other sites
Ex Machina 390 Posted November 15, 2021 Share Posted November 15, 2021 4 minutes ago, Clipper said: These ones Mint ! What are the rings for ? Quote Link to post Share on other sites
Psyche 843 Posted November 15, 2021 Author Share Posted November 15, 2021 Professional! Was going to make a few for sticking inside for hang things from plus outside for spin blocks and jib leads. Thought that half an hour going through brass plumbing fittings might get a quite a good solution too McDuff is selling these http://www.blueshark.cc/Soft-padeye/r-221.html which look pretty good and very cheap compared to Rope Eye Quote Link to post Share on other sites
Black Panther 1,775 Posted November 15, 2021 Share Posted November 15, 2021 I've always worried about chafe where the soft rope touches hard carbon, how easy are they to then replace? Quote Link to post Share on other sites
Clipper 375 Posted November 15, 2021 Share Posted November 15, 2021 1 hour ago, Ex Machina said: Mint ! What are the rings for ? The rings are tubes that are glued into the deck, to seal up core. Kind of a hollow upside down top hat Quote Link to post Share on other sites
CarpeDiem 535 Posted November 15, 2021 Share Posted November 15, 2021 24 minutes ago, Clipper said: The rings are tubes that are glued into the deck, to seal up core. Kind of a hollow upside down top hat Did you turn the tubes? Or is that some prefabricated something else? How do you stop water ingress? Does it just pool inside the tube? Quote Link to post Share on other sites
Clipper 375 Posted November 15, 2021 Share Posted November 15, 2021 14 minutes ago, CarpeDiem said: Did you turn the tubes? Or is that some prefabricated something else? How do you stop water ingress? Does it just pool inside the tube? Not turned. Carbon tube glued into carbon plate and edges sanded. push dyneema through hole, put sika around the flat carbon, pull up tight, clean up and let set. No ingress in to cabin, I suppose the base of the dyneema stayed damp, but never seemed to be an issue. Quote Link to post Share on other sites
Ex Machina 390 Posted November 15, 2021 Share Posted November 15, 2021 39 minutes ago, Clipper said: Not turned. Carbon tube glued into carbon plate and edges sanded. push dyneema through hole, put sika around the flat carbon, pull up tight, clean up and let set. No ingress in to cabin, I suppose the base of the dyneema stayed damp, but never seemed to be an issue. Aha ! that’s the missing link In the ones I’ve seen Quote Link to post Share on other sites
Rgvkiwi 15 Posted November 15, 2021 Share Posted November 15, 2021 These intrigue me, what is a suitable or meant for, application? Quote Link to post Share on other sites
CarpeDiem 535 Posted November 15, 2021 Share Posted November 15, 2021 3 minutes ago, Rgvkiwi said: These intrigue me, what is a suitable or meant for, application? To replace metal padeyes. https://www.ropeye.com/usage 1 Quote Link to post Share on other sites
