CarpeDiem 430 Posted September 4, 2022 Share Posted September 4, 2022 Can anyone point me to the inside throttle assembly for a typical yacht? I need to replace mine and I want to use the Spinlock control. But I can't work out what to put on the inside. Ours imploded tonight when switching to reverse and the throttle got jammed at a 100% full ahead unable to move or slow. We had a near miss with a fizz boat that was coming out of the marina. So near that our prod swept across their cockpit and someone literally ducked under the prod. Killed the engine and managed to get a rope round a pile... Sheesh! Quote Link to post Share on other sites
eruptn 95 Posted September 4, 2022 Share Posted September 4, 2022 Maybe some more detail of the unit on your boat? I had a similar experience backing out of a marina berth in Havlock, collected two launches an a pile in the process. Not a nice feeling! Turned out to be a cable clamp, bracket that had come free from a mount on a bulkhead next the the motor. Allowed the cable to bend without moving the lever on the gearbox. Nothing to do with lever in cockpit. Quote Link to post Share on other sites
CarpeDiem 430 Posted September 4, 2022 Author Share Posted September 4, 2022 Ouch. Mine is definitely the handle/lever inside mechanism. It's now in more pieces than it started the day. It's dual cable driven. One for the throttle one for the gear box. I don't know what model I currently have. I just want to replace the whole thing but I would like to be able to put the Spinlock control on the outside... Spinlock says it needs a Teleflex mechanism but I can't find much about it online. Quote Link to post Share on other sites
Y88 5241 25 Posted September 4, 2022 Share Posted September 4, 2022 I replaced my throttle controller to a spin lock one in February. The mechanism I used is this one https://www.marine-deals.co.nz/catalogsearch/result/?q=SeaStar+B700Ss+Side+Mount+Control then you use the spin lock exterior - https://fostersshipchandlery.co.nz/products/spinlock-atcu-winch-handle-throttle-control All works really well and a lot smoother than the old system! Nice upgrade. PM me if you have any questions. We did need a bit of reglassing to make the new one fit, as the old hole was quite a bit bigger. 1 Quote Link to post Share on other sites
Psyche 632 Posted September 4, 2022 Share Posted September 4, 2022 I got a sharp deal at Fosters when I upgraded recently, youll need the specific mechanism and Spinlock part as mentioned. It was under a boat dollar and I could not be happier with how it works so a good deal all around. 1 Quote Link to post Share on other sites
LE Bb 25 Posted September 4, 2022 Share Posted September 4, 2022 You should be able use the existing backing unit, of the original throttle unit was a single lever. I'm yet to see an issue with the backing units. Delt with plenty in the external throttle bodies Quote Link to post Share on other sites
Psyche 632 Posted September 5, 2022 Share Posted September 5, 2022 it all depends on the mechanism, some fit and some dont. Quote Link to post Share on other sites
CarpeDiem 430 Posted September 6, 2022 Author Share Posted September 6, 2022 4 hours ago, Psyche said: it all depends on the mechanism, some fit and some dont. Yep. My inside mechanism is in pieces. It seems to be some kind of compound fiber/resin/poly construction. From the photos I have seen it wouldn't of been compatible. But it's irrelevant now... Quote Link to post Share on other sites
Psyche 632 Posted September 6, 2022 Share Posted September 6, 2022 Mine was held together with a mixture of grease, salt and aluminium oxide- by now they are all pretty sad! Quote Link to post Share on other sites
CarpeDiem 430 Posted September 18, 2022 Author Share Posted September 18, 2022 On 5/09/2022 at 7:55 AM, Psyche said: I got a sharp deal at Fosters when I upgraded recently, youll need the specific mechanism and Spinlock part as mentioned. It was under a boat dollar and I could not be happier with how it works so a good deal all around. Did you use all the offset spacers? The body I got lines up perfectly with the spinlock holes... Do you just have the body suspended by the same screws that hold the spinlock plate on? Quote Link to post Share on other sites
Psyche 632 Posted September 18, 2022 Share Posted September 18, 2022 1 Quote Link to post Share on other sites
