CarpeDiem 537 Posted September 10, 2022 Share Posted September 10, 2022 This is my old throttle control hole. What would be the approved way of repairing this? I was thinking: 1. Grind out the edges so it's convex inside and out 2. Cut a piece of ply that is 10mm less thickness than the depth of the hole (5mm each side) 3. Fibreglass over the ply and into the convex edges... Inside and out. Having never done this before I have no idea if I am on the right track... Quote Link to post Share on other sites
Island Time 1,313 Posted September 10, 2022 Share Posted September 10, 2022 That'll work. For a structural repair, taper and overlap the glass. If you just want to fill the hole, find some suitable material (timber, foam) and use a hole saw to cut out a suitable size plug. Make it 5mm less deep than the thickness of the cabin top. Epoxy it in place, fill the cavity and fair (Vinylester filler is fine, dries in 20 mins, and sands well), paint to suit. 3 Quote Link to post Share on other sites
aardvarkash10 1,138 Posted September 10, 2022 Share Posted September 10, 2022 Did pretty much exactly that on a cabin top repair. Not sure I'd taper the inside - nothing is likely to force the plug outward. 1 Quote Link to post Share on other sites
Island Time 1,313 Posted September 10, 2022 Share Posted September 10, 2022 54 minutes ago, aardvarkash10 said: Did pretty much exactly that on a cabin top repair. Not sure I'd taper the inside - nothing is likely to force the plug outward. Actually, internal pressure is not unknown. Boats falling off waves with hatches shut can produce sufficient pressure to blow out windows on occasion. Quote Link to post Share on other sites
Changed 10 Posted September 10, 2022 Share Posted September 10, 2022 Why not insert a piece of foam and glass both sides. Quote Link to post Share on other sites
CarpeDiem 537 Posted September 10, 2022 Author Share Posted September 10, 2022 1 hour ago, Changed said: Why not insert a piece of foam and glass both sides. Where does one purchase foam from? After an actual shop name/supplier in Auckland. Quote Link to post Share on other sites
LE Bb 31 Posted September 10, 2022 Share Posted September 10, 2022 we got plenty of scraps 1 Quote Link to post Share on other sites
Changed 10 Posted September 14, 2022 Share Posted September 14, 2022 How thick is the core? Quote Link to post Share on other sites
