Winter 42 Posted December 11, 2023 Share Posted December 11, 2023 Is it a thing to re-use gaskets? I've pulled my exhaust manifold off, (blocked water passage) In the drawing below, Part 7 gasket is a goner, I need to find a new one of those (part number anyone?) But Item 17 is a thick metal looking one, and that seems to be a great order, only a couple years old. Do I need to replace it? Same with the Item 4 (gasket that connects to mixing elbow) that one seems ok - can I wipe it clean and re-use? Quote Link to post Share on other sites
Psyche 913 Posted December 11, 2023 Share Posted December 11, 2023 Should be fine as is, if not get some kind of goo to seal it. In days of yore there was literally a product called gasket goo , an awful brown treacly substance that you brushed on. People have successfully used garden variety silicon, I use loctite blue but any auto supplier will have a shelf of options. if you inspect the gasket and it looks ok and the mating surfaces are clean it should work. Head gaskets are a no though! 2 Quote Link to post Share on other sites
Winter 42 Posted December 11, 2023 Author Share Posted December 11, 2023 Thank you will do just that. Quote Link to post Share on other sites
Surprise 0 Posted December 11, 2023 Share Posted December 11, 2023 Shuk engineering can make you a replica. Quote Link to post Share on other sites
CarpeDiem 575 Posted December 11, 2023 Share Posted December 11, 2023 I have had experience with gasket hoop and won't touch it again. Making gaskets is incredibly easy. Although time consuming. I made my first one last Sunday for my heat exchanger/exhaust manifold. It was oddly satisfying... I was wrapped with how easy it was. I watched this video... Purchased a craft knife set and a litle ball pein hammer some gasket paper and I had a gasket within 4 hours! Now unfortunately the factory one I had already ordered and paid for showed up a week earlier than expected before I got to reassembly. But I have absolutely no doubt that my home made gasket would of worked... 1 Quote Link to post Share on other sites
harrytom 698 Posted December 11, 2023 Share Posted December 11, 2023 I used this on my old GM 15hp never had an issue being on the exhaust side same as you are doing. Quote Link to post Share on other sites
LBD 218 Posted December 11, 2023 Share Posted December 11, 2023 The paper material gaskets seal liquids and yes need to be softish, maybe use a little light smear of loctite 515 on both sides of a new gasket. A cross section of the metal gasket will show a wave shape that compresses when the joint is fastened up, one use only... it is only exhaust gases but even a small leak makes a black mess and blind air filters... I always replace this one. Make sure all surfaces are clean flat and dry... a flat oil stone or a flat board with wet and dry sandpaper with a little kero or CRC does wonders to clean up the faces. Quote Link to post Share on other sites
