Kestrahl 6 Posted October 3, 2011 Share Posted October 3, 2011 I have a volvo coupling, have heard two stories of them failing now on volvo 2002's with the rubbers detaching. Thought about some preventive maintaince but found the rubbers are $91 each (and there is 6 of them). Rubber must be expensive in Sweden. Anyone else heard of horror stories with these? Link to post Share on other sites
wheels 543 Posted October 3, 2011 Share Posted October 3, 2011 I haven't heard of volvo ones specificaly, but flexi couplings do indeed fail eventually. And yes, the rubber inserts can be expensive for all of them. I would take the spider (that's the rubber part) to a local engineering supplier or a Bearing supplier and see if it is an off the shelf spider for starters. That may mean a significant price reduction. There are two things that cause them to fail. The first is any misalignment which will cause abnormal wear and tear. The other is just normal wear and tear. Link to post Share on other sites
Guest Posted October 4, 2011 Share Posted October 4, 2011 I have a volvo coupling, have heard two stories of them failing now on volvo 2002's with the rubbers detaching. Thought about some preventive maintaince but found the rubbers are $91 each (and there is 6 of them). Rubber must be expensive in Sweden. Anyone else heard of horror stories with these? aren't you thinking about the rubbers in the prop on volvo saildrives, Kaimai flyer got rather perforated cause of one of those letting go Link to post Share on other sites
tuffyluffy 76 Posted November 11, 2011 Share Posted November 11, 2011 Ive just been shopping for some parts the mechanic needs to fix an issue I have with the VolvoPenta donk on my boat. There are 12 small parts in total and the entire supply would fit inside a shoebox, The prices I’ve received are as follows. USA NZD$501 + gst and courier UK NZD$399 + gst and courier Aus NZD$828 + gst and courier NZ NZD$951 + gst From what I can gather from the customs dept, no duty is payable. It might be worth letting your keyboard do the walking Link to post Share on other sites
Guest Posted November 11, 2011 Share Posted November 11, 2011 Ive just been shopping for some parts the mechanic needs to fix an issue I have with the VolvoPenta donk on my boat. There are 12 small parts in total and the entire supply would fit inside a shoebox, The prices I’ve received are as follows. USA NZD$501 + gst and courier UK NZD$399 + gst and courier Aus NZD$828 + gst and courier NZ NZD$951 + gst From what I can gather from the customs dept, no duty is payable. It might be worth letting your keyboard do the walking Bring it to Volpower's attention. They control the accredited NZ Volvo dealers. Marinepartsexpress is a good outfit to deal with if timing is not of concern. generally cheaper and very professional. They were extremely helpful when I was told by NZ that parts no longer exist for an old dunger we were trying to fix but after a bit of effort (not on my part) everything was found. Link to post Share on other sites
Gappy 9 Posted November 12, 2011 Share Posted November 12, 2011 Volvo are just one to rip on spares I needed a water pump for your boat was a no servicable pump last time we brought one cost us $500 then they wanted $1400 2yrs later and yes it only lasted 2 yrs and that the life they give them with the hours we did. So yip let the fingers do the walking landed into NZ for $315 bolted it on all sweet as. Link to post Share on other sites
Fogg 427 Posted November 13, 2011 Share Posted November 13, 2011 Came across a boat in Fiji with volvo and soft coupling. The owner made his own using rubber from car tyres. He swore they worked fine and he had a spare set ready in of failure between routine replacements. Link to post Share on other sites
Kestrahl 6 Posted November 13, 2011 Author Share Posted November 13, 2011 I've been eyeing up some possible alternatives. They are a stud glued in some rubber which is glued to a plate with another stud attached to that. Link to post Share on other sites
Grinna 2 Posted November 13, 2011 Share Posted November 13, 2011 We've just got hold of an R&D flexible shaft coupling for our boat. Can't remember the exact cost, but it was something like $240 I think. Looks like this Link to post Share on other sites
