Internal mast seal
18 replies to this topic
#11 44forty
44forty
  • 257 posts
Posted 22 August 2019 - 12:56 PM
Pourable silicon as in mould making stuff?
What about foaming epoxy?
Yep mold making stuff , it’s a bit easier to get the level correct with the drain hole
#12 Sail Rock
Sail Rock
  • 102 posts
  • LocationAuckland
Posted 22 August 2019 - 02:22 PM
If using pourable silicone, first check there are no old rivet holes or other gaps in the mast wiring conduit that the silicone can flow into. Otherwise you’ll fill up the conduit and not be able to replace or draw new wires through it!
#13 ballystick
ballystick
  • Marine Forums Only
  • 674 posts
  • LocationTauranga
Posted 22 August 2019 - 03:16 PM
Who stocks pourable silicone? I haven't been able to find anything that will pour and self-level except a Sika product for teak decks that has to be bought in bulk and has a short shelf life!
Edited by ballystick, 22 August 2019 - 03:18 PM.
We cannot direct the wind but we CAN adjust our sails
#14 Sail Rock
Sail Rock
  • 102 posts
  • LocationAuckland
Posted 22 August 2019 - 05:45 PM
I purchased some tubes from a Sika agent in East Tamaki a few years ago. It’s quite expensive. Google the Sika catalogue to find the specific product.
#15 ballystick
ballystick
  • 674 posts
  • LocationTauranga
Posted 22 August 2019 - 05:47 PM
I know what that is, I was looking for an alternative
#16 Island Time
Island Time
  • Administrators
  • 7,082 posts
Posted 22 August 2019 - 06:07 PM
try https://www.sculptur...ble-starter-kit
#17 Maté
Maté
    Sailor
  • 3,723 posts
Posted 22 August 2019 - 08:40 PM
When I did a mast on a previous boat I did the balloon trick, poured a thin epoxy slurry (it levels out the balloon top) then teak deck sika product. Epoxy would have done it except that heat/cooling cycles could have eventually broken the seal hence the teak deck stuff, (which was eyewateringly expensive)
#18 Chewing Gum
Chewing Gum
  • 895 posts
  • LocationAuckland
Posted 22 August 2019 - 09:35 PM
I did as suggested by Steve Ashley and removed a halyard sheave box near deck level. If you don't have a hole there I imagine cutting one around 50-60-70mm dia should be ok - check with a mast fabricator
Next shaped some flexible foam to approx mast shape and pushed it in through the hole and down say 15mm below sheave hole.
(Flexible foam - might have used the stuff Burnsco sell for seating - not sure.)
Then spread flexible sealant from Sika on top of foam and left to set. This was a few years back so can't remember the name of the sealant but it was not silicone. As Steve mentioned it was thicker than what Sika used to produce so dificult to push around back of cable tube so we still had a slight leak.
Next mod was put in a layer of slightly thickened epoxy on top. Voila no leaks and been there at least 5 years.
PK
#19 44forty
44forty
  • 257 posts
Posted 22 August 2019 - 09:40 PM
The Fibreglass shop stocks several different brands at varying prices . If you do an NZ specific search online for “liquid silicone “ there are quite a few suppliers
