vic008 17 Posted August 10, 2020 Share Posted August 10, 2020 in main saloon! Drip,drip,drip.Thinking can clamp an old sheet to the ceiling. Will it work? Quote Link to post Share on other sites
Black Panther 1,523 Posted August 10, 2020 Share Posted August 10, 2020 We insulated the cabin sole and installed a heater. Only thing that worked Quote Link to post Share on other sites
aardvarkash10 877 Posted August 10, 2020 Share Posted August 10, 2020 air movement. Get some. Quote Link to post Share on other sites
vic008 17 Posted August 10, 2020 Author Share Posted August 10, 2020 I leave the mainhatch and the forehatch open. Guess there is still no air flow. Wooden boat. Quote Link to post Share on other sites
DrWatson 357 Posted August 10, 2020 Share Posted August 10, 2020 Surprised you get so much condensation in a wooden boat. That grey carpety stuff seems to eliminate condensation more or less - it's the smooth polished (painted9 surfaces that allow it, IMO. Being a foam boat, Firefly only gets condensation on the windows except for the deck/hull joint, which is just solid glass. Seems to me that a layer of 3mm LD foam included just inside the inside-most layer of cloth would have pretty much solved that as it would insulate the joint as well. All through bolts could easily be recessed those 3mm... Brittany has a similar climate to NP in the summer, and Hamilton in the winter, so I'm thinking of getting a dehumidifier to leave running while in the marina this winter. Any thoughts on the dangers? Previously we have used lots of drypack dehumid. boxes and change them mid winter. But it's messy and I wonder about their effectiveness. Quote Link to post Share on other sites
Vorpal Blade 89 Posted August 10, 2020 Share Posted August 10, 2020 Just now, aardvarkash10 said: air movement. Get some. That and an external cover that's close fit while allowing an air gap keeping the rain off Quote Link to post Share on other sites
Steve Pope 243 Posted August 10, 2020 Share Posted August 10, 2020 5 hours ago, vic008 said: in main saloon! Drip,drip,drip.Thinking can clamp an old sheet to the ceiling. Will it work? Any bolts, fittings, etc. that pass all the way through will always drip unless you find a way of insulating them. I have an alloy hull / deck, every metal fixing screw that screwed into the deck beams / stringers would drip. We stuck thin foam strips along the stringers and used nylon machine screws to hold the ply up. No more drips. Quote Link to post Share on other sites
DrWatson 357 Posted August 10, 2020 Share Posted August 10, 2020 Capping every through fixed bolt/nut with a polyethylene dome nut cover works nicely. Quote Link to post Share on other sites
