vic008 17 Posted December 20, 2020 Share Posted December 20, 2020 Thinking to use some new 38mm hose, and, to keep costs down,40mm pvc rigid plumbing pipe wherever possible.Anybody done this? Practical? Quote Link to post Share on other sites
Steve Pope 243 Posted December 20, 2020 Share Posted December 20, 2020 Cheap piping just means that you will suffer from smells much earlier than if you used sanitation hose. 3 Quote Link to post Share on other sites
El Toro 97 Posted December 20, 2020 Share Posted December 20, 2020 What Steve said Quote Link to post Share on other sites
aardvarkash10 962 Posted December 20, 2020 Share Posted December 20, 2020 57 minutes ago, KM... said: There is no way I could have used PVC and it been cheaper than using a top quality flexible dunny hose. Fitting time alone let alone buying all the bends, glue and the pipe itself. plus, its designed to go into houses generally don't bounce, roll, pitch and yaw as a part of their operating method, and are built around standard angles (90, 45, etc). The drainage stuff does crack if its not supported or is subjected to a lot of movement. If you have a long run that can be well fitted and supported (preferably embedded) ok. Anything else, just get the right stuff and swallow the boat tax. Quote Link to post Share on other sites
Fish 0 Posted December 20, 2020 Share Posted December 20, 2020 I reckon once you have a go at fitting the proper dunny hose over any fitting, you will want to avoid as many joins as possible, and be happy to pay the $$. It is damn near impossible to get that stuff onto fittings... You'd need a good long run of PVC to make it worth it, with double stainless hose clips on every joint the dollars will add up fast. Not to mention working out how to join the two dissimilar diameters. The other option is to get a compositing head. It may well be cheaper, and far easier to install. Quote Link to post Share on other sites
Steve Pope 243 Posted December 20, 2020 Share Posted December 20, 2020 Composting head answers most of the issues that arise from a conventional head (holding tank etc) and all the legislation that has and is coming our way. But do make sure you have "head room" unless you are only 1500mm tall, as they are around 500mm tall as against app 300 to 350mm for the one you are (I was) replacing. Quote Link to post Share on other sites
Terry B 71 Posted December 21, 2020 Share Posted December 21, 2020 Steve, you happy with the composting toilet you installed? Thinking about one next time the jabsco breaks down. Which will probably be the next time I use it 🙂 Apologies for the thread drift.......... Quote Link to post Share on other sites
Steve Pope 243 Posted December 21, 2020 Share Posted December 21, 2020 16 hours ago, Terry B said: Steve, you happy with the composting toilet you installed? Thinking about one next time the jabsco breaks down. Which will probably be the next time I use it 🙂 Apologies for the thread drift.......... I think I would have been had I had enough "head" room. I measured the footprint, no problem, I never gave the extra 200 mm of height a thought, until I sat upon the throne! I would need to do serious mods to allow me to sit without my neck being bent over and by ear against the deck head. Mat imported quite a few several years ago and installed one, I believe he is very happy with his. They make a lot of sense and take away any problems with the poo police. Quote Link to post Share on other sites
wheels 543 Posted December 21, 2020 Share Posted December 21, 2020 I had to do a lot of plumbing for my land based inside out boat with PVC pressure pipe. I was shocked at the cost of fittings etc. So I looked on trademe and now use this business to supply all my fittings. Always been very fast delivery and parts are at a fraction of the cost. All stamped with the proper ANZS numbers as well. Look on trademe for https://www.trademe.co.nz/a/marketplace/business-farming-industry/farming-forestry/irrigation-drainage/pipes-distribution/listing/2906199433 I noticed a couple of others as well, so could be worth a comparison. 1 Quote Link to post Share on other sites
Sail Rock 28 Posted December 22, 2020 Share Posted December 22, 2020 I replumbed my head and holding tank a couple of years ago with a combination of marine sanitary hose and domestic PVC waste pipes plus bends, elbows, etc. It works fine and no odours. I needed to use the rigid pipe on some sections due to tight spaces and bends that the sanitary hose couldn’t accommodate. The rigid pipes are well supported so there haven’t been any problems with movement or cracking. Quote Link to post Share on other sites
