Fogg 427 Posted August 1, 2021 Share Posted August 1, 2021 1 hour ago, grant said: I like the "double glazed" idea, and agree with comments about the slope for keep the water out. That aside and going back to your original drawing, if the air inside is warmer than that outside how much airflow through the holes? It would go through if there is air coming forward to force it. What if the low holes were on the inside and high on the outside? as the warmer air goes in and rises it goes out the top, creating (a very small) thermal draft. Or I could be way over thinking it.... I think that’s actually the rationale for my design. Maybe the French do know what they are doing with boat design after all… Quote Link to post Share on other sites
aardvarkash10 1,179 Posted August 1, 2021 Author Share Posted August 1, 2021 4 hours ago, Fogg said: I think that’s actually the rationale for my design. Maybe the French do know what they are doing with boat design after all… aaaaaah mais oui! Tout de brilliant design avec un finettre with the holes in it aussi! Perfect pour le cruise de Mediterranean assisted by beaucoup de dollie birds and buckets of champers! Avoidee-vous the pooping though, n'est pas? 1 Quote Link to post Share on other sites
aardvarkash10 1,179 Posted August 8, 2021 Author Share Posted August 8, 2021 Thanks to Crew member lateral, I got a piece of 10mm acrylic that looks like it would hold back the Apocalypse, and is large enough to replace the entire upper board, which it will now do. I want to glue a lap onto the bottom of the sheet so that it overlaps the bottom washboard. I've cut a strip of the acrylic and routered its edges ready to glue on, but then I thought "what with?" I figure cyno-acrylate, any other guesses or knowledgeable comments? Quote Link to post Share on other sites
Black Panther 1,834 Posted August 8, 2021 Share Posted August 8, 2021 Glue 1 Quote Link to post Share on other sites
Island Time 1,351 Posted August 8, 2021 Share Posted August 8, 2021 10mm does not really need an overlap, most just cut it at 45 deg.... 1 Quote Link to post Share on other sites
DoT 31 Posted August 8, 2021 Share Posted August 8, 2021 I believe you can make an effective glue by "melting down" some of the acrylic waste (trimmings and shavings) with acetone. 1 Quote Link to post Share on other sites
aardvarkash10 1,179 Posted August 8, 2021 Author Share Posted August 8, 2021 3 hours ago, Black Panther said: Glue I'm gonna stick that one in the "guesses" pile 😝 Quote Link to post Share on other sites
Black Panther 1,834 Posted August 8, 2021 Share Posted August 8, 2021 I didn't think a hose clamp would do it. Maybe duct tape. 1 Quote Link to post Share on other sites
aardvarkash10 1,179 Posted August 8, 2021 Author Share Posted August 8, 2021 21 minutes ago, Black Panther said: I didn't think a hose clamp would do it. Maybe duct tape. nothing you can't stick with duct tape Quote Link to post Share on other sites
Brien 22 Posted August 8, 2021 Share Posted August 8, 2021 This is a useful reference on the web https://www.permabond.com/resource-center/bonding-acrylic-industrial-adhesive/ 1 Quote Link to post Share on other sites
aardvarkash10 1,179 Posted August 8, 2021 Author Share Posted August 8, 2021 1 hour ago, Brien said: This is a useful reference on the web https://www.permabond.com/resource-center/bonding-acrylic-industrial-adhesive/ thats how tech articles shold be written - so even the stupid among us can understand them. Thanks Brien. Quote Link to post Share on other sites
Abel Seaman 19 Posted August 9, 2021 Share Posted August 9, 2021 On 8/08/2021 at 2:00 PM, aardvarkash10 said: Thanks to Crew member lateral, I got a piece of 10mm acrylic that looks like it would hold back the Apocalypse, and is large enough to replace the entire upper board, which it will now do. I want to glue a lap onto the bottom of the sheet so that it overlaps the bottom washboard. I've cut a strip of the acrylic and routered its edges ready to glue on, but then I thought "what with?" I figure cyno-acrylate, any other guesses or knowledgeable comments? I just made a box shaped shower dome using 5mm acrylic. Following research the whole thing is glued up using superglue. No problem. Quote Link to post Share on other sites
