Lukas 0 Posted April 9, 2023 Share Posted April 9, 2023 Hi, please does somebody tried to replace top rudder bearing on CAV 32? There is a decent play between shaft and collar and while engine is idle it makes decent rattle... Thank you, Lukas. Quote Link to post Share on other sites
Black Panther 1,809 Posted April 9, 2023 Share Posted April 9, 2023 Rudder will have to come off. This is done by pulling the shaft up ( leave the tiller on, even use it as a lever). When rudder and shaft removed the bearing can come out. I can't remember what sort of bearing they used but throw it away and ask Island Time where he gets his sexy super slippery ones from. You may need to take accurate measurements or find someone to do that for you. The new one should slip right in with a little dab of something to keep it in place. Replace rudder. If it is stiff remove and attack the inside of the bearing with sandpaper till it spins freely. There are no seals as it drains into the ocean. When finished you will have a greater knowledge of how it all goes together. The shaft is married to the rudder with two bronze keys. These may object to coming out, beat them. They can also lead to a tiny amount of slop which is unpleasant when sailing. I fixed it with an application of a hot mix of west epoxy. It locked them in and my assumption was being brittle a sharp tap would release them. But everything worked so well I never got to find out. 1 Quote Link to post Share on other sites
LBD 198 Posted April 9, 2023 Share Posted April 9, 2023 Proper solution... Take rudder and clamp to a machine shop and ask then to spread the clamp say 3mm, fit a 2mm shim in the gap and tighten up Set up in a lathe and bore to about 4mm larger than the diameter you accurately measured. Machine up a stainless steel sleeve about a 2mm wall thickness and slot it just a whisker wider than the key Clean up the keyways... and make a new good fit key. Thoroughly clean and dry all components... oil free, and assemble the halves, and key onto the shaft using a little Loctite... Quick dirty solution... Dismantle and clean all components oil free, and spread the clamp faces about 1mm. Assemble with Loctite "quickmetal" or Devcon epoxy metal on the shaft and keyway, and only nip lightly up the clamp. Next day or when fully cured tighten you the two halves to correct tension. Quote Link to post Share on other sites
Frank 193 Posted April 9, 2023 Share Posted April 9, 2023 11 hours ago, LBD said: Proper solution... Take rudder and clamp to a machine shop and ask then to spread the clamp say 3mm, fit a 2mm shim in the gap and tighten up Set up in a lathe and bore to about 4mm larger than the diameter you accurately measured. Machine up a stainless steel sleeve about a 2mm wall thickness and slot it just a whisker wider than the key Clean up the keyways... and make a new good fit key. Thoroughly clean and dry all components... oil free, and assemble the halves, and key onto the shaft using a little Loctite... Quick dirty solution... Dismantle and clean all components oil free, and spread the clamp faces about 1mm. Assemble with Loctite "quickmetal" or Devcon epoxy metal on the shaft and keyway, and only nip lightly up the clamp. Next day or when fully cured tighten you the two halves to correct tension. I would be doing the quick and dirty as LBD describes above, any of the epoxy/metal powder products such as JB weld or similar should do the trick, Chatfield engineering probably have bronze key stock and you can buy SS key stock at ANZOR in east tamaki. Then at a convenient time I would take it to a machine shop to bush the tiller head as described. Quote Link to post Share on other sites
SloopJohnB 334 Posted April 9, 2023 Share Posted April 9, 2023 or use a "Scottish key" Quote Link to post Share on other sites
LBD 198 Posted April 9, 2023 Share Posted April 9, 2023 When you look at it, it is actually a design fault. As the yokes from the tiller wear on the clamp piece, the clamping force on the rudder stock reduces until it is loose and there is no clamping force on the rudder stock.. and the key is relied on as the sole positive drive mechanism. Quote Link to post Share on other sites
Island Time 1,337 Posted April 10, 2023 Share Posted April 10, 2023 There should be no movement. Zero. The key should be a slight interference fit, when clamp is tight. Most tiller arms are like that, and provided there is no movement at all, they will last a very long time... Any tiller arm joints with pins should be bushed, and bushes replaced when needed. Vesconite bushes are self lubricated and last incredibly well. Quote Link to post Share on other sites
Frank 193 Posted April 10, 2023 Share Posted April 10, 2023 Vesconite is good stuff, as I understand it most engineering plastics will swell to some extent in water, Vesconite (trade name ? ) is one of the few that doesn't. I used oil impregnated Nylon for my first DIY rudder bearings it froze the rudder rock solid in a few weeks. I vaguely recall a few years back you could purchase a pourable graphite impregnated epoxy resin and cast perfect bearings with the rudder in situ, don't know if its still a thing. Quote Link to post Share on other sites
