CarpeDiem 577 Posted June 14, 2024 Share Posted June 14, 2024 19 minutes ago, Guest said: What put me off 5x cell was 50%=2.2V. (11V) Discharge curve YinLong Yes! But that will still will crank your diesel... Unlike a 11v LA. All these things your encountering are the reason I shelved my LTO start battery project 🤣 1 Quote Link to post Share on other sites
aardvarkash10 1,184 Posted June 14, 2024 Share Posted June 14, 2024 50 minutes ago, Guest said: 1 hour ago, aardvarkash10 said: Nope. It will start quicker, and given the duty cycle of a starter, 15% higher supply voltage is a "meh". I used to do 6v to 12v conversions on VW beetles. StArter was one of the things we left stock standard. Man, they cranked and fired inside one revolution!!! Expand Still be a "meh" at 25% aye? Yup. Starters are series-wound motors are pull huge current at 0 rpm but the current rapidly drops as starter revs increase. As long as you are not being stupid (30 seconds engagements repeated without a break), a starter motor will take a LOT of punishment. 1 1 Quote Link to post Share on other sites
Guest 141 Posted June 14, 2024 Share Posted June 14, 2024 Thanks for that "What cells are you using that are rated for 0.01C at 3.65v that's out there." ( O.001C 😬) IIRCly Both Will & Andy have charged to O amps terminal current to batteries "full capacity"? My CALB 230Ahr came with product specs in Chinese. So resorted to Prowse and Andy OGG coming to the conclusion that absorb was for lead in the main, and perhaps to balance but was not really necessary. For day to day. I've only ever top balanced once (8mnths after installing) was in a hurry so left it on bulk until HVD, then balanced manually until it started charging again, rinse repeat to 0.5A at 3.65V. Then synced Victron BMV. To 100%. Rested they returned to 3.35V/cell. Six months later, cells are well balanced but SOC is way out~ So I about to do it again, this time a bit better informed. Now have 2x Heltec 5A balancers and a new "absorb" V regime. Cheers CD! Quote Link to post Share on other sites
CarpeDiem 577 Posted June 14, 2024 Share Posted June 14, 2024 32 minutes ago, Guest said: IIRCly Both Will & Andy have charged to O amps terminal current to batteries "full capacity"? I doubt any lfp could support that even a handful of times. The li-ions would be getting depleted very fast! 32 minutes ago, Guest said: Six months later, cells are well balanced but SOC is way out SoC numbers literally become a random number generator after a few half cycles. Not even laboratory grade couloumb counters can get accurate SoC over many cycles without fully charging. I have to laugh when manufacturers claim they can maintain a SoC between 40%-80%... I encountered a so called system just recently which was under performing. We disconnected all the loads and fully charged the cells, surprise surprise, each cell some how magically absorbed 70%... I use a method of counting couloumbs each charge. If I put 1000watts in then that's how many I have to take out. Anything left over is an unknown. Quote Link to post Share on other sites
waikiore 523 Posted June 17, 2024 Share Posted June 17, 2024 This thread confirms that I am happy to stay a Luddite in my Kauri log with small solar and Yanmar 😇 3 Quote Link to post Share on other sites
aardvarkash10 1,184 Posted June 17, 2024 Share Posted June 17, 2024 1 hour ago, waikiore said: This thread confirms that I am happy to stay a Luddite in my Kauri log with small solar and Yanmar 😇 Lead acid chemistry rules!!!! 2 Quote Link to post Share on other sites
CarpeDiem 577 Posted June 17, 2024 Share Posted June 17, 2024 1 hour ago, aardvarkash10 said: Lead acid chemistry rules!!!! The battery in this photo is from the 65-ft sloop Blue Peter. As the engine was turned on to leave, there was a loud bang and the battery exploded. Fortunately, nobody was hurt. Quote Link to post Share on other sites
aardvarkash10 1,184 Posted June 17, 2024 Share Posted June 17, 2024 9 minutes ago, CarpeDiem said: The battery in this photo is from the 65-ft sloop Blue Peter. As the engine was turned on to leave, there was a loud bang and the battery exploded. Fortunately, nobody was hurt. See, excitement AND simplicity. 1 1 Quote Link to post Share on other sites
harrytom 698 Posted June 17, 2024 Share Posted June 17, 2024 11 hours ago, CarpeDiem said: The battery in this photo is from the 65-ft sloop Blue Peter. As the engine was turned on to leave, there was a loud bang and the battery exploded. Fortunately, nobody was hurt. lack of maintaince I would say. How many check the water in older batteries or rely on seeing the little green light in the glass? Quote Link to post Share on other sites
waikiore 523 Posted June 17, 2024 Share Posted June 17, 2024 But no singeing fire. Yes I will stick with Lead Acid as it has always worked for me on board. And AGM versions in my cars. 1 Quote Link to post Share on other sites
