eruptn 111 Posted December 15, 2024 Share Posted December 15, 2024 A small leak has started from behind the pulley. What are the servicing/rebuild options? At last impeller service, I had to get cover plate machined (wear groves). Starting to think maybe a new one, what are options? Who is best supplier, are there replacement options? Quote Link to post Share on other sites
Psyche 902 Posted December 15, 2024 Share Posted December 15, 2024 Just did this 6 months ago, they are usually are rebuildable. Your small leak means the bearings are probably gone but the lip seal and bearings on the shaft are available from Saeco's, the face plate can be lapped flat on a sheet of glass with varying grades of wet and dry, you can get gasket paper from most engineering supply places. The "foot" which compresses the impeller vanes may be a bit worn as probably 40 years old like most of them but the 2GM doesnt need much water so they have to be really stuffed. Take care removing the shaft and removing the bronze screw holding it in place if you do decide to remove it. At this point so close to xmas Id remove the pump and just replace the seal, bearings and impeller then pick the best side of the faceplate and lap it. Put it all back together and go boating. For parts give Bill Falconer a call, not sure who the other Yanmar agents are. Quote Link to post Share on other sites
Romany 164 Posted December 15, 2024 Share Posted December 15, 2024 There is a marine service place in the original orams boat stacky thing beside what used to be pier 21. Showing my age - I think its AB Marine?? Anyways I had my 3gm30F waterpump rebuilt there a whileback. I thought they were reasonably priced, but regardless - parts for mine were obtained there Quote Link to post Share on other sites
mcp 37 Posted December 15, 2024 Share Posted December 15, 2024 https://parts4engines.com/collections/yanmar-2gm-parts/products/yanmar-2gmf-raw-water-pump Quote Link to post Share on other sites
eruptn 111 Posted December 18, 2024 Author Share Posted December 18, 2024 On 15/12/2024 at 9:13 PM, Psyche said: Just did this 6 months ago, they are usually are rebuildable. Your small leak means the bearings are probably gone but the lip seal and bearings on the shaft are available from Saeco's, the face plate can be lapped flat on a sheet of glass with varying grades of wet and dry, you can get gasket paper from most engineering supply places. The "foot" which compresses the impeller vanes may be a bit worn as probably 40 years old like most of them but the 2GM doesnt need much water so they have to be really stuffed. Take care removing the shaft and removing the bronze screw holding it in place if you do decide to remove it. At this point so close to xmas Id remove the pump and just replace the seal, bearings and impeller then pick the best side of the faceplate and lap it. Put it all back together and go boating. For parts give Bill Falconer a call, not sure who the other Yanmar agents are. Who is Bill Falconer?…what company Quote Link to post Share on other sites
aardvarkash10 1,160 Posted December 18, 2024 Share Posted December 18, 2024 Bills contact details. The ancient YaMariner himself. 1 Quote Link to post Share on other sites
ex Elly 276 Posted December 19, 2024 Share Posted December 19, 2024 Bill is the "overall" man of action! It says so on his van... 😄 Quote Link to post Share on other sites
