GregW 28 Posted April 27, 2012 Author Share Posted April 27, 2012 Anzac day and trial fit of rear beam. A bit tight on one side so will have to get the grinder out I recall having this conversation with you about 18 months ago when I started building my beams (you were building your main hull beam mounts) ! I decided to build the beams first, then the beam mounts, so I could get an exact fit, you were sure you could build the beams "to plan" and they would fit... classic... Actually they do fit as you can see in the pics, just the top corner of one rear trough needs a couple of mill taken off to allow for glass and paint (ie. I made it too narrow there). Its no biggie and I'm surprised I didn't notice it earlier err.. before I painted it . Sat in the cockpit for a while and started visualising control layouts, where to put winches etc etc. Ah yes - boatbuilding 900hrs; sitting around gazing at it and daydreaming 899 hrs I think I probably tend to daydream more than most Link to post Share on other sites
GregW 28 Posted July 10, 2012 Author Share Posted July 10, 2012 Tempus fugit and all that, time for another update - it feels like I've been building beams for a while Dragged everything out of the shed for a bit of a trial mock up last weekend and it looks like everything will fit which is a plus. Also last trial fit for the front beam before glassing and checked out the dagger board machined by Styrotech (cheers Kevin and CJ), which now I just have to glass. What else... bought all the bits for mainsheet and traveller, getting all the stainless bolts and brackets done. and now investigating mast options, so after a year or two of not spending much, the wallets well and truely been prised open again. Link to post Share on other sites
Clipper 343 Posted July 10, 2012 Share Posted July 10, 2012 that tree is gonna slow you down somewhat... Link to post Share on other sites
Guest Posted July 10, 2012 Share Posted July 10, 2012 You are going to have trouble getting it down the driveway with that tree where it is Nice work. Link to post Share on other sites
Atom Ant 0 Posted July 10, 2012 Share Posted July 10, 2012 I'm confused, I thought you were building a tri. What's with the weird front beam? Link to post Share on other sites
Variant 2 Posted July 11, 2012 Share Posted July 11, 2012 Cool photo's there Are you still going to use the mast you bought a while back? Link to post Share on other sites
203 0 Posted July 11, 2012 Share Posted July 11, 2012 Iv got boat building envy again now! Maybe something might happen when Iv finished school.. Looks like your doing a awesome job! keep it up! Cant wait to see her launched! Link to post Share on other sites
Megwyn 2 Posted July 11, 2012 Share Posted July 11, 2012 Nice one Greg - she is starting to look a bit like a boat Not long now? M Link to post Share on other sites
samin 0 Posted July 11, 2012 Share Posted July 11, 2012 Good work Greg. Cant wait to see her all assembled. Its about now you start thinking what an awesome Cat you could have..... well at least we did... Link to post Share on other sites
GregW 28 Posted July 12, 2012 Author Share Posted July 12, 2012 Thanks all. I'm confused, I thought you were building a tri. What's with the weird front beam? According to the designer it gives more 'humping height' over the forward berth. Cool photo's there Are you still going to use the mast you bought a while back? Not sure yet. Yours looks like its coming along well. Give me a yell when you're ready to turn over. Good work Greg. Cant wait to see her all assembled. Its about now you start thinking what an awesome Cat you could have..... well at least we did... LOL, You're not wrong there. I'm sure the SM floats would also have made a pretty effective pod cat. Link to post Share on other sites
Clipper 343 Posted July 12, 2012 Share Posted July 12, 2012 According to the designer it gives more 'humping height' over the forward berth. humping height! Link to post Share on other sites
Guest Posted July 12, 2012 Share Posted July 12, 2012 Now there's a designer I can relate to. Link to post Share on other sites
GregW 28 Posted July 13, 2012 Author Share Posted July 13, 2012 humping height! This is a technical term I understand - although I couldn't find it in Skene's As a little aside, 21 footer to Graeme's design , currently being built in Germany and nearly ready to be launched. Link to post Share on other sites
Guest Posted July 13, 2012 Share Posted July 13, 2012 Does he give the humping height for that one? Link to post Share on other sites
GregW 28 Posted July 13, 2012 Author Share Posted July 13, 2012 Does he give the humping height for that one? Its got sitting headroom over the double bunk which most people should find adequate. Link to post Share on other sites
ScottiE 174 Posted July 15, 2012 Share Posted July 15, 2012 Those beams look a bit marginal Link to post Share on other sites
GregW 28 Posted July 15, 2012 Author Share Posted July 15, 2012 Those beams look a bit marginal They have water stays for sailing (not fitted in pic) Link to post Share on other sites
GregW 28 Posted September 7, 2012 Author Share Posted September 7, 2012 Quick update, beams are glassed and put to one side while I finish decking the floats. Question for the tri guys - do you antifoul the floats or not bother? Link to post Share on other sites
203 0 Posted September 7, 2012 Share Posted September 7, 2012 One of the floats would always be in the water, So probably best to do both, but only where necessary Link to post Share on other sites
samin 0 Posted September 7, 2012 Share Posted September 7, 2012 Quick update, beams are glassed and put to one side while I finish decking the floats. Question for the tri guys - do you antifoul the floats or not bother? yep I tried not antifouling the floats when I first launched GDT, bad idea, grew slime very quick. I have antifouled the floats on SM and its great slime doesnt really grow and when it does I can just wipe it off easy Link to post Share on other sites
