I have been meaning to give soft baiting/jigging a bit of a go since when we do fish I am really sick of the stink, mess and cost of bait.
Everybody I have spoken to says its important to have a sea anchor so that your drifting at the right speed etc. We are 40ft/13ton - and the sea anchors at Burnsco aren't rated for yachts that big, and I don't quite want to go full nuclear on this problem and get a coppins custom one.
Anyone have any ideas on what to do here?
AG
I'm not really sure why the drift rate matters that much when you are soft baiting. I always thought it was more how you made the bait move and look.
I would have thought the issue was more about keeping your boat head to wind. Maybe heaving to would do the trick for you? Either that or just try the biggest sea anchor Burnsco have.
Note, I am one of the most environmentally conscious fisho's about. Despite regularly fishing (with the kids) all I have managed to catch is some fan worm...
Oh, and snapper when using the bait and burly method.
Had huge success while anchored,just keep s/b about 150mm off the bottom and boat movement keeps it moving,just gone to Zman for zilch,gone back to gulp pink/green 4inch seems to work ok,not a lot but a feed.Gulp has a sauce in packet and zman seems dry and need to add a sauce for it to work.
16 minutes ago, bigal.nz said:
Interesting about not needing the sea anchor. Will give it a go and the heave to method!
Remember, all the fishos use boats with loads of windage and nothing in the water. Drift rates and windage etc for a fizz boat will be completely different to a yacht. I'd see why they need a drouge
whether you need a sea anchor is really a function of wind and tide.  I doubt you will need one.  The drift rate matters as does your soft bait hook weight.  You will need different weighted hooks even if the drift rate is low due to depth.  Fundamentally you are trying to get to the bottom.  Too high a drift rate versus too smaller a hook weight and you will not get there.  You may need different sized soft baits, the hooks come in different lengths, the bait needs to match.
Jigs can be good.  There are different types and they work really well if you are fishing in a workup or you can see (fishfinder) a bait ball which is likely to have larger fish i.e. snapper underneath.
Ahh. Good to know. Sometimes we are around park point or near matiatia where there seems to be reasonable currents. We certainly drift quickly past the fizz boats with sea anchors out.
When drifting say south,cast in that direction and wind as boat drifts to where you cast,1/2oz is a good starting point up to 3/4oz shouldnt need to go any heavier. I very rarely drift as most of the time current against the wind,prefer a stable platform so normally anchor and cast ahead and wind back
Yep they work wicked in workups ....park upwind within casting distance , chuck it amongst the work up and let it sink . 9 times out of 10 it will get hit on the drop by snapper about 10 metres or more below the work up ....same technique works well with the sliders pictured up thread
  • Upvote 1
I drift fish on my 8Y8. Have never found the need for a drogue. I swore I would always be a bait fisho until I tried slow jigging with a slider on my bait rod. The results were so good I succumbed to buying a new rod and reel loaded with braid. The braid means you can feel every tap.
  • Like 1
