All Activity
This stream auto-updates
  1. Yesterday
  2. Here is a pic of how the system works...
  3. Nope. There will be a heat exchanger between fridge and freezer. Not yet installed. I'll post a pic when it is, but there are 2 50mm dia tubes between fridge and freezer. There will be a SS plate/cover over them on freezer side, and on fridge side a temp controlled fan takes air from top of fridge, blows it across the plate in freezer, returns it to fridge. There is no air exchanged between fridge and freezer, as that causes frosting. Basically the fridge runs as a parasitical load from freezer. So both cabinets from the one condenser...
  4. I can't see a plate in the fridge? I assume that's the freezer with the plates in it? Do you have fans cooling the fridge from the centre holdover plate?
  5. Is ozefridge electric compressor or boat motor driven?
  6. Its an Ozefridge. Its air cooled until the condenser reaches 38 deg, then it swaps to water (fresh water, borrowed then returned to the tank). Uses eutectic tanks for holdover. Once finished, I hope to be back to one run per day, about 30% of the time in the tropics, less here in NZ... Does not really use the water cooling in NZ, except sometimes in mid summer.
  7. Last week
  8. For another discussion so we don't get side tracked, I still dont agree that public standards should be behind a paywall. Once upon a time you could go the govt bookshop behind the St James and get or order pretty much whatever publication by any ministry for a nominal fee. Thanks for the library tip CD, you're right we have a pretty good idea of what and how.
  9. Guest
    Lithium conversion
    Whether you know the rules or not , insurance companies will give you the cold shoulder if you diy without a commercial installer’s certification of proficiency . (Ime, anyway) And they have little comprehension of AYBC E13. Not that there is much to follow. As CD said, he and IT have covered the niceties. Not that it will help the diyers with insurance even if you blind them with contingency electrical engineering. Btw, I used to pay $300 every so often for updates to NZS3604, seems they are mostly free now. Guess there’s not much point in having “industry best practice” behind a pa
  10. Available at public libraries - check out the catalog. There's actually sfa to the Lithium install rules and its content has already been posted in this forum pretty much verbatim.
  11. Plumbing standards, domestic and commercial electrical standards, gas fitting standards, motor vehicle design and construction standards, standards for the construction of houses. None of these are free to access. Again, most people lack the technical knowledge to interpret a technical standard. The ASNZ standard for lithium installations is about $250 in pdf format so it's unlikely that access to the standard is actually holding back people dying to DIY it.
  12. Thanks Matt I'm liking this option I will give yih a call Cheers Howdie
  13. Doug
    Lithium conversion
    Yes definately need EWOF compliance and risk free installation as far as that is possible. Insurer requires installation or sign off by marine electrician . Burnsco have confirmed none of the lithium battery brands they sell are compliant.
  14. I'll clarify, it's not viable as a standalone business, it would depend on the details of the contract with the council. There are many businesses that are based on non market subsidies and this would be one of them.
  15. Intellectual property? Ok but tightly held by a government organisation that sets standards? Essentially, we're paying for the Information twice. I'm pretty sure the standards related to lithium battery installation are not rocket science, we essentially know what needs to be done but the specifics of it are not publicly available unless you pay. A good an analogy would be an act of parliament, publicly available and with a bit of effort you can understand the gist but to interpret the nuance, you need a specialist
  16. Alternative view. If you are serious about doing the project, paying for the IP that sets out the required standard is not unreasonable. Its probably the lowest cost component in the entire project. I'm a fan of letting the professionals deal with all that. The many technical standards I've been involved with assume a high level of technical competence - higher by far than Joe Blow wanting to DIY a job has.
  17. Suitable barge, $250,000 assume $0 value at the end of 10 years Staff, 4 @ 75,000 pa, $300,000 Operating days per year, 150 Daily plant operating cost inc maintenance allowance, $2000, $300,000pa Licences, fees etc, $2000 pa Legals and accounting, $10,000 pa Gross daily cost, no alliance for capital, profit line, tax etc, say $4500 1400 wrecks, projected 10 year period so 1 per day average High risk activity, time limited, no exit strategy so 150% nett profit would be reasonable. Each wreck would be in the region of $12 to $15k average to mak
  18. Try getting the standards to see what's required if you want to DIY or just to get your existing LA system updated as per the regs, they are all paywalled which I think is self defeating if you want people to comply with them.
  19. 1400, that's a great little business right there. You could dispose of the bulk of the smaller shitters very efficiently, as many a day as you wanted if you had the resources it's not an unreasonable 3-5 year project.
  20. I think you'll find it was worded as "...helps to pay for..." or similar. In that respect, any income to the council helps to pay for what the council and therefore the HM does.
  21. Ash. I do recall that when that fee, $50 pa was added it was specifically to address the abandoned boats issue around Auckland. There may be a thread on Crew about that, from several years ago.
  1. Load more activity
