Norwester 3 Posted March 1, 2022 Share Posted March 1, 2022 Aluminium mast. Quote Link to post Share on other sites
Norwester 3 Posted March 1, 2022 Author Share Posted March 1, 2022 I am going to sand off the paint on my mast and just go bare alloy. I am looking for waxing or other easy polishing ideas. Quote Link to post Share on other sites
aardvarkash10 962 Posted March 1, 2022 Share Posted March 1, 2022 wax implies regular maintenance to keep in coated and buffed etc. That would get tiresome pretty quickly for me - your view may be different. Quote Link to post Share on other sites
harrytom 646 Posted March 1, 2022 Share Posted March 1, 2022 Once paint off,let it oxidise naturally,the oxidation is alloy protection,may not look shiny and new but start polishing regularly and you are doing more harm than good. Quote Link to post Share on other sites
ex Elly 197 Posted March 1, 2022 Share Posted March 1, 2022 Some people use a clear coating called Nyalic on their masts: http://www.nyalic.co.nz/ Quote Link to post Share on other sites
raz88 96 Posted March 2, 2022 Share Posted March 2, 2022 Also consider having the old coating media(soda?) blasted rather than sanding? Might leave you with a better job. Quote Link to post Share on other sites
Norwester 3 Posted March 8, 2022 Author Share Posted March 8, 2022 Thanks for the good information. Soda blasting might just be the trick and that Nyalic is available here so I am going to try it. Quote Link to post Share on other sites
Romany 162 Posted March 8, 2022 Share Posted March 8, 2022 Please keep the thread going when u have more to add. I maybe following suit so it would be good to hear how you get on. Quote Link to post Share on other sites
aardvarkash10 962 Posted March 8, 2022 Share Posted March 8, 2022 Crew member funlovingcriminal did the hard mahi on his Farr 1020, but refinished in black. Process is the same however. Brass Tacks - My Boat - Crew.org.nz He also wrote up a bit about the process at about the same time - if you do a search you will find it. Quote Link to post Share on other sites
Island Time 1,235 Posted March 8, 2022 Share Posted March 8, 2022 Nyalic will work for a while, but will Crack and peel eventually. I considered all this, and decided to repaint. Too hard/expensive to remove all the paint to leave bare. Sanded, epoxy prime and topcoat, with brush/roller. Came out pretty good. Last paint job lasted over 20 years. Quote Link to post Share on other sites
Bad Kitty 252 Posted March 9, 2022 Share Posted March 9, 2022 1 hour ago, Island Time said: Nyalic will work for a while, but will Crack and peel eventually. I considered all this, and decided to repaint. Too hard/expensive to remove all the paint to leave bare. Sanded, epoxy prime and topcoat, with brush/roller. Came out pretty good. Last paint job lasted over 20 years. Agree, Nyalic isn't the long term solution it's cracked up to be. Quote Link to post Share on other sites
