Pugwash 0 Posted January 27, 2023 Share Posted January 27, 2023 Hi all. I am wanting to get a simple, reasonably priced depth sounder for my trailer yacht. All I can seem to find are fish finders. I’m not a fisherman, I’m a sailor. Dedicated depth sounders are too expensive. Any advice please? Quote Link to post Share on other sites
Psyche 847 Posted January 27, 2023 Share Posted January 27, 2023 For a TS theres no real need If its got a swing keel, I used a lead line and the chart. Or get on Ali Express for an el cheapo kayak device Quote Link to post Share on other sites
Clipper 375 Posted January 27, 2023 Share Posted January 27, 2023 If you are in auckland you could test it in your driveway at the moment… 2 Quote Link to post Share on other sites
ballystick 79 Posted January 27, 2023 Share Posted January 27, 2023 Simple fishfinders should still be OK, they will give you the depth and the bottom contour line gives a good indication of the depth change trend in a visual graphic form, an ascending line will indicate shallowing which is often better than numbers changing rapidly. I find it very useful in Tauranga harbour which is full of sandbanks. If your hull is solid glass you can glue a plastic (Sistema) container to the inside of the hull ahead of the centreboard, fill with glycol or oil and place the transducer in it. The transducer can be machined down to reduce it's size to fit. Attached is a cheap one, it needs to have a digital display as an option, most do a split screen option, unsure if this does but it is cheap. 2 Quote Link to post Share on other sites
eruptn 110 Posted January 27, 2023 Share Posted January 27, 2023 If your after a small footprint unit the Lowrance Hook2 4inch is very good value, nice clear screen in daylight. Allows you to see trend (is it getting shallower\deeper) .The bullet sensor an be installed inside, shoot thru hull an see to around 100’. Quote Link to post Share on other sites
The big T 45 Posted January 27, 2023 Share Posted January 27, 2023 If your hull is solid glass, just epoxy transducer to inside of hull making sure there are no bubbles in the bond. No box or liquid required. Quote Link to post Share on other sites
harrytom 698 Posted January 27, 2023 Share Posted January 27, 2023 2 hours ago, eruptn said: If your after a small footprint unit the Lowrance Hook2 4inch is very good value, nice clear screen in daylight. Allows you to see trend (is it getting shallower\deeper) .The bullet sensor an be installed inside, shoot thru hull an see to around 100’. I would not by a hook 2 even for depth use only, Can set shallow water or deep and yeah showing 10m in 40m, save your money or spend $100 more on a garmin striker https://www.burnsco.co.nz/12v-electrical/electronics/fishfinders-chartplotters/garmin-striker-4-plus-gps Excellent little unit,gps,tracking etc so many choices out there Quote Link to post Share on other sites
Pugwash 0 Posted January 27, 2023 Author Share Posted January 27, 2023 Thanks for the replies. I had looked at both the Lowrance and Garmin units. I wasn’t sure if I would be able to mount the transducer in side the hull. There is an existing through hull where a speed log used to be so I could possibly use that? Quote Link to post Share on other sites
