Guest Posted October 14, 2011 Share Posted October 14, 2011 I have a two burner Old primus stove fitted in 26 Raven probaly from standard and was wondering if anyone knows of a place that sells spares etc for them in NZ, bit scared to light it after being told one burner works fine but the other shoots out two foot flames but "ca,nt remember which one". Just thought it might be easier to re jet the old stove since its fitted to a gimballed bracket otherwise I have to try and find a new stove with the same dimensions will upload some pics of the stove soon going out tommorow. Link to post Share on other sites
Guest Posted October 14, 2011 Share Posted October 14, 2011 Take it home....outside.....set up level and have a good long play at lighting it etc etc, bit of a knack "driving" these beasties preheating is the key from memory however burn enough grass and you'll get on top of it no probs, most camping stores have/ had the pricker things to unclog the jet, the kero ones also run on diesel from memory Link to post Share on other sites
Guest Posted October 15, 2011 Share Posted October 15, 2011 Brought it home today and gave it a blow out with compressor but still could,nt get it to work properly after dissembly found a collection of mis matched bits just need to get two new primus burners to fit onto the old Tank and Bracket anyone know where to start looking? Link to post Share on other sites
wheels 543 Posted October 15, 2011 Share Posted October 15, 2011 I am pretty sure parts are no longer available. You may have to get a wee Gas cooker unit to replace it. But just incase, give 121 Marine a call, as they do a fair bit with Gas cookers re parts and fixing. Link to post Share on other sites
SloopJohnB 322 Posted October 15, 2011 Share Posted October 15, 2011 Try the "Silver Fox" Freddy Andrews at Marine Stainless. If my memory serves my right he use to make them plus all the stainless work on the Ravens for the 2 Dons. Link to post Share on other sites
Guest Posted October 16, 2011 Share Posted October 16, 2011 Try the "Silver Fox" Freddy Andrews at Marine Stainless. If my memory serves my right he use to make them plus all the stainless work on the Ravens for the 2 Dons. Cheers for that sounds about right as theres a sticker on it that says"Marine Stainless Fittings' Auckland looks they made stove and just used Primus running gear. Who were or are the "2 Dons"? I have found a mob in the States that sells spares for Primus old stoves (packstoves@aol.com)but would be good to find someone over here that sells seals washers,prickers etc. Would prefer to keep the Kero stove rather than go to Gas for safety reasons. Link to post Share on other sites
Steve Pope 243 Posted October 16, 2011 Share Posted October 16, 2011 I would have though any of the older established camping stores would have parts, maybe Fosters might have them in the dungeon somewhere?? I did try the tricky plumber for repairs to a M.S. Princess some time ago but was put off by someone who said they had had one overhauled but the estimate of around $500.00 jumped to a final bill in excess of $1100.00. Link to post Share on other sites
Guest Posted October 16, 2011 Share Posted October 16, 2011 Where are these older established Camping stores thats the trouble all the good ones I knew got sunk by these chain stores like Kathmandu ,Warehouse, rebel Sports etc etc where the guy serving you doe,snt even know what Kerosene is let alone re jetting a old Cooker. Link to post Share on other sites
Herdy 0 Posted October 16, 2011 Share Posted October 16, 2011 These stoves used Optimus burners from Sweden. There use to be an agent in New Zealand, but I can no longer find any details. You could try contacting Optimus via their website. I would unscrew a burner of the the tank and photograph it and send it to them. They should be able to help. The original Optimus company in Sweden was sold in 2007. Website: http://www.optimusstoves.com I rebuilt one of these stoves about 12 years ago. All that is involved in replacing the burners, and the leather cup on the end of the pump. Link to post Share on other sites
PaulR 3 Posted October 16, 2011 Share Posted October 16, 2011 bit scared to light it after being told one burner works fine but the other shoots out two foot flames but "ca,nt remember which one". Sounds like the burner has not been preheated enough and it is the kero that is flaring. First step: Are you using some meths to preheat the burner? It is an art to get just the right amount of meths on the burner. There were special bottles with brass tubes in a "U" shape to measure and dispense just enough meths. If wrong, then it's best to start again with a full load of meths. Using half loads and playing catch up never seemed to work. Second Step: Turning on the burner just as the last of the meths was burning was an advanced skill that took practice. Good Luck. PS Meths can be easily extinguised with a glass of water or damp cloth , but kero is washed burning into the bilge, which generally, but not always, creates a heighted level of interest from the owner, similar to the flare ups scorching the cabin deckhead or elephants' mating. Link to post Share on other sites
Chewing Gum 17 Posted October 17, 2011 Share Posted October 17, 2011 Gas is safe if set up correctly with bottle outside and a gas detector. Those primus stoves are a pain - you will end up with a blackened deckhead. Link to post Share on other sites
Guest Posted October 17, 2011 Share Posted October 17, 2011 Gas is safe if set up correctly with bottle outside and a gas detector.Those primus stoves are a pain - you will end up with a blackened deckhead. Yep I agree with you LPG is looking like a easyway out at the moment but I have to get this Keresone one going now for self esteem issues. Link to post Share on other sites
wheels 543 Posted October 17, 2011 Share Posted October 17, 2011 Yeah I hate those old primus things. You can end up with quite a BBQ going on when it all goes wrong. I feel much safer with Gas and you have so much more control. Link to post Share on other sites
Guest Posted October 17, 2011 Share Posted October 17, 2011 bit scared to light it after being told one burner works fine but the other shoots out two foot flames but "ca,nt remember which one". Sounds like the burner has not been preheated enough and it is the kero that is flaring. First step: Are you using some meths to preheat the burner? It is an art to get just the right amount of meths on the burner. There were special bottles with brass tubes in a "U" shape to measure and dispense just enough meths. If wrong, then it's best to start again with a full load of meths. Using half loads and playing catch up never seemed to work. Second Step: Turning on the burner just as the last of the meths was burning was an advanced skill that took practice. Good Luck. PS Meths can be easily extinguised with a glass of water or damp cloth , but kero is washed burning into the bilge, which generally, but not always, creates a heighted level of interest from the owner, similar to the flare ups scorching the cabin deckhead or elephants' I do,nt think its pre heating issues have burnt full cups of Meths and then heated it up with a Blow Torch just in case,one burner has a little needle that pops up and cleans the jet when you twist the knob to port the other doe,snt do that so must be rooted. I just want to arsehole the two burners and replace them but the cheapest I can find so far is 70 pounds each per burner plus postage tax etc basically equals the cost of a new LPG unit so it mght be time to switch. Link to post Share on other sites
Guest Posted October 18, 2011 Share Posted October 18, 2011 Burners and spares are available from this site http://www.oillamps.com.au Link to post Share on other sites
Guest Posted October 29, 2011 Share Posted October 29, 2011 http://www.trademe.co.nz/sports/camping ... 628842.htm This guy seems to sell everything you need to get your old Primus /Optimus stoves going, another helpful site full of Kerosene Stove Collectors is Spiritburners .com Link to post Share on other sites
ex Elly 197 Posted November 14, 2011 Share Posted November 14, 2011 I have bought parts from http://www.base-camp.co.uk/ Got the goods here fairly quickly. Link to post Share on other sites
Ike 0 Posted December 26, 2011 Share Posted December 26, 2011 I have one of these cookers on my boat, still using it regularly is now 30 yrs old. My first question are you trying the right fuel in it. My one is set up with jets to use methylated sprits as the main and priming fuel. I have serviced mine once about 10 yrs ago, there was at that time a Primus NZ agent , I dont see one listed now Link to post Share on other sites
Guest Posted May 16, 2012 Share Posted May 16, 2012 http://www.trademe.co.nz/motors/boats-m ... 121508.htm These are very nice but very expensive. Link to post Share on other sites
ilya 0 Posted May 2, 2013 Share Posted May 2, 2013 These stoves used Optimus burners from Sweden. There use to be an agent in New Zealand, but I can no longer find any details. You could try contacting Optimus via their website. I would unscrew a burner of the the tank and photograph it and send it to them. They should be able to help. The original Optimus company in Sweden was sold in 2007. Website: http://www.optimusstoves.com I rebuilt one of these stoves about 12 years ago. All that is involved in replacing the burners, and the leather cup on the end of the pump. Yea I belive even the burners in the Taylors Stoves use a burner built by Optimuss. there is one old agent of taylors in New Zealand. They have spaires avalable. Link to post Share on other sites
