Marshy 30 Posted May 10, 2013 Share Posted May 10, 2013 Pretty sure he still won it though? http://www.segel.de/oceanarchiv/rhum200 ... 1-233.html And the damage talked about there doesnt sound that bad, but for a single handed person sailing that boat its enough to want to pitstop and repair it... Link to post Share on other sites
Guest Posted May 10, 2013 Share Posted May 10, 2013 Big change of the bottom of hull, crossbeams. in 2005. http://www.voile-multicoques.com/resour ... $2Barr.jpg and http://www.voile-multicoques.com/resour ... 4A9ant.jpg OC Link to post Share on other sites
Guest Posted May 10, 2013 Share Posted May 10, 2013 Big change of the bottom of hull, crossbeams. in 2005. http://www.voile-multicoques.com/resour ... $2Barr.jpg and http://www.voile-multicoques.com/resour ... 4A9ant.jpg OC Subject to new safety rules, and special regulations JAN 2013 ISAF. ? At least 2 escape hatches with higher floatation and ............. ? OC Link to post Share on other sites
NZL3551 0 Posted May 10, 2013 Share Posted May 10, 2013 TVS has two escape hatches already in the main hull Link to post Share on other sites
Guest Posted May 10, 2013 Share Posted May 10, 2013 TVS has two escape hatches already in the main hull And the rest ect New Special Regs / Rules. Link to post Share on other sites
B00B00 361 Posted May 10, 2013 Share Posted May 10, 2013 Stick to your cruising OC. Link to post Share on other sites
Guest Posted May 11, 2013 Share Posted May 11, 2013 The ORMA60's were in constant change season to season with everyone trying to squeeze out a little more speed. Some they cut the whole of the main hull down in one season and replaced it with an upgraded shape for better efficiency. Accordingly a vessel at any stage or age is completely different from the year it was first built. 01-2005 Designers web site: "This winter, there were some major modifications made to the ORMA 60 trimarans to get them ready for the 2005 season." GEANT "New main hull under body to improve its versatility for offshore / inshore races, the existing main hull is actually more suited for offshore sailing." "Centreboard with a trim tab added to improve the performance upwind" Link to post Share on other sites
Guest Posted May 11, 2013 Share Posted May 11, 2013 What does this have to do with the A2B? Link to post Share on other sites
Guest Posted May 11, 2013 Share Posted May 11, 2013 Good point - those few posts are being migrated to another thread. Link to post Share on other sites
Guest Posted May 13, 2013 Share Posted May 13, 2013 TVS has two escape hatches already in the main hull They are supposed to have three counting companion way hatch. Quote from a well known designer Richard Woods. ORMA 60 Class in Trouble? "multihull crossbeams do break eg Groupama 3 is a better example, and it was a rapid failure, not gradual... do you know if they identified the reason for the 'shearing' of the beams/hull? I'm sure there are more trimarans especially, which have had beam problems of one kind or another. When I think of it, Hervé Cleris when he was skipper for Prince de Bretagne (2009?) had a hull drop off of his new Nigel Irens design, and wasn't Yves Blevec making desperate patches on his main beam in his last Route du Rhum? Lots of multihull crossbeams have broken over the years, even when they were designed to the predicted loads, and deciding what those are is the real crux of the problem. " What has this got to do with the A2B Race? They have an ORMA 60 entered and it has been suggested TVS will enter as well. The same Club has TVS entered in the Sail Fiji race. If TVS has a major failure it will put the race and other races to the SI & tropics in jeopardy for Multihulls. I certainly hope they don't have a major failure and resulting loss of life. Link to post Share on other sites
Navig8r 0 Posted May 13, 2013 Share Posted May 13, 2013 TVS has two escape hatches already in the main hull They are supposed to have three counting companion way hatch. They Do.... a 5 second web search would have shown that. Port side: Just behind the "e" in vodafone http://petertasker.photoshelter.com/gal ... syfnEeJqeA Starboard side: Just behind the Vodafone logo. http://www.sail-world.com/photos_2011_2 ... ng_Std.jpg http://line7.co.nz/marine/files/2012/05 ... ponsor.jpg Oh and before you say it... they even have a companionway http://yachtyakka.co.nz/wp/wp-content/u ... 00x375.jpg Link to post Share on other sites
rigger 47 Posted May 13, 2013 Share Posted May 13, 2013 OC you seem to have an axe to grind with TVS. Why? Link to post Share on other sites
Guest Posted May 13, 2013 Share Posted May 13, 2013 OC you seem to have an axe to grind with TVS.Why? Whats makes you think that. OC. Link to post Share on other sites
rigger 47 Posted May 13, 2013 Share Posted May 13, 2013 Because it appears you are attacking TVS - you have pretty much stated that the vessel cannot comply with the Cat reqs, and have failed as you are ignorant about the current state of the vessel. Perhaps if you asked questions rather than appearing to criticize you may get a better response. Apologies to everyone for the thread drift. Squid I would totally understand if this thread was deleted. Link to post Share on other sites
Guest Posted May 13, 2013 Share Posted May 13, 2013 I have considered locking it, I have tried to split it to keep it on topic, I'm leaving in a couple of days and will probably suspend OC till I return as I did at Xmas. Lately I've been having fun trying to edit his posts to make them readable (I sometimes wonder if he is using one of those little keypad thingies and hence all the typos), it's kinda like doing a latin translations. Link to post Share on other sites
OYSTR 1 Posted May 13, 2013 Share Posted May 13, 2013 I've been having fun trying to edit his posts to make them readable (I sometimes wonder if he is using one of those little keypad thingies and hence all the typos), it's kinda like doing a latin translations. He has his discombobulator set to maximum at the moment. Link to post Share on other sites
Guest Posted May 13, 2013 Share Posted May 13, 2013 Because it appears you are attacking TVS - you have pretty much stated that the vessel cannot comply with the Cat reqs, and have failed as you are ignorant about the current state of the vessel. Perhaps if you asked questions rather than appearing to criticize you may get a better response. Apologies to everyone for the thread drift. Squid I would totally understand if this thread was deleted. I am asking questions. Team Australia is from the same designers and the same design as TVS the Troubled ORMA 60's class. which have major problems in heavy and storm sailing conditions. There has just been another Multihull failure although a Catamaran. If either TVS or Team Australia have a major failure or loss of life racing within NZ especialy in the A2B race in it,s inaugural race or from NZ waters imagine what that would do to Multihull vessel requirements and the A2B race and all other multihull races within the control off YNZ . The new safety regs also have quite clear requirements re floatation heights regarding the escape hatches when the vessel is inverted and floatation material / positions and amounts to acheive successful dry escape not wet submerged escape and the Cat class that is to be imposed in certain water tempatures. Only x rays of the beams would determine the state the vessel is in, so how can you say I'm ignorant. It would appear you and others rush in at any oportunity and attack me. Please show me where I have criticize. I have used quotation marks in the posts. OC. Link to post Share on other sites
Guest Posted May 14, 2013 Share Posted May 14, 2013 For the record, I am no longer reading this thread because of the resultant thread drift and repeat points being made. It's a shame because I was interested in the thread initially. I thought I would comment so that there was some visibility of the impact of thread hijacking, drift, trolling etc. I am sure I am not the only one shaking my head in frustration. Link to post Share on other sites
Guest Posted May 14, 2013 Share Posted May 14, 2013 Wise choice KB....... Link to post Share on other sites
Guest Posted May 14, 2013 Share Posted May 14, 2013 I've been having fun trying to edit his posts to make them readable (I sometimes wonder if he is using one of those little keypad thingies and hence all the typos), it's kinda like doing a latin translations. He has his discombobulator set to maximum at the moment. "Discombobulator only works on meshes and, at that, only on quadrilateral faces. Triangles will simply be left alone so you can discombobulate a mesh that has triangles, but only the Quadrilateral faces will be discombobulated. At this point, materials aren't supported so a discombobulated mesh will not retain materials. So make sure to add materials last. In addition, a discombobulated mesh will always be moved to or created in layer 11. I know these limitations can get annoying, but bear with it." Link to post Share on other sites
