cep32 4 Posted February 2, 2016 Share Posted February 2, 2016 So I just broke my third rivet gun in five years. This time I was just putting the normal Burnsco monel rivets in the mast and just like before the jaws broke. The latest gun was a $60 Stanley one so I thought it would do the trick. The last one was a concertina style one. Can anyone direct me to a decent one that won't break the bank? Link to post Share on other sites
erice 732 Posted February 2, 2016 Share Posted February 2, 2016 how about HR003 HIT LONG ARM RIVET TOOL description..A heavy duty rivetting tool with long arms for extra leverage - accepts 3mm 4mm 5mm aluminium and steel rivets http://www.toolware.co.nz/results.php?pageNum_rsCWResults=2&category=22 or these http://mytools.co.nz/collections/hand-tools-clamping/riveting Link to post Share on other sites
Island Time 1,313 Posted February 2, 2016 Share Posted February 2, 2016 You need one that specifically says Monel rivets. Ones designed for alloy just wont deal with the power needed for a Monel rivet. I did not know Burnsco sold Monel rivets, just alloy ones.... Link to post Share on other sites
wheels 544 Posted February 2, 2016 Share Posted February 2, 2016 If the jaws break, it is nearly always the wrong size rivet. Make sure you have the correct tip size. Although in saying that, Stanley is not Stanley of old. Once again, many of the hand tools supplied by the "Bunnings" of this world, seem to be poor quality made in China. In fact if you look closer at the range of hand tools on offer, you start to see that many are almost identical with just minor variations in things like the grip and colour. I bought a set of cable strippers recently. This is one tool where I try not to scimp on quality due to using them lots. I looked carefully at several and noted them as being identical. So I bought the Stanley seeing it was best price, but looked the same as the others. It ended up being a piece of junk. The two mistakes I made were Buying from Bunnings and expecting a quality tool. And buying Stanley and expecting a quality tool.You just can't trust Brand Name to give you quality anymore. Link to post Share on other sites
wheels 544 Posted February 2, 2016 Share Posted February 2, 2016 It's also very surprising who owns what companies. Although just because a company owns another that is a known quality tool maker, does not always mean the other names are of equal quality.Stanley are now Stanley Black & Decker and under that name, own Bostitch Dewalt Porter Cable Stanley Blackhawk (Proto) Bost Britool Facom Lista Mac Tools Pastorino Powers Proto Sidchrome USAG Vidmar Link to post Share on other sites
all fired up 8 Posted February 2, 2016 Share Posted February 2, 2016 I purchased one of the expanding caliber type of Rivet Gun from Ullrich Aluminium about 10 years ago. It pulls SS, Monel and Al rivets without a murmur. As an earlier poster said I just make sure I have the correct nozzle size fitted. Link to post Share on other sites
BNG 54 Posted February 2, 2016 Share Posted February 2, 2016 The concertina type ones are a serious finger chopper if you don't grip them correctly. Many a nasty injury from those in inexperienced hands. Link to post Share on other sites
John B 116 Posted February 2, 2016 Share Posted February 2, 2016 how about HR003 HIT LONG ARM RIVET TOOL description..A heavy duty rivetting tool with long arms for extra leverage - accepts 3mm 4mm 5mm aluminium and steel rivets http://www.toolware.co.nz/results.php?pageNum_rsCWResults=2&category=22 or these http://mytools.co.nz/collections/hand-tools-clamping/riveting No no no . don't get a lever arm unit for masts. I did. This is what happens . You go up the mast with your bucket of stuff yer fitting and yer rivet gun. You drill the holes and put yer tefgel in , balance the fitting or tie or tape it in place for the first rivet all good so far. Then you get your rivet gun out and attempt to rivet the fitting in , only , you have to use two hands for that type of gun. Two or one plus something else. See where I'm going with this? If you're a rigger and used to swinging from trees on a belt all good. Normal people want to pressure treat the extrusion with their knees, grip the spreaders/ halyard/ whatever with one hand so hard moisture comes out of it and use ONE hand to operate the tool/ rivet gun in this case. I am a normal person , therefore I chose one hand for one handle and various other bits for the other. Shoulder , sorta works but permanently removes rotator cuff. Head , yep, works but needs a trip to the dentist after the reverberation when the rivet pops. Lets not talk about the groin. Get a one handed rivet tool. Link to post Share on other sites
Straight Laced 18 Posted February 3, 2016 Share Posted February 3, 2016 Can't help on what type, but in my experience even the most expensive guns get a squeaky voice if you punish them with Monel Rivets continually. When you think of the mechanics of how a rivet gun works, you almost need jaws made of Kryptonite to be able to lock on to a little round rod and pull it till it snaps and not eventually take the edge off the teeth, or break. I used to treat rivet guns as replaceable items until aluminium rivets became more popular. Link to post Share on other sites
harrytom 698 Posted February 3, 2016 Share Posted February 3, 2016 i use the concertina type (lazy tongs)can be used one handed,as before right tip for rivet,never had a issue using alloy/ss/monel. 2 hands are best,hold base and push with other hand,just keep fingers/thumbs out of way Link to post Share on other sites
wheels 544 Posted February 3, 2016 Share Posted February 3, 2016 If you want quality, go see Rivtec. They have 13 hand models to choose from.For you Rigging guys, you should seriously consider one of these.http://www.rivtec.co.nz/tools-and-nose-assemblies/cordless-battery-riveter/42-gesipa-accubird-battery-operated-rivet-toolI used to have an air operated version and it was fantastic. Pull the trigger and in one stroke the rivet was done. But air is not an easy option when up a mast of course. Link to post Share on other sites
ynot 60 Posted February 4, 2016 Share Posted February 4, 2016 We have 7 of the gesipa ones.. These things are reliable and very sturdy.... Dropped one from ten meters up once and it survived. The boys drop them every bloody day...but that's another story. Can't speak highly enough of them. Expensive though Get the dark blue one for heavier stuff... Like stainless etc. A little slower but not by much. Link to post Share on other sites
wheels 544 Posted February 4, 2016 Share Posted February 4, 2016 Haha, yeah don't be up a mast when you take a call from the rep and he gives you the price. You most definitely need to be sitting down. Link to post Share on other sites
