chippie 6 Posted September 10, 2016 Share Posted September 10, 2016 We're thinking of getting a longer kite pole and the guy at the front end keeps nagging for a carbon one. The one we've got is an alloy 5m and we're thinking of a carbon 6m but it would be a bit harder to stow on deck and avoid all the other bits. I remember that in our Piedy days (long ago now) we used to stow the pole along the boom in couple of brackets leaving the topping lift attached during the race. Our boom's long enough to take the longer pole (although it's a bit higher off the deck than the piedy one was) and wondering if I'm nuts thinking it would work in a scaled up version. Or does anyone currently do it? Quote Link to post Share on other sites
Frickie 9 Posted September 10, 2016 Share Posted September 10, 2016 Still the way we do it on my Ross 930. Quote Link to post Share on other sites
Addem 95 Posted September 10, 2016 Share Posted September 10, 2016 Did it on our callenge 29. Used a 180mm plastic drainage tube lashed to the boom. Quick and easy to stow the pole. Looking at doing it on Elliott 10.5. Which has a long carbon pole. Quote Link to post Share on other sites
chippie 6 Posted September 11, 2016 Author Share Posted September 11, 2016 Thanks for that, might give it a try. Quote Link to post Share on other sites
raz88 96 Posted September 11, 2016 Share Posted September 11, 2016 I've sailed on a young 11 that had this. Handy for keeping the pole out of the way, and didn't seem to be any issues with it being on a larger scale, other than as the bowman pulls it forwards once it's out of the bracket it's easy to drop the back of it and bang the cabin top, which is pretty easy to avoid if you're careful. Quote Link to post Share on other sites
snail 1 Posted September 11, 2016 Share Posted September 11, 2016 We use it as well. Works great. Just check your sail cover is still going to fit with the extra volume. Quote Link to post Share on other sites
chippie 6 Posted September 11, 2016 Author Share Posted September 11, 2016 It's a leisure furl boom so the sail cover is well clear. Now that it sounds like it will not be a problem I'm thinking about the most elegant way to design the stowage. It's got to be practical, easy to use and secure. Thinking the outer end of the boom needs to be some kind of ring or semi enclosed ring and the front an eye to clip the pole end into? I remember the Piedy one used to rattle like hell in big winds! Quote Link to post Share on other sites
snail 1 Posted September 13, 2016 Share Posted September 13, 2016 Ours are just two oversize stainless rings on each side of the boom. 1forward, 1 aft. Spinaker pole sits in the aft ring and is clipped into forward one. Our pole is under 4 metres so the aim at aft ring is usually manageable. Noise hasn't really been an issue, or more to the point, when it gets that rough I'm usually worried about something else - like keeping my lunch down! Quote Link to post Share on other sites
mattm 98 Posted September 13, 2016 Share Posted September 13, 2016 I like this system, always used it in trailer boats, never tried it on a bigger boat. One thing that did bug me on light days was the extra weight on the boom when your trying to open the leach for flow, I took the pole off the boom on light days because we didn't have a boom topper - which would also solve the problem. Quote Link to post Share on other sites
ballystick 72 Posted September 13, 2016 Share Posted September 13, 2016 Storing the pole on the boom lets you leave the topper and downhaul connected which meant for fast deployment and stowing with less tangles and sheet wrapping. Quote Link to post Share on other sites
Battleship 100 Posted September 14, 2016 Share Posted September 14, 2016 Works well on a smaller boat with a lightweight pole, can get the bag up real quick. can sometimes be a bitch getting it back in on the end of the boom and can also hook up on runners if you have them. Would be interested to hear how it works out on a larger boat, can't remember seeing this on a fully funded race (TP52) boat in the days of poles so there must be a point at which it becomes impractical. Quote Link to post Share on other sites
chippie 6 Posted September 14, 2016 Author Share Posted September 14, 2016 That's exactly what I've been wondering. Will it work on a bigger boat even though I know how well it works on a smaller one. The only tricky thing I remember is trying to get the far end of the pole into the ring on a bumpy day. We're 44ft, anyone doing it on a similar size boat? The kite pole thing I mean. Quote Link to post Share on other sites
chic014 0 Posted September 14, 2016 Share Posted September 14, 2016 Are you talking about storage while racing or when not in use at all? If while racing why not extend the butt end track on the mast down to deck level then the pole sits relatively flush on the deck and the jib can clear it. Quote Link to post Share on other sites
chippie 6 Posted September 14, 2016 Author Share Posted September 14, 2016 Was thinking of both, but that's a good idea for racing. Quote Link to post Share on other sites
Guest 000 Posted September 15, 2016 Share Posted September 15, 2016 You fellers are really smart! My little praam has a 3 metre mast that I think can be used as a headsail booming out pole on the H28 as well. I was wondering where/how to stow it. Under the boom. What a great idea. Thanks. Quote Link to post Share on other sites
Addem 95 Posted September 16, 2016 Share Posted September 16, 2016 . The only tricky thing I remember is trying to get the far end of the pole into the ring on a bumpy day. ? The kite pole thing I mean. That's why we used a plastic tube. One person can slide it in while the topper is taking the weight. No clips required until the end of the day or someone in the cockpit can secure it while the foredeck get on with tidying up. We've got a 4m pole. Quote Link to post Share on other sites
