Dave 11 Posted December 16, 2020 Share Posted December 16, 2020 I tend to agree Tamure, I had hoped that it would have been a bit of a "silver bullet" in the war on fouling, but realise now that its probably not quite there for the majority of prospective users. By that I mean that to get the benefit out of the wrap I think you'll have to be pretty stringent on maintenance if you're not using the boat regularly. Leaving it as I did for so long was asking for trouble so have only myself to blame. From a cost perspective the wrap was around $4.5k, as well as probably $2k for the hull prep and paint. The product is warrantied for 5 years so for me it will ideally cost $1300 per year over it's life, still dearer than hauling and antifouling but it 'should' be a bit less hassle, we'll see about that. I reckon it will be a good solution for launches that are used reasonably regularly, with the added bonus of fuel savings for them due to the claimed drag reduction of the silicon. I'm interested in how your mate gets on, there's also a couple of power boats that have been done at Stillwater so when I run into them (not literally!) I'll see how they're getting on. Quote Link to post Share on other sites
Fish 0 Posted December 16, 2020 Share Posted December 16, 2020 I've ordered some of this silicon wrap to go on my prop shaft (yacht). We don't haul out, as we have copper coat. The prop speed has warn off, and I'm wanting something I can apply between tides. Should be an easy option to try, and not much to loose if it doesn't work. Even if we don't go out often enough, I do tend to give the engine a run and spin the prop every two weeks or so on the mooring, so hoping it will stay clean. Randomly, I think the fouling on the shaft is damaging my cutless bearing - the growth on the shaft is blocking the water flow through the bearing. Historically I've been getting through cutless bearings faster than I should, which I put down to an alignment and vibration problem. Now we've got a new engine, the only vibration is from the cutless bearing... Quote Link to post Share on other sites
Black Panther 1,776 Posted December 16, 2020 Share Posted December 16, 2020 Interesting. I would try that for prop and shaft. Using lanolin at present. Quote Link to post Share on other sites
Clipper 375 Posted December 16, 2020 Share Posted December 16, 2020 How often so you apply lanolin? My propspeed is had it now. You apply it with a rag in the water?? Quote Link to post Share on other sites
Black Panther 1,776 Posted December 16, 2020 Share Posted December 16, 2020 Rag in water. About every 4 to 6 weeks. Let it go over winter coz I'm a pussy. Had to scrape clean and start again. Quote Link to post Share on other sites
Dave 11 Posted December 17, 2020 Share Posted December 17, 2020 Might work, I seem to recall that there's a top speed for the wrap above which it's not recommended, the guys at MPS will tell you I'm sure. I don't know what the relative 'boat speed' of a propshaft is at revs but I guess you could work it out algebraically. I hope it goes well for you. Quote Link to post Share on other sites
LBD 186 Posted August 21, 2024 Share Posted August 21, 2024 Is anyone using Hempel Globic 9000?... how is it performing? Quote Link to post Share on other sites
CarpeDiem 538 Posted August 22, 2024 Share Posted August 22, 2024 1 hour ago, LBD said: Is anyone using Hempel Globic 9000?... how is it performing? For a bit of thread drift, we have International Ultra 2 - currently into it's third year and according to my diver just starting to go patchy around the waterline, which is caused by oil and diesel in the marina, but it is otherwise fine... At this rate I will need to slip the boat just to change the anodes!! Quote Link to post Share on other sites
mcp 36 Posted August 22, 2024 Share Posted August 22, 2024 18 hours ago, CarpeDiem said: For a bit of thread drift, we have International Ultra 2 - currently into it's third year and according to my diver just starting to go patchy around the waterline, which is caused by oil and diesel in the marina, but it is otherwise fine... At this rate I will need to slip the boat just to change the anodes!! How often are you getting the diver to clean the hull? Quote Link to post Share on other sites
CarpeDiem 538 Posted August 22, 2024 Share Posted August 22, 2024 43 minutes ago, mcp said: How often are you getting the diver to clean the hull? It's not consistent but we probably get it done every 3-4 weeks on average... Quote Link to post Share on other sites
