rossd 16 Posted December 1, 2020 Share Posted December 1, 2020 This would be no big deal for a lot of you guys but for me my biggest trip as skipper. quote from my facebook page for non boaties so bare with me: “Big thankyou and gratitude to my crew James and Shae, couldn’t have done it without them. For example ,the Raglan bar was no problem,not even breaking, then the wind got up higher than forecast and sea built up and I was seasick . Eventually Shae made a correct call too take down the genoa and put up a smaller jib. I was still capable of steering at that point so pointed into wind and waves while Shae and James went forward. I had rigged 2 jack lines from the cockpit forward around the mast to the anchor bollard to clip onto. So with short metre long tethers its “impossible” to go over the side. With the bow rising and falling at least 2 metres you cannot really stand up so have to kneel,sit or otherwise stay low. James told me later that at one point Shae was thrown on his back and didn’t bother getting up but clawed the sail down from there. Eventually the smaller sail was hoisted and the action of Mahoe was somewhat tamed. The same couldn’t be said for my stomach! I had been dry reaching for some time, was getting weak and couldn’t help at all. The crew decided after I had been sick for 24 hours I needed to be put ashore to recover, easier said than done. We were nearing Kaipara harbour entrance by now so Shae radioed coastguard and after some discussion back and forth they basically refused us entry. They suggested Hokianga harbour as a possibility. We pressed on , up to now even a sip of water would come straight out again. So was rather excited when water stayed down and I started eating. Nearing Hokianga entrance I was eating like a horse so Shae radioed coastguard to tell them we were all good and carrying on. So your work much appreciated Shae and James.As we neared Cape Reinga we were greeted with this so all was forgotten!” 2 Quote Link to post Share on other sites
rossd 16 Posted December 1, 2020 Author Share Posted December 1, 2020 We motored from North Cape to Mangonui incalm seas so Shae could get a bus home for work. James and I carried on day sailing. Stops at Cavalli Is. Bland bay, Tutukaka, Omaha, Tryphena, Whitianga, Waihi Beach, and then this” After Mahoe did a sterling job in allconditions and a last day from Waihi beach to Whakatane , within 10 miles of home there was a clunk from the driveline and viabration. Towed in by the Coastguard at 2 am. On temporary swing mooring in Whakatane river. Quote Link to post Share on other sites
rossd 16 Posted December 1, 2020 Author Share Posted December 1, 2020 Found out why we lost momentum on Mahoe and had to be towed into Whakatane. A small bouy and rope wrapped around the propeller. Quote Link to post Share on other sites
DrWatson 375 Posted December 1, 2020 Share Posted December 1, 2020 15 hours ago, rossd said: Found out why we lost momentum on Mahoe and had to be towed into Whakatane. A small bouy and rope wrapped around the propeller. Did you call the number? Quote Link to post Share on other sites
DrWatson 375 Posted December 1, 2020 Share Posted December 1, 2020 Just now, DrWatson said: Did you call the number? also, rags to whaka is not exactly a Sunday cake walk... good effort. Quote Link to post Share on other sites
Bad Kitty 252 Posted December 1, 2020 Share Posted December 1, 2020 Yes good stuff, not a trip to be taken lightly, that West Coast has tripped up a lot of boaties over the years. Quote Link to post Share on other sites
Steve Pope 243 Posted December 1, 2020 Share Posted December 1, 2020 Did the Kaipara coast guard give a reason for refusing you entry? Was it for just the southern channel or the Northern one as well? Great effort, a feather in yours and your crews caps. It is an interesting piece of the west coast, Besides the Hokianga, Whangape harbour is also accessable, given a rising tide and -1m swell. "Sealegs" work for me until I do get my sea legs, no noticeable side affects. Quote Link to post Share on other sites
Island Time 1,235 Posted December 1, 2020 Share Posted December 1, 2020 The coast guard have no Legal Status. They can only advise. A harbourmaster can close a port. However, if you go against the advice of either, then have an issue, its unlikely to go well for you in the courts! Well done, the NZ coast, esp the W coast or south of Napier/New Plymouth, is not to be taken lightly. Drugs for the first few days to combat seasickness is pretty common - BEFORE you leave, so they have time to work and are not vomited out immediately! Sealegs can make some sleepy, there are lot's of options. Quote Link to post Share on other sites
Black Panther 1,586 Posted December 1, 2020 Share Posted December 1, 2020 For some reason I get a real kick out of stories like this. Well done Quote Link to post Share on other sites
rossd 16 Posted December 2, 2020 Author Share Posted December 2, 2020 10 hours ago, DrWatson said: Did you call the number? Yes called the number. A temperature sensor, evidently monitoring a marine heatwave thats coming. Double boeys so maybe not destroyed. Was surprised at the sheer number of boeys around the coast. Can understand fishing nets cray pots etc. But all the others. There was just a mass of them in the marine reserve at Leigh. I probably could have been further off shore , was at about the 20 metre depth line at the time. 9 hours ago, Steve Pope said: Did the Kaipara coast guard give a reason for refusing you entry? Was it for just the southern channel or the Northern one as well? Great effort, a feather in yours and your crews caps. It is an interesting piece of the west coast, Besides the Hokianga, Whangape harbour is also accessable, given a rising tide and -1m swell. "Sealegs" work for me until I do get my sea legs, no noticeable side affects. I think the last straw for them was when they asked max speed under motor. 5 knots didnt cut it! Didnt get to discussing channels 9 hours ago, Island Time said: The coast guard have no Legal Status. They can only advise. A harbourmaster can close a port. However, if you go against the advice of either, then have an issue, its unlikely to go well for you in the courts! Well done, the NZ coast, esp the W coast or south of Napier/New Plymouth, is not to be taken lightly. Drugs for the first few days to combat seasickness is pretty common - BEFORE you leave, so they have time to work and are not vomited out immediately! Sealegs can make some sleepy, there are lot's of options. They advised not to attempt it and if we did , we would do so at our own risk, I thought that an odd comment as I consider all my boating totally at my own risk. Then again I suppose if they are talking someone through a situation they are taking on some responsibility Quote Link to post Share on other sites
Sail Rock 28 Posted December 4, 2020 Share Posted December 4, 2020 Great story, thank you for sharing. (I don’t think I would attempt any of the west coast harbour entrances without someone with excellent local knowledge on board!) Quote Link to post Share on other sites
rossd 16 Posted December 4, 2020 Author Share Posted December 4, 2020 50 minutes ago, Sail Rock said: Great story, thank you for sharing. (I don’t think I would attempt any of the west coast harbour entrances without someone with excellent local knowledge on board!) At least Raglan has leading lights. Years ago i went on a bar day wirh the Coastguard, well worth it, but was so calm I could have rowed the tender over it. Quote Link to post Share on other sites
harrytom 642 Posted December 5, 2020 Share Posted December 5, 2020 On 4/12/2020 at 3:11 PM, rossd said: At least Raglan has leading lights. Years ago i went on a bar day wirh the Coastguard, well worth it, but was so calm I could have rowed the tender over it. Thank you enjoyed the read. Have only crossed the Manukau Bar once in a fizz boat. On way out no issues, coming in.1/2 tide dropping sw 10knts.Hmm thought much rather enter Tutukaka in a 20knt easterly. No desire to venture across a bar again. Was in a 6m ali with 150hp and wave/swell still pushing us side ways. Can see why C/G maybe concerned at 5knts. Quote Link to post Share on other sites
