aardvarkash10 1,139 Posted February 25, 2021 Author Share Posted February 25, 2021 Garnet-blasting happening on Saturday. I may video and post here so others can see the process and outcome... Quote Link to post Share on other sites
Vivaldi 57 Posted February 26, 2021 Share Posted February 26, 2021 This was the information given to me by the Altex paint rep on scraping or sodablasting back to the gel coat: If the scrapping method of removal is chosen and once all of the old antifouling has been removed it will leave a shiney finish on the grey primer undercoat, this must be removed , and we recommend machine sanding with 80 grit dry paper. This will remove the shine and yield a coarse surface texture for the new paint system to adhere. · Once the sanding is complete, remove all of the sanding dust, a wipe over with a damp cloth that has been dampened with fresh clean water. Wipe down so the surface is dust free and then allow to dry. · If any hull damage has occurred from the scrapper, or there is damage from other means spot fill these areas with two pack Epoxy filler, allow to cure over night, then sand flush with the surrounding surface and again dust off. · Once all of the surface preparation is complete, and the existing grey primer / undercoat has no adhesion issues, proceed with the mew paint system application. Mask along the water line with plastic masking tape if working outside. · Then by roller apply one full coat of No 1 epoxy primer mixed 4 to 1 with its converter, once mixed up to 5 % No 12 thinner can be added to aid roller application. The practical coverage rate is approx 4.3 M 2 per mixed litre. Brush will be required to gain access in some locations, EG, skin fitting internals etc. · As soon as you can leave a thumb print in the No 1 epoxy primer ( 1 to 2 hours ) apply the first of two coats of No 5 Ablative Copper based antifouling colour Sea Green again by roller at 4.5 M 2 per litre per coat. Up to 5 % No 12 thinner can used in hot weather. · Allow the first coat of No 5 antifouling to dry overnight or longer, before appling the second coat at the same coverage rate. We suggest a third coat is applied to the Rudder, Keel, down the stem , around the waterline down about 350 to 400 mm and above the propeller. · A small brush will be need to apply the antifouling inside the skin fittings and other areas where a roller is unable to be used. Continue to stir the can to keep the ingredients in suspension. 180 to 200 microns of dry antifouling film build is required. · Once the new paint system has been applied allow at least 24 to 48 hours drying so the paint film dries hard and solvent free, this yields the best antifouling performance. hope that helps. We took the Carpenter 29 back with Skoda blasting - worked really well. cheers Paul 1 Quote Link to post Share on other sites
Vivaldi 57 Posted February 27, 2021 Share Posted February 27, 2021 14 hours ago, KM... said: How many Skodas did it take and did the dealer do you a deal? It must have been damn handy being able to drive that medium to the site considering you'd not get many in your boot Ha!😀 yeah - good old predictive text..... most Skodas should be blasted though - along with the Suzuki swift’s, Demeos,and the Kia police 👍 - buts another thread I think 1 Quote Link to post Share on other sites
Black Panther 1,776 Posted February 27, 2021 Share Posted February 27, 2021 My wife drives a Suzuki Swift, so wondering exactly what is wrong with it?,? 1 Quote Link to post Share on other sites
Island Time 1,313 Posted February 28, 2021 Share Posted February 28, 2021 2 hours ago, Black Panther said: My wife drives a Suzuki Swift, so wondering exactly what is wrong with it?,? Nothing. Great little car. Quote Link to post Share on other sites
Vivaldi 57 Posted February 28, 2021 Share Posted February 28, 2021 3 hours ago, Black Panther said: My wife drives a Suzuki Swift, so wondering exactly what is wrong with it?,? No offence intended. It’s just a bit of a joke I have calling them Suzuki police or Kia police as they are often driving down the Hutt highway side by side at 90k with a big line of cars behind them. Making sure everyone is obeying the law. Quote Link to post Share on other sites
Black Panther 1,776 Posted February 28, 2021 Share Posted February 28, 2021 4 hours ago, Vivaldi said: No offence intended. It’s just a bit of a joke I have calling them Suzuki police or Kia police as they are often driving down the Hutt highway side by side at 90k with a big line of cars behind them. Making sure everyone is obeying the law. So you know my wife? 1 1 Quote Link to post Share on other sites
aardvarkash10 1,139 Posted March 6, 2021 Author Share Posted March 6, 2021 mechanical sanding vastly improved by the use of a near-disposable drywall sander. Ozito is Bunnings house brand of cheap nasty power tools, but at only $159 retail this 225mm random orbital drywall sander is great for this purpose. It has built in dust extraction so you dont need a big workshop vacuum and much to my surprise this feature worked fine. It comes with a pack of shitty cheap velcro discs in almost entirely the wrong grit range (150 to 400) but getting 80 and 120 grit discs isn't a problem. You wouldnt want to put it to a professional work program, but for this one-off (and the bonus that I got it at a large discount off a certain buy/sell website familiar to NZ residents) its fine. I reckon it will do two or three more before it lets all its smoke out. Quote Link to post Share on other sites
aardvarkash10 1,139 Posted April 27, 2021 Author Share Posted April 27, 2021 Very late follow up. Prior to the Great Bum Polish, Stepping Out struggled to get to 5kt flat out under motor. Now we get 6kt @ 2000rpm easy. Same differential under sail. Maybe it was worth it! Quote Link to post Share on other sites
Black Panther 1,776 Posted April 27, 2021 Share Posted April 27, 2021 Same here. Clean bum 6.5kn, dirty bum 5kn. Same revs. 1 Quote Link to post Share on other sites
aardvarkash10 1,139 Posted April 27, 2021 Author Share Posted April 27, 2021 Must be a Spencer performance specification...😁 Quote Link to post Share on other sites
aardvarkash10 1,139 Posted May 1, 2021 Author Share Posted May 1, 2021 7 hours ago, lateral said: Where did you get the 225mm discs from? Bunnings Quote Link to post Share on other sites
grayw 1 Posted May 9, 2021 Share Posted May 9, 2021 For what its worth.. I have just had my boat out at the landing for 2 weeks . Had coppercoat but after much deliberation I sanded it mostly off, applied 2 coats of primacon and 2 coats of grey warpaint. Boat looks great for now. See how Warpaint performs in OBC. The coppercoat was 10 years old but in the last 3 years I was cleaning it 2-4 weekly. Never seemed to get it really clean. Quote Link to post Share on other sites
