Changed 10 Posted September 10, 2012 Share Posted September 10, 2012 I would like to add a little more sweep to the spreaders on my boat, so we can run the rig without runners, and to get rid of the jumpers by going to a cathedral configuration. All on the existing alloy rig. Who is the best to advise and complete this work arounf Westhaven. I really miss the advice and guidence that was given so freely. Link to post Share on other sites
lebleaux 8 Posted September 10, 2012 Share Posted September 10, 2012 We recently did something similar to Urban Cowboy - moved the mast a little, decreased the rake, changed the spreader angles and converted to a cathedral configuration. The work was managed by Grant Jenkin, who I can not recommend highly enough. Grant organised the engineering (loads, lengths, calcs etc) and then did much of the work. You can contact him on 027-4931682. You are also welcome to have a look at Urban if that will help. By the way - I understand the attraction, but I would keep the runners. Link to post Share on other sites
col j 0 Posted September 10, 2012 Share Posted September 10, 2012 we want runners on the 727, damn near need checks after seeing it dance last weekend. in all honesty, i dont think you could go without the runners. could maybe get away without the checks if you put alot of sweep in the spreaders/move the chain plates. your section is very small and when i sailed with you the amount the rig was pumping with runners/checks i think your thinking is rather wishful. Link to post Share on other sites
203 0 Posted September 10, 2012 Share Posted September 10, 2012 Id be keeping the runners.... Just my opinion though.. Link to post Share on other sites
Kiteroa 8 Posted September 10, 2012 Share Posted September 10, 2012 Just going by the amount of luff curve in that www.Crew.org main I borrowed from you has, I would say your rig may be a bit soft to do without the runners. But by all means get the calcs done and see. I'd think you will need stiffening though. Link to post Share on other sites
all fired up 6 Posted September 10, 2012 Share Posted September 10, 2012 The work was managed by Grant Jenkin, who I can not recommend highly enough. Grant organised the engineering (loads, lengths, calcs etc) and then did much of the work. You can contact him on 027-4931682. I would also recommend Grant. He did a considerable amount of work on the cathedral rig of my 930 and as a result she is performing much better. You are welcome to come down the boat and have a look any time. a.f.u Link to post Share on other sites
Zoe 8 Posted September 10, 2012 Share Posted September 10, 2012 Grant Jenkins, definitely Link to post Share on other sites
Guest Posted September 10, 2012 Share Posted September 10, 2012 http://www.kiwirigging.co.nz/ Link to post Share on other sites
raz88 96 Posted September 11, 2012 Share Posted September 11, 2012 I've had rigging work done for me in Westhaven by Bart at nzrigging.com Found him good to deal with, and got what I needed done on time and at a sharp price. Link to post Share on other sites
Guest Posted September 11, 2012 Share Posted September 11, 2012 Happy to Have a Look and give you some advice, Give me a call on 480 8090 to arrange a time Link to post Share on other sites
Wannabe 0 Posted September 12, 2012 Share Posted September 12, 2012 Steve Ashley is another option for you, and can be found loitering around Westhaven. Never met him personally, but have heard the boss speak well of him. Email steve@riggingshop.co.nz Phone Business 09 309 6519 Mobile 027 477 7969 http://www.riggingshop.co.nz/ Link to post Share on other sites
Changed 10 Posted September 12, 2012 Author Share Posted September 12, 2012 Thanks for all of the advice and information. Can anyone tell me what spreader angle I need to achieve to get the mast to stand up without the fear of it falling over the bow without a runner? It does have a m/h backstay. Link to post Share on other sites
Guest Posted September 12, 2012 Share Posted September 12, 2012 And remember Bart (NZR ) advertises on Crew.org.nz!!! Link to post Share on other sites
Guest Posted September 12, 2012 Share Posted September 12, 2012 You going to move your chain-plates as well? Sounding major but I know you arent scared of a few mods. Whats up with the runners? They can be fiddly but with a tricky dicky bungy setup they get out of the way pretty quick, I did it on Black Fun and then on Energy when I put the top-mast runners on. Works a treat. Happy to help you on that one - half hour job at most. I still have your orange pennant BTW, I'll drop in next time I'm out on X. Link to post Share on other sites
Changed 10 Posted September 12, 2012 Author Share Posted September 12, 2012 Have all of the tricky bungy mods and course and fine adjustments. I preferred the SR setup where they were there but we only used them when it was up the range or we using a frac gennie. Moving chainplates is not a big deal really (I think). Link to post Share on other sites
Guest Posted September 12, 2012 Share Posted September 12, 2012 24degrees for the spreaders seems to work with a stiff carbon rig Link to post Share on other sites
Kiteroa 8 Posted September 12, 2012 Share Posted September 12, 2012 We're running 22 degrees with a bend around 0.7% of P. That's a very light very stiff HM carbon rig but we still need the runners if we want height on the wind. It's not going to fall over though. Link to post Share on other sites
TimW 1 Posted September 12, 2012 Share Posted September 12, 2012 I don't know Cool Change well enough to comment on the correct spreader angle and I'd suggest it requires a little more research than plucking a number from the air. At Hall Spars we can properly work out what would be required with your existing section. Call me at work if you want to discuss . Tim 09 427 5472. Link to post Share on other sites
Guest Posted September 13, 2012 Share Posted September 13, 2012 Well it Sounds Like Halls is the only place to go to as everyone else is Just plucking Numbers from the air, Just for the record Tim, you guys are not the only ones that can Properly work out the loads etc required. Yourselves , NZ Rigging, Southerns all have different design software that is used. Link to post Share on other sites
Marshy 30 Posted September 13, 2012 Share Posted September 13, 2012 Not sure the mast section in Cool change would handle the extra compression from the raked spreaders enough to go runnerless. Might be more like the Young 11's where it needs runners but there is a bit more security in there with the spreaders raked aft. But its certainly going to take a bit to get the rig to stand on its own. Its pretty skinny. And the same size tube on the SR's is pushing it! Any of the contacts mentioned here would be able to do the job. and being ex the industry im not going to reccommend anyone or i will get crucified by the others!, but all are capable and have the gear to work it out. Just be warned that the mast in there now might not be grunty enough to take it on. Marshy Link to post Share on other sites
