Solenoid operated gas regulators
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
A lectronic solenoid is a 'want' not a 'need'. There is no requirement to have one.
The gas dude I spoke to prior to making my final call and while trying to find a SS one, said many leak and many do not full close. He also said  many of the new ones are built too much to a price. Clipper seems to have found some.
A club member who is very mechanically competent and is currently preparing for some extended offshore sailing has taken the LPG off his boat completely and replaced with kerosene. He spent a lot of money getting a top shelf kero stove, imported from the UK.
Hi logic was that the residual risk with LPG is always present, and the consequence of an undetected leak is, well, fatal, generally.
It's also a hell of a lot easier getting kero in remote places than LPG, with the right bottles, fittings, certifications etc
Reading this thread, I'm starting to see his point. We've been planning on installing a solenoid islolator but haven't gotten aroundtoit...
Not sure if I will now.
Just been away for three weeks and had the gas sensor go off a couple of times.  Checked everything with the soapy water method and every connection was fine.  (not many connections because we only run the stove off the cylinder).  Almost accidentally dripped some of the soap solution on the actual solenoid casing and saw bubbles coming from both the top and bottom of the casing.  Took the regulator off and replaced it with our spare non solenoid operated regulator, carefully tested and everything fine.
I'm bit perturbed by this.  The solenoid operated regulator is only about six months old and the bracket that holds the solenoid is already showing corrosion.  The whole installation is in a weatherproof box.  This is a particular concern because the gas must have been leaking through the solenoid throughout the whole trip.  We turn the gas bottle on at the beginning of the trip and religiously turn the valve off at the stove after use but leave the sensor on at all times while we're away.  In this case, the gas must have been leaking out irrespective of us turning off the solenoid.
Two questions.  Has anyone else had a similar problem?  And secondly, where can you buy a truly marine grade solenoid operated regulator?  I've googled, but not come up with anything in NZ.
If I understand this correctly , there's 2 issues going on . One is your sensor is activating the alarm. The other is that outside and in the venting locker , you have a gas leak which you discovered because of the first. But that leak is not why your sensor triggers the alarm. So you have some more looking to do. I have been on boats where the sensor/ sniffer has died , so I carry a spare one of those. We have had ours go off after cleaning inside the boat , something in the simple green / spray and wipe or whatever sets it off. thats good feedback as far as i'm concerned.
If the sniffer gets wet its compromised too.
Ours was a BEP John, and like Clipper says, a shitty electrogalv bracket which is never going to have a hope in a marine environment.  The one I replaced was also BEP and was about eight years old too.  I thought I was doing the right thing by fitting a new one when the hose was replaced.
Now wondering if I should contact BEP because I don't think it's a minor issue if more people are having problems with them.  You'd never realise there's a leak unless you can smell it or test with the soap solution.  Well there's the big bang method I suppose.
Where do you guys get your alarms from and what type are they?
Burnsco only offer a hard wired one, and it wasn't cheap.
I was after one like a smoke alarm that takes 9v batteries or the like. I don't want to shag around hard-wiring a CO alarm.
I have had 2 BEP LPG solenoids in the 30 years since I splashed my 88. The first lasted 15 years until the wiring to the coil corroded out. The second one has been on the boat for 10 years. I was down the boat yesterday and decided to test it out for leakage. None and there was no corrosion/rust on the bracket. The gas bottle and valve is in the port aft locker which spent quite few years with no locker door on and now only has a piece of Sunbrella fabric velcroed across it so hardly watertight.
As I said earlier take it back to where you bought it from and if possible show them video or pic of the solenoid bubbling/frothing.
