vic008 17 Posted May 17, 2020 Share Posted May 17, 2020 Turning herself off for say 15m, then after about another 15m, turning back on. Power supply good and plugged in hard. Everything works good otherwise. Internal battery? Quote Link to post Share on other sites
Island Time 1,246 Posted May 17, 2020 Share Posted May 17, 2020 Internal batt wont do that. Itll be power, but possibly internal. How do you know "power is good"? Youd need to be watching it with a meter at the moment of switch off, or logging it continuously to be certain. Quote Link to post Share on other sites
vic008 17 Posted May 17, 2020 Author Share Posted May 17, 2020 Thanks, multimeter says she is getting power. Quote Link to post Share on other sites
Luigi Vercotti 7 Posted May 17, 2020 Share Posted May 17, 2020 If it's still getting power while it's dead, have you tried cycling the power to see if it comes back up, or still waits 15mins? If you have to wait, it may be something overheating and needs the time to cool. Quote Link to post Share on other sites
Island Time 1,246 Posted May 18, 2020 Share Posted May 18, 2020 3 hours ago, vic008 said: Thanks, multimeter says she is getting power. It does not take much of a voltage drop to make it turn off. A scope will tell you, a multimeter may not. Does the unit stay off while good power seems available? If so, as above, heat could be an issue. Quote Link to post Share on other sites
Fish 0 Posted May 18, 2020 Share Posted May 18, 2020 We've got a Navman 5500 sounder / fish finder that is causing issues, the depth jumps from the actual depth to a random shallow number and back, inconsistently but repeatedly. Very alarming seeing a very shallow depth flash up, until you get used to it. We think the transducer coil has shat itself and need a new transducer. It is 'of an age'. Does that sound like the likely issue for mine, and could it explain Vic's problem, screen stays 'on', just random or no numbers. Quote Link to post Share on other sites
Fogg 427 Posted May 18, 2020 Share Posted May 18, 2020 Does shutdown coincide with using another appliance on boat eg fridge or water pump? My navman used to shutdown every time I started the engine. Quote Link to post Share on other sites
vic008 17 Posted May 18, 2020 Author Share Posted May 18, 2020 No, overnight it will turn off. Its unresponsive when off, but pull her power supply out,then plug her in again, and she fires up. Strange. Quote Link to post Share on other sites
wheels 543 Posted May 18, 2020 Share Posted May 18, 2020 The reason it starts back up again when the power is re supplied is due to a yellow wire (I think it was yellow) being connected to the Red power wire. This bypasses the panel switch so as the unit powers up as soon as an eternal switch/breaker is turned on. That does not solve the problem of it turning off on it's own though. I imagine there is a cold solder joint internally. To be honest, I doubt it is worth repairing. Fish, your unit has possibly got fouling on it's surface. The weaker signal bounces off the Keel and it gets a false shallow reading. Too much AF paint can also do it. Quote Link to post Share on other sites
Luigi Vercotti 7 Posted May 18, 2020 Share Posted May 18, 2020 It looks like power supply quality, as IT suggested. Sometimes, when the voltage drops very slowly to a point below the digital electronics logic thresholds, they will lock up. Similarly with a quick dip. Can you connect it to a known good battery, on its own, and see how it holds up? Quote Link to post Share on other sites
Fish 0 Posted May 18, 2020 Share Posted May 18, 2020 36 minutes ago, wheels said: Fish, your unit has possibly got fouling on it's surface. The weaker signal bounces off the Keel and it gets a false shallow reading. Too much AF paint can also do it. Thanks Wheels, we did check that, no AF on the transducer itself. It did have barnacles on it, we were happy we thought we had fixed it - it made no difference at all... Is it a thing that the transducer coils can get old and short / fail? The gear is fairly old. It was the first new lectronic item we installed on the boat, and we've had it for 20 yrs, so it is in the order of 18-20 yrs old now. Quote Link to post Share on other sites
wheels 543 Posted May 18, 2020 Share Posted May 18, 2020 I cant say never when it comes to lectronics and that fellow Murphy. But it is not a common way for them to go. Normally it is go or no go. However, if you had no AF coating on it, then growth could once again be an issue. It only takes a week or so for any clear realestate to be snapped up by those marine invaders. You do need to put some kind of coating on the transducer. Just ensure old is removed before new applied so it does not get too thick. Quote Link to post Share on other sites
Jon 360 Posted May 18, 2020 Share Posted May 18, 2020 IMHO You have got twice the design life out of this unit. The easiest fix will be replacement Quote Link to post Share on other sites
Fish 0 Posted May 18, 2020 Share Posted May 18, 2020 1 hour ago, Jon said: IMHO You have got twice the design life out of this unit. The easiest fix will be replacement Agree Jon, its just a pain in the arse drying the boat out for long enough to swap the transducers (Coppercoat, so we don't haul out ever, just clean between tides and change anodes, service prop), and the general time and boat money involved. We already have a Garmin plotter on an NMEA2k system so just need the transducer. It did give me thought to just not use a sounder. The only time I really need one is anchoring, to know how much chain put out. All the times I've hit things or run aground, the sounder was no use anyway. Sounds don't warn of rocks that leap out infront of you... I understand the mark 1 lead line never needs firmware upgrades either... Quote Link to post Share on other sites
Jon 360 Posted May 19, 2020 Share Posted May 19, 2020 I hate them sneaky rocks that do that. 1 Quote Link to post Share on other sites
wheels 543 Posted May 20, 2020 Share Posted May 20, 2020 Not having a sounder is like not wearing your seatbelt. It can also be a navigation aid when coastal cruising. Use can use it to follow depth contours and that helps plot your position on the chart. I hate entering an unknown bay without one. Quote Link to post Share on other sites
Fish 0 Posted May 20, 2020 Share Posted May 20, 2020 15 hours ago, wheels said: Not having a sounder is like not wearing your seatbelt. It can also be a navigation aid when coastal cruising. Use can use it to follow depth contours and that helps plot your position on the chart. I hate entering an unknown bay without one. I don't think so. I would describe it more as driving around with one tail light not working. The driving with no seat belt analogy would probably better fit having no working VHF onboard, IMO. In terms of nav, I've got a chart plotter in the cockpit. I have done blind nav exercises in the past where depth is integral to establishing your position, but it is never required outside of Yachtmaster examinations. I have sufficient compasses to triangulate, and have back up GPS and charts if I have a systems failure. I take your point on entering unkown bays, that is a valuable use of a sounder. But right now I'm not planning on entering unknown bays. I just want to go sailing and enter my regular, well known bays. I do want to replace it, but it is a question of probably $1,000 and 2 or 3 days work (including hauling out), or I could just go sailing and be a bit more cautious. And take a lead line for checking how much chain I need out. in terms of crossing the bar, I can predict the depth as accurately as the sounder can tell me, so that is not an issue. In saying all of that, my sounder is still working, it just flashes intermittently. I can still use it for depth and nav, at the moment. It will stop working all together soon. I just need to carry a lead line as back up I think. Quote Link to post Share on other sites
Island Time 1,246 Posted May 21, 2020 Share Posted May 21, 2020 I cant agree with that fish. Your compasses are not much use for position fixing in poor visibility - like fog, or night (unless to get a bearing on a light). The depth finder is a great source of data to help you check position. Its often an easy way to double check your GPS/plotter position... but locally, in good conditions, your probably fine. The flashing numbers mean the unit has lost the bottom, or its too soft to get a consistent reading. Check all the wiring for pinholes in the insulation (corrosion) , and all connections for tightness and cleanliness. This issue could well be cables or connectors. Most of the new (Throughhull) transducers are 51mm, so if that is the size of the through hull, then a new unit can likely use the same housing. New housings though have the flap that closes when you remove the transducer, so let in lots less water while changing. If you send me a pic of the transducer plug, I may have one in my 2nd hand junk you can try.... New fish finder/depth sounders start at about $600, with a transom mounted skimmer transducer. Quote Link to post Share on other sites
Black Panther 1,600 Posted May 21, 2020 Share Posted May 21, 2020 I think BP is the first boat I've owned with a functioning depth sounder Quote Link to post Share on other sites
Leftred 45 Posted May 23, 2020 Share Posted May 23, 2020 My boat came with the old transducer not working (sold as "it's all good! just needs to be calibrated" which I suspect they knew wasn't true). Someone had glassed over the top of it inside the hull too, so replacement would have been a bit of work. I bought at Garmin Striker 4 and mounted the transom transducer inside my hull, screwed into a frame, and sitting on a bed of silicone. Shoots through 1 inch of kauri without trouble. Tested it first sitting on a plastic bag of water. The display unit is customised to just show depth and GPS speed so it's nice and big and easy to read. A pretty reasonable $300 workaround. 1 Quote Link to post Share on other sites
