Sign in to follow this
category 1 or not
does anyone know the consequences of sailing off shore without Category 1, now don't all jump down my throat it's just a question :wink:
Share this post
pretty much no consequences of sailing offshore as long as you don't stray into another countries waters.
If however you end up in say Oz waters without clearing customs (which as a New Zealand registered vessel you will need a cat1 certificate) you will find yourself in deep sh*t and will probably spend some time in a prison cell.
Share this post
Any country for that matter, because you won't have clearance to leave NZ for another country.
Question, is it not possible to get Cat1?? It's not that difficult really. And most sailors tend to have most things on board already. It's only sailors like Squid that want to sail the Oceans in 4 Kerosene Tins tied together, just like my Great Grandfather did apparently, so I am told.
Share this post
Cat 1 is a big step up Wheels. The most recent post that I remember on the subject was Island Time getting ready for the solo TransTasman race and having to have things like extra lashings in case his engine mounts failed. I have also seen comments in past threads (maybe from Pete Wederell? or someone similar) that the fact that it becomes voided as soon as you reach your destination doesn't add to the appeal.
Share this post
You get Cat 1 for a specific voyage or race. At the end of that voyage/race the boat reverts to Cat 2 automatically, sort of.
If you are a NZ boat it's highly unlikely you'll get Customs Clearance without a Cat 1. No clearance means no entry at the other end or in other words as mentioned above, you could become great mates with a dude called Bubba.
When the NZ Authorities catch up with you there will be more trouble. Knowing NZ I'd say you'll get a serious thrashing with a wet Cat 1 Cert :)
20K would be up there a little I think Squid but I'd budget a number closer to that than I would 1K.
Share this post
20K is close to what we spent but that was starting pretty much from scratch with a weekend sailor and most of the money we spent would have been spent on the same things anyway. The big sticker for us was if we had been forced to get righting curves done but we dodged that little inconvenience OK.
Share this post
Starting from scratch yes. But I doubt most that have seriously cruised in a well found boat, would be anywhere near that kind of cost. Pete's situation was different because that was not the typical crusiing boat and so as he said, they started from scratch.
IT was similar because of the race it was doing. Remember that the inspector has a fair bit of say in what is required and not required outside of the "book" and he makes those decisions based on the situation.
Ummm...I think from past discussions here, that the only safety gear that a few members here would rather not have to have, would be Liferaft, EPIRB, and HF radio. Personally it is just HF radio I would do without, but I would look at an alternative, as I would still want communication. So would you consider cruising without Liferaft and EPIRB?? they would be your really big ticket items that many sailors may not normally have. We have niether ourselves, but am wanting to get an EPIRB when I can afford to.
Apart from maybe being tripped up by stability curves, most all the issues of achieving Cat1 would be how I want my boat to be in normal mode anyway. The reason why Cat1 reverts to Cat 2 is that you have time expiring equipment on board and these need to be checked each time you enter Cat1.... AND, that you have not removed any items just because you obtained Cat1 once. I am sure a few unscrupulous given the oportunity, would borrow a mates Liferaft, pass Cat1 and then return the raft before they set off. Thankfully we don;t have anyone like that here as "crew" members. :wink:
Share this post
