madyottie 82 Posted October 7, 2019 Share Posted October 7, 2019 So, recently I bought an old Noelex 22, and have been slowly beavering away trying to bring it up to scratch. Bought sails, replaced mast, designed rig tension system, put it mostly in position. The rudderblade was barndoor sized, and weighed a ridiculous amount, not to mention having some mild steel packers, which rendered the whole rudder useless and immovable. So anyway... Bought foam, designed blade, cut blank, shaped, added unidirectional strands to stiffen it up, and laid rovings over the top. All with West epoxy. So far so good. Decided to add a further layer of 100mm tape along the leading edge incase I hit things. I realised I was out of hardener, and went to the nearest big box hardware store, and bought 500g of Ados epoxy. Mixed according to directions on the packet, looked ok. Applied to the rudder, and a week later it's still only partially set. I've removed the tape now. Does anyone know how to remove partially set (well, not set at all, but sticking to the West under it) epoxy? I can scrape some of it off, but turps does nothing. The crap epoxy sticks to everything it comes into contact with. It just doesn't go hard. doesn't respond well to sandpaper, I seem to be removing the good stuff while the crap just clogs the paper. Any ideas gratefully received. Quote Link to post Share on other sites
Brien 22 Posted October 7, 2019 Share Posted October 7, 2019 Try vinegar. It removes epoxy from hands so might work. If you try it let us know how it goes. Quote Link to post Share on other sites
madyottie 82 Posted October 7, 2019 Author Share Posted October 7, 2019 Tried the heat gun earlier, heat doesn't differentiate between set and not set???? Quote Link to post Share on other sites
Clipper 358 Posted October 7, 2019 Share Posted October 7, 2019 Acetone? 1 Quote Link to post Share on other sites
madyottie 82 Posted October 7, 2019 Author Share Posted October 7, 2019 Vinegar could be the secret, I'll give that a crack tomorrow Quote Link to post Share on other sites
Island Time 1,278 Posted October 7, 2019 Share Posted October 7, 2019 Epoxy thinners will remove what isn't set... Quote Link to post Share on other sites
wheels 543 Posted October 7, 2019 Share Posted October 7, 2019 Epoxy Thinners.NEVER mix different brand products. The hardener is made to exactly match the Resin.Also, be very careful heating uncured Epoxy. The smoke fumes are terribly toxic and can make you very ill and so sensitized to Epoxies, you will never be able to go near it again. Quote Link to post Share on other sites
madyottie 82 Posted October 8, 2019 Author Share Posted October 8, 2019 As a thought, if I were to bush hardener over the unset stuff, would it harden? Or even harden enough to sand/mechanically remove? Although if it didn't harden in correct ratios, it probably never will. Wheels, I wasn't mixing products, this was a fresh layer Quote Link to post Share on other sites
Frank 157 Posted October 8, 2019 Share Posted October 8, 2019 As a thought, if I were to bush hardener over the unset stuff, would it harden? Or even harden enough to sand/mechanically remove? Although if it didn't harden in correct ratios, it probably never will. Wheels, I wasn't mixing products, this was a fresh layer Brushing the hardener probably wont help, it is not like the catalyst for polyester, try a strong solvent like acetone or paint thinners and scrub with a coarse steelo pad like the SS ones. I have also had luck with painting a coat of interprotect over the gummy surface and then scraping or sanding that off after it set good luck ! Quote Link to post Share on other sites
Cantab 341 Posted October 8, 2019 Share Posted October 8, 2019 Too much hardener tends to stop epoxy setting, you must measure very carefully. A little bit extra just to be sure is enough to cock it up. Quote Link to post Share on other sites
wheels 543 Posted October 8, 2019 Share Posted October 8, 2019 Once again, Epoxy thinners. Nothing else. Epoxy thinners is the only thinner that will remove the stuff. WEAR GLOVES.Sorry, no you can't bush over the hardener. It doesn't work that way unfortunately.Sorry, I had thought you had gone and bought just an Ados hardener.As BOIguy said, you need the exact ratio of resin and hardener to get the best result. The difference with Epoxies is that the hardener is like a bunch of keys that exactly fit a bunch of locks, being the Resin. An incorrect mix leaves a bunch of either locks of keys unmatched and stuck in the hardened mix. If the mix is too far out or wack, you end up with a tacky mess.Low ratio mixes like 2:1 ratios tend to be much more forgiving. High mix ratios like 5:1 require exacting measurements. In fact, high ratio mixes are best weighed rather than measured due to temperature differences causing volume changes. Although small differences won't be noticed, the strength of the cured mix is. That may not be critical for most of us, but mission critical situations requiring best possible strength requires perfect mixes and post curing with heat to ensure all keys are in al the locks so to speak. 1 Quote Link to post Share on other sites
madyottie 82 Posted October 8, 2019 Author Share Posted October 8, 2019 Ok, so I popped in to our local fibreglass expert after work today. According to him... Acetone won't work. M.E.K may work. Having tried tonight, M.E.K helped to soften it slightly, but wouldn't actually remove it. Scraper and 40grit sandpaper kinda works. Surprisingly, Vinegar actually seemed to work quite well, except that I used the same rag I'd used for the mek, so now I need to buy more vinegar for the kitchen cupboard. All is not lost, it seems. Fortunately this is the prototype blade. I have another foam blank in the shed, waiting patiently for my glassing skills to improve. Ideally I'd like to include carbon in the final product, so it could be a long wait. Thanks all for the replies. I'll buy a big pack of Steelo pads tomorrow, and keep on scrubbing Quote Link to post Share on other sites
Dtwo 157 Posted October 8, 2019 Share Posted October 8, 2019 Meths. Sounds just wrong but I have been using it for years to clean epoxy brushes, thin epoxy for sealing and wiping up. If I was in your scenario (nothing to lose) I would: - orientate the rudder so leading edge up - 2 or 3 layers of paper towels over the bits you want to clean - saturate with meths - cover with cling film so meths stays in and air out - leave overnight - have at least one beer while repeating to yourself "I will never mix products again" - see what it looks like in the morning All is not lost yet! Quote Link to post Share on other sites
Steve Pope 253 Posted October 10, 2019 Share Posted October 10, 2019 I usually use meths to dilute epoxy to get a better penetration / sealing on the first coat. Quote Link to post Share on other sites
wheels 543 Posted October 10, 2019 Share Posted October 10, 2019 Yes Meths will thin epoxy. But you do need to be aware that Meths absorbs moisture from the air and so putting it into Epoxy also puts moisture into the Epoxy. There are also a couple of other products in Meths that are not solvents and thus also contaminate Epoxy. As a cleaner, it is fine. Overseas, Methanol is often used as a poison in Meths. But in NZ, Methanol is no longer used. However, I am not sure about Oz, where Super cheap and Bunnings products come from.Cellulose thinners will also thin Epoxy. But it isn't cheap stuff. The bigger problem is that it is has a very fast evaporation rate and you will likely lose 50% of it to the air before it dissolves the Epoxy.Epoxy thinners is a mix of three different solvents. It does not evaporate as fast as the thinner above. Nor do they absorb moisture. It easily evaporates out of an epoxy mix leaving nothing behind.The advantages of either the above thinners is that it will break down Epoxy that maybe tacky, but not fully cured. Which in this case, sounds to be the issue. So it should be the best to use in my view.Meths does not act as a solvent to nearly cured Epoxy. So it may not work as well at removing the tacky stuff.Acetic Acid (Vinegar) stops the cross linking process and thus stops the curing process dead in its tracks. However, it will not actually mix with epoxy. It will help in breaking down the sticky stuff on your hands. BUT DO NOT use it to thin epoxy. 1 Quote Link to post Share on other sites
mcp 34 Posted October 10, 2019 Share Posted October 10, 2019 Yes Meths will thin epoxy. But you do need to be aware that Meths absorbs moisture from the air and so putting it into Epoxy also puts moisture into the Epoxy. There are also a couple of other products in Meths that are not solvents and thus also contaminate Epoxy. As a cleaner, it is fine. Overseas, Methanol is often used as a poison in Meths. But in NZ, Methanol is no longer used. However, I am not sure about Oz, where Super cheap and Bunnings products come from. Cellulose thinners will also thin Epoxy. But it isn't cheap stuff. The bigger problem is that it is has a very fast evaporation rate and you will likely lose 50% of it to the air before it dissolves the Epoxy. Epoxy thinners is a mix of three different solvents. It does not evaporate as fast as the thinner above. Nor do they absorb moisture. It easily evaporates out of an epoxy mix leaving nothing behind. The advantages of either the above thinners is that it will break down Epoxy that maybe tacky, but not fully cured. Which in this case, sounds to be the issue. So it should be the best to use in my view. Meths does not act as a solvent to nearly cured Epoxy. So it may not work as well at removing the tacky stuff. Acetic Acid (Vinegar) stops the cross linking process and thus stops the curing process dead in its tracks. However, it will not actually mix with epoxy. It will help in breaking down the sticky stuff on your hands. BUT DO NOT use it to thin epoxy. What are they using in place of Methanol in NZ now? Surely its not pure ethanol? Back on the main subject. You didn't mentioned Acetone in the above? I have used this for clean up and it does a great job. Is there a reason you have left this out or is one of the ingredients in the epoxy thinners? or? Quote Link to post Share on other sites
wheels 543 Posted October 10, 2019 Share Posted October 10, 2019 Is there a reason you have left this out Yes there is reason I left it out. It's called getting old and forgetfulness Acetone is good. I use it a lot for all sorts of things because it is the one solvent that is not actually toxic to us. Although that does not mean it is non toxic. We still need to take care using it. Acetone is naturally occurs in our bodies in the event of Insulin/diabetes issues, so our bodies have learned to deal with small amounts of it. Where as many other solvents are extremely harmful to us. Including Ethanol. Not sure what NZ made Meths has added. I believe they now use an additive that makes one vomit. Methanol, being poisonous, still never stopped someone desperate enough from drinking the stuff. So I guess they figured it was better to try and stop someone taking it in another way. Which makes sense to me. Quote Link to post Share on other sites
madyottie 82 Posted October 13, 2019 Author Share Posted October 13, 2019 In the end I tried most things (excluding actual Epoxy Thinners) but the only thing that really worked was a scraper and 40grit sandpaper. At this point I've got as far as a first undercoat. Still a bit more sanding to do between coats to get the best finish, but all-up weight at this point is a little over a kilo. Ended up being a few mm too narrow as it is, but easy to fix that problem. Quote Link to post Share on other sites
