Has anyone ever built
8 hours ago, Black Panther said:
Their own solid vang? I remember seeing a design a while back using squash balls.
We used to use squash balls under concrete pavers to support turntables in nightclubs/dance parties etc. We replaced them every month or so. They rapidly lose the air within and quickly become a mush of rubber when under constant pressure.
  • Upvote 1
15 hours ago, Black Panther said:
Also if I remove the toppi g l7ft what happens to the back of the stackpac
You will still need a topping lift. Even the best systems only support the boom temporarily. Without a topping lift your main sheet won't have anything to brace the boom against and it will swing all over the place
  • Upvote 1
I'd use urethane skateboard bushings.  A lot of early mountainbike suspension systems used urethane bushings as the "spring".  Stable, takes huge load, available in a wide range of compression strengths (duro), easily replaced and tuned (stack different duro bushings in different lengths to tune).
  • Like 1
