Frank 185 Posted December 12, 2022 Share Posted December 12, 2022 I have been looking into options for a life raft and was keen on a 6 man Crewsaver in a valise. After making a scale cardboard model to the stated packed dimensions I found It cant fit it in the cockpit locker which was the preferred option , its close but not close enough. Next Option then is to get a smaller 4 man raft or stow it somewhere else, the two other options seem to be the deck or maybe in the fwd V berth which wont be occupied when passage making. I'm not so keen on the deck option even though I see it is common because I would be worried about it being washed off . The boat has stout Iroko grab rails on the coach roof but I still would not trust them to restrain a 50Kg raft. We could probably also stow one behind the companionway steps. Well a bit of a ramble here but any input is appreciated. Quote Link to post Share on other sites
darkside 69 Posted December 12, 2022 Share Posted December 12, 2022 We tied our valise under the saloon table (bridge deck catamaran) That was fine until it inflated itself while we were out for a meal (Menorca) and it more or less filled the cabin Quote Link to post Share on other sites
aardvarkash10 1,138 Posted December 12, 2022 Share Posted December 12, 2022 2 hours ago, Frank said: The boat has stout Iroko grab rails on the coach roof but I still would not trust them to restrain a 50Kg raft. I would more question my ability to wrestle a 50kg item above deck while the hull was rapidly filling with cold seawater at 0300hrs, 700km offshore... I guess we worry about different things. 1 Quote Link to post Share on other sites
Island Time 1,313 Posted December 12, 2022 Share Posted December 12, 2022 nah, amazing what you can lift if you think you'll die if you don't! best place is in stern locker, preferably accessible if inverted. But most yachts don't have that facility. 1 Quote Link to post Share on other sites
CarpeDiem 540 Posted December 12, 2022 Share Posted December 12, 2022 I once had a valise repacked from a suitcase shape into a rollbag of the same volume. Might be an option to get it repacked to fit into the locker? Quote Link to post Share on other sites
Black Panther 1,776 Posted December 12, 2022 Share Posted December 12, 2022 I suspended a valise above a quarter berth with a couple of snapshackles for quick release Quote Link to post Share on other sites
Frank 185 Posted December 12, 2022 Author Share Posted December 12, 2022 9 hours ago, aardvarkash10 said: I would more question my ability to wrestle a 50kg item above deck while the hull was rapidly filling with cold seawater at 0300hrs, 700km offshore... I guess we worry about different things. Yes, I must admit that had crossed my mind as well, they are awkward puppies at the best of times. Quote Link to post Share on other sites
Frank 185 Posted December 12, 2022 Author Share Posted December 12, 2022 8 hours ago, CarpeDiem said: I once had a valise repacked from a suitcase shape into a rollbag of the same volume. Might be an option to get it repacked to fit into the locker? Good suggestion, I will check Quote Link to post Share on other sites
Frank 185 Posted December 12, 2022 Author Share Posted December 12, 2022 7 hours ago, Black Panther said: I suspended a valise above a quarter berth with a couple of snap shackles for quick release Worth a look , and I started watching you tube videos on this, In America they seem to prefer a hard case and a dedicated SS cradle bolted to the Coach Roof . One thought was to use a "soft Cradle" or basically a webbing harness made so that it was impossible for the raft to escape any opening. There would be a draw string lashing through loops on the top , pulling them together like the top of a duffle bag . The Cradle itself would be lashed to deck tiedowns which I may need to retrofit. One cut of the purse string and it is deployed. Quote Link to post Share on other sites
Black Panther 1,776 Posted December 12, 2022 Share Posted December 12, 2022 I wouldn't use a soft case on deck. Mine was inside the boat above the quarter berth. Quote Link to post Share on other sites
B00B00 330 Posted December 13, 2022 Share Posted December 13, 2022 My one is mounted in a stainless steel cradle on the Pushpit. Pretty nicely tucked out of the way and has a quick release strap around it. If you just need it for a voyage then you are welcome to borrow the cradle as I have taken it off for my summer cruise along with all that other stuff cluttering up the back end of the boat. Quote Link to post Share on other sites
Frank 185 Posted December 13, 2022 Author Share Posted December 13, 2022 Thanks for the offer, I saw a few pushpit mounted ones on U Tube, Im considering that and also the deck fwd of the dodger, for both locations I would use a Hard case pack. I will PM you if I need a cradle. (Nice boat BTW ) Quote Link to post Share on other sites
Vivaldi 57 Posted December 13, 2022 Share Posted December 13, 2022 13 hours ago, B00B00 said: My one is mounted in a stainless steel cradle on the Pushpit. Pretty nicely tucked out of the way and has a quick release strap around it. If you just need it for a voyage then you are welcome to borrow the cradle as I have taken it off for my summer cruise along with all that other stuff cluttering up the back end of the boat. What has happened to Rogue 2 - back on the market? Quote Link to post Share on other sites
B00B00 330 Posted December 13, 2022 Share Posted December 13, 2022 3 hours ago, Vivaldi said: What has happened to Rogue 2 - back on the market? Sold it about 6 months ago. She was a great boat but after a wet windy Easter cruise and being stuck inside a 35ft race boat with 3 boys we decided to stretch ourselves and get a proper cruiser again. Brought this one into NZ from New Caledonia in October. Quote Link to post Share on other sites
Vivaldi 57 Posted December 14, 2022 Share Posted December 14, 2022 Nice. Quote Link to post Share on other sites
