banaari 27 Posted March 29, 2012 Share Posted March 29, 2012 Found this photo I took a couple of months ago, the very first time I took the front panel of the switchboard. See how many different transgressions you can spot... Link to post Share on other sites
Mothership 6 Posted March 29, 2012 Share Posted March 29, 2012 11. Are we counting repeats of the same, or just a count of how many different things wrong? I also bet there's more at least 3 more in the immediate vicinity, unseen. Perhaps better to ask what was done right. Link to post Share on other sites
shanson 0 Posted March 29, 2012 Share Posted March 29, 2012 Hey When were you on my boat? Shane Link to post Share on other sites
PaulR 3 Posted March 29, 2012 Share Posted March 29, 2012 About 15 without trying. Link to post Share on other sites
OYSTR 1 Posted March 29, 2012 Share Posted March 29, 2012 Well, the lighting could have been better, a better angle would have shown more of the layout and a smaller aperture would have enabled more of the overall photo to be in focus. Link to post Share on other sites
wheels 543 Posted March 29, 2012 Share Posted March 29, 2012 Looks like most wiring/switch panel installations I have seen. Nothing out of the ordinary But from what I can see, and without doubling anything, I have counted 11. Link to post Share on other sites
banaari 27 Posted March 29, 2012 Author Share Posted March 29, 2012 Well, the lighting could have been better, a better angle would have shown more of the layout and a smaller aperture would have enabled more of the overall photo to be in focus. Link to post Share on other sites
banaari 27 Posted March 29, 2012 Author Share Posted March 29, 2012 Would folks care to enumerate what they've spotted? Best of the lot for me was the white wire "connected" to the 3rd switch from the right. Strip the insulation, bend into an "L", hook it through the hole in the lug and away you go... Link to post Share on other sites
Guest Posted March 29, 2012 Share Posted March 29, 2012 Wrong? What's wrong? Link to post Share on other sites
Bimini Babe 0 Posted March 29, 2012 Share Posted March 29, 2012 Wrong? What's wrong? Now there's a response I can identify with. Link to post Share on other sites
Grinna 2 Posted March 29, 2012 Share Posted March 29, 2012 Does it work? Does the smoke escape? No?? Good to go!! Link to post Share on other sites
Guest Posted March 29, 2012 Share Posted March 29, 2012 Major one I can see is the loose connect near the front that could easily short to the busbar and let lots of smoke out. Link to post Share on other sites
tuffyluffy 76 Posted March 29, 2012 Share Posted March 29, 2012 If theres smoke escaping a good squeeze of sikaflex should keep it comtained. Link to post Share on other sites
smithy09 50 Posted April 5, 2012 Share Posted April 5, 2012 Standard Kiwi boat wiring. You can always tell when you see TPS (House wiring) used. Haven't seen a well wired Kiwi boat yet... And I looked at a few before finding the Marshall... Link to post Share on other sites
rigger 47 Posted April 5, 2012 Share Posted April 5, 2012 Does it work? Does the smoke escape? No?? Good to go!! As a chief engineer taught me - electricity is smoke compressed into wires - f*&^ with it and the smoke escapes Link to post Share on other sites
wheels 543 Posted April 5, 2012 Share Posted April 5, 2012 There are a few good'ens around smithy. But yeah, lots of "shockers" too. Would folks care to enumerate what they've spotted? 1: Well as already just stated, the type of wiring is wrong. It needs to be tinned multi stranded wire. 2:No identification 3:No dressed wiring 4:Busbar and terminations are corroded/rusted 5:Spade connectors. You have to have captive connections, ie screw connection with eye terminal 6:None of the terminals have heatshrink protected the wire/terminal connection 7:Some wires have the insulation broken/cut 8:Lose uninsolated connections/wires just dangling about in the back 9:No main supply wire terminated to the Buss Bar via it's termination point. 10:main supply wire to row of fuses is much smaller than what would be expected as a possible load. 11:one terminal has a white wire just pushed through and bent over as a termination 12:some wires have been soldered 13:hard to tell, but one orange wire looks to be twisted around as a connection What have I missed Link to post Share on other sites
banaari 27 Posted April 5, 2012 Author Share Posted April 5, 2012 What have I missed I think that would be about it The only saving grace is that the original power source for the whole mess was a microscopic gel cell. What might have happened with an 85Ah battery discharging through a short, scares me. Link to post Share on other sites
PaulR 3 Posted April 5, 2012 Share Posted April 5, 2012 14). What about a simpler standard colouring of wires Red = OK Positive . . . generally Orange = Faded red ?? inside a closed sun UV protected box ?? Black = Negative Red/Black stripe = mainly negative but often knot White = ?? Possibly USA positives (from pumps?? etc) White/ Black = ?? possibly USA negatives Bare wires between fuses? (assumed bottom row but top in picture) Yet to fit the Blue, Brown, Yellow, Black/Green stripe, Red/White stripe, Purple, Gray etc wires 15). No Strain Relief on wires comming into box. 16). No cable ties supporting / organising wires. 17). No laminated wiring diagram 18). Switches not labelled on inside of box lid for easy reference. Re your 6). Non Insulated Spade Receptacle = should be the ones with Insulation pre fitted or better still, insulation covers (or heat shrink) fitted over ring terminals, but then again the wrong switches have been used. They are a very common type of switch with spade terminals that were the latest and greatest many years ago, rather than the more expensive switches with screw terminals for ring connectors. Then again, where can one get panel mounted fuse holders with screw terminals So the weakest link is still the push-on spade receptacle. The only fuse holders that I can get always seem to be with spade terminals, so one might as well get the cheaper switches with the same spade type teminals. Anyway one can never find those small S/S screws in electrical shops and they are just too hard to find when dropped, are they knot "It's only for a boat after all" is one attitude that does knot recognise that the salesman's life is knot at risk here, unlike yours. It works OK in the salesman's home Link to post Share on other sites
wheels 543 Posted April 5, 2012 Share Posted April 5, 2012 As an old Radio engineer said to me once, "you need to think like the wire". He's probably been around transmitters too loing me thinks, but he does have a thought worth thinking about. So why insulate terminals??? Well if something comes loose, you don't want it coming into contact with anything else. Why dress wires? (which is what Paul called cable ties etc)because you don't want a wire falling down through other wires and shorting. Why identify?? Well you need to know what you are looking at and for when it all goes pair shapped, which happens when it's all gone to custard. This pic is a result of a major failure that caused the main feed cable that had 1800CCA on it, melt and fall down through other wires resulting in shorting and cutting them all and on down through plumbing and eventually came to rest on Ally Fuel tanks which were isolated from Earth, apart from one electrical path to the Earthed engine which just happened to be a steel braided Fuel line, which super heated up and was melting and blowing Diesel fuel in a smoky fume out into the engine room. Link to post Share on other sites
PaulR 3 Posted April 5, 2012 Share Posted April 5, 2012 What happened on your second day / lesson 2 Link to post Share on other sites
