Black Panther 1,776 Posted July 18, 2020 Share Posted July 18, 2020 From the John Mansell thread. Now we hear of inadequate clips on safety harnesses. I have seen man overboard strobes that float upside down, and I've seen them totally mysh on the inside as not waterproof Any other issues?? Be a good thing to share Quote Link to post Share on other sites
Clipper 375 Posted July 18, 2020 Share Posted July 18, 2020 The ‘inadequate clips’ are fine if used as intended. I believe if most tether clips get caught and side load they will be much weaker. i had 2 strobes on voom that floated on their side, replaced after Tim C bought it up. I had an old liferaft i inflated. Torch batteries were flat, possibly spares flat too. Flares were 2 years out of date, liferaft only 1 yr out of service. My PLB with a 7 year life stopped working after 5, replaced by manufacturer. Test them people (check the time, just after the hour maybe?) And here is one of my own making. I unscrewed the canister in my inflatable lifejacket for flying. 12 months later opened up to service and canister fell on floor. I forgot to reattach! Quote Link to post Share on other sites
Cantab 341 Posted July 18, 2020 Share Posted July 18, 2020 Someones getting paid off big time to keep these on the market. 1 Quote Link to post Share on other sites
Kevin McCready 83 Posted July 18, 2020 Share Posted July 18, 2020 We've still got a long way to go in improving safety culture. One big thing is the definition of a life jacket. Maritime NZ allows the wearing of devices that it knows can leave the wearer face down in the water for chrissakes. https://kmccready.wordpress.com/2014/01/15/lifejackets-lifejackets-and-sissies/ Quote Link to post Share on other sites
Dr Dave 5 Posted July 18, 2020 Share Posted July 18, 2020 Thank you for starting BP For a bit of context - my post I will only clip onto a "jackline" on deck. Also beware of lateral loads There are a number of incidents where people have come to grief attaching to stays or bollards See https://www.yachtsandyachting.com/news/200975/Tether-hook-angle-was-crucial-factor-in-death Regards Dr Dave Quote Link to post Share on other sites
Dr Dave 5 Posted July 18, 2020 Share Posted July 18, 2020 I use the Spinlock 3 hook tether -https://www.spinlock.co.uk/en/categories/safety-lines/product_groups/performance-safety-lines The new clips are lighter and much easier to use one handed Yes they are expensive, however I trust my life to them NOTE - they also carry a warning regarding lateral loads Regards Dr Dave Quote Link to post Share on other sites
Cantab 341 Posted July 18, 2020 Share Posted July 18, 2020 I agree DD that what you do is probably safer given the equipment on the market but: From the safety regulations "Through-bolted or welded anchorage points or other suitable and strong anchorages for safety harnesses must be provided adjacent to stations such as the helm, sheet winches and masts" If the shiny new tether you just bought at great expense ins't safe to use as recommended by the regulations it is not "fit for purpose" and shouldn't be on the market. Quote Link to post Share on other sites
Black Panther 1,776 Posted July 19, 2020 Author Share Posted July 19, 2020 I'll add another. Anything made of fabric: ddrogues on liferings flags on danbuoys. 2 ye lifespan in the tropics tops. At the very least replace with vinyl Quote Link to post Share on other sites
2flit 52 Posted July 19, 2020 Share Posted July 19, 2020 9 hours ago, Clipper said: The ‘inadequate clips’ are fine if used as intended. I believe if most tether clips get caught and side load they will be much weaker. i had 2 strobes on voom that floated on their side, replaced after Tim C bought it up. I had an old liferaft i inflated. Torch batteries were flat, possibly spares flat too. Flares were 2 years out of date, liferaft only 1 yr out of service. My PLB with a 7 year life stopped working after 5, replaced by manufacturer. Test them people (check the time, just after the hour maybe?) And here is one of my own making. I unscrewed the canister in my inflatabl.e lifejacket for flying. 12 months later opened up to service and canister fell on floor. I forgot to reattach! That Spinlock clip in the picture has failed with only a 200 kg side load, that's a frighteningly small amount of force to have them fail at. I would not be willing to assume that even a taught jack-line could prevent a clip from ever being subjected accidental side loading in all circumstances. Even cheep $13.00 aluminum carabiners handle three times that side load (see attached : Side Loaded Carabiner). Why can't the folks making tethers worth many times this amount make something that can withstand significantly more than a 200 kg side load? Quote Link to post Share on other sites
Cantab 341 Posted July 19, 2020 Share Posted July 19, 2020 So if the Spinlock Clips are not suitable for use on the required anchor points should they be acceptable for passing your category inspection? Should the inspector (or YNZ and therefore Maritime NZ), knowing they are not fit for purpose, accept them? In a perfect world they meet some ISO standard and would only ever be subject to a perfect load, by the time you have fallen off or been swept out of your boat you are a long way from a perfect world. Would be nice if your safety equipment could cope with that. Quote Link to post Share on other sites
Island Time 1,313 Posted July 19, 2020 Share Posted July 19, 2020 Im not sure that that IS is spinlock clip. This is; Quote Link to post Share on other sites
Ed 151 Posted July 19, 2020 Share Posted July 19, 2020 Seems spinlock have a standard (pictured below) and performance version that IT posted this is the double cup tether currently on the fosters website Quote Link to post Share on other sites
Cantab 341 Posted July 19, 2020 Share Posted July 19, 2020 7 hours ago, Island Time said: Im not sure that that IS is spinlock clip Found these articles, very informative, I think your right IT but apparently most clips on the market will do the same. You need to read all three to get the whole picture. Just read the last one if you need info on what to choose - hint Spinlock didn't cut the mustard in several ways. https://www.practical-sailor.com/blog/safety-tether-clip-in-caution https://www.practical-sailor.com/blog/tether-clip-update https://www.practical-sailor.com/safety-seamanship/safety-tethers-under-scrutiny "Based on our testing, a variety of locking clips that are certified as meeting the ISO 12401 Standard for racing sailing tethers, World Sailing Small craft – Deck safety harness and safety line – Safety requirements and test methods, do not appear to comply with the portion of the standard (quoted below) that is used to establish that the hook can not easily release from a fixed attachment point by accident." 1 Quote Link to post Share on other sites
Clipper 375 Posted July 19, 2020 Share Posted July 19, 2020 I have spinlock.☹️ Quote Link to post Share on other sites
splat 57 Posted July 19, 2020 Share Posted July 19, 2020 Me too re spinlock but no fixed anchor points, just continuos jackline...they aren't cheap. Quote Link to post Share on other sites
2flit 52 Posted July 19, 2020 Share Posted July 19, 2020 9 hours ago, Island Time said: Im not sure that that IS is spinlock clip. This is; Well I took my image from a marine testing article that represented the clip as being Spinlock and the article was about the fiasco on the Clipper Ships Around the World man-overboard tether break. This is especially bad when you read the full account linked on the Clipper site. This clipper ship had so many 'issues' aboard that one crew member left mid way in South America, instead of continuing on his ( they cost up to $80,000) race around the world passage. I have compared the CrewSaver clips aboard our boat to the Spinlock my wife uses. I did this just yesterday for the first time. Guess what? The Spinlock is dramatically thinner when comparing the Spinlock to the CrewSaver clip. Now... I have no idea of the tensile properties of the stainless in either of these clips, there are tremendous differences between the exact same looking stainless shackles when comparing standard shackles to H.R. (High Resistance) stamped shackles. So I can't say that the CrewSaver is way better. But it sure is about 30% to 40% thicker. There are allot of other issues involved here because the Clipper Ships switched to another brand of tether afterwards, arguably because they were concerned about the Spinlock brand..... However they then switched back to Spinlock for unstated reasons. I would assume it could either be sponsorship issues, or more likely because the Spinlock clips are so easy to use (un-clipping and re-clipping).... but I have no idea My point is >> Why don't manufactures use a clip that is stronger? It would be really easy to design one that withstands a much higher side load than 200 kg. Quote Link to post Share on other sites
2flit 52 Posted July 19, 2020 Share Posted July 19, 2020 Here is an example of a clip that 'appears' to be able to withstand higher side loads. This is according to custom shop I corresponded with which makes custom tethers, atreeas, slings, and so forth. https://www.baselinemarine.com/shopexd.asp?id=6899 I think there may be other options, this is just the first I was made aware of Quote Link to post Share on other sites
2flit 52 Posted July 19, 2020 Share Posted July 19, 2020 And this complete tether (https://www.kong.it/en/2-products/items/c4-components/f41-sailing-accessories/p764-elastictetherevodouble) tested much better. Here is a quote from Practical Sailor: "To our testers surprise, off-center loads don’t have to be great to bend a snap hook open. In our tests, the Gibb-style hooks like the Spinlock Race Clip that Speirs was wearing began distorting under axial (side) loads as light as 275 pounds. At 300 pounds the hooks were fully open. As a comparison, carabiners used by rock climbers like the Kong Tango sustain loads up to 2,700 pounds before failure, and about 1,160 pounds when nose hooked." So we go from 136 kg on a Spinlock up to 526 kg with the Kong tether clip. A 380% improvement. Quote Link to post Share on other sites
Start Me Up 4 Posted July 20, 2020 Share Posted July 20, 2020 Here's the real spinlock and the later version is IT'S picture. KM absolutely correct on spotting this. Quote Link to post Share on other sites
DaveNoy 1 Posted July 20, 2020 Share Posted July 20, 2020 Guessing it’s in reverse order to what you would think, given KM is asking the question. Rope (strongest (2T break load ??)), 6mm chain. 8mm link, with the 10mm SS link being weakest. Quote Link to post Share on other sites
