Sealing Sheet Tracks
1 hour ago, Sail Rock said:
Same here. Get someone to hold the screw in place with a screwdriver to prevent it turning and breaking its bond with the sealant, while you tighten the nut from below.
You have had success with this method Sail Rock? Currently in the process of doing the first track at the moment using Sika 291. Cheers.
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Here you go : https://www.tradeproducts.co.nz/product/butyl-lap-tape-white-4mm/
I did the same as Fish using Sika 291, the trick is too do the last tighten after it’s hardened but before it’s fully cured. And tighten the nuts not the screw of course
Yes, 291 is the stuff, and 180S is spot on, and in better detail than me. It is definitely a 2 person job. Firstly to lay down the sika and place the track on it, then to tighten the nuts while someon
Posted Images
