All Activity
- Past hour
Do you charge it from the boat or plug into the grid somehow?
- Today
My little 3.5 Mercury drove me insane. Was very reliable for 8 or 9 years but then conked out every time I used it for the next 2 or 3 years. Mechanic reckoned it was to do with some change to the composition of petrol (?) and that repairs to small outboards was their biggest money spinner. I ditched it and splashed out on an ePropulsion Spirit electric. Best thing I’ve ever bought. (Apart from the diesel heater) (And the boat)
I'll give the magic carb cleaner a go, then try for the fuel pump membranes then take It to the workshop.
- Yesterday
Looking for a 15m berth at Bayswater to rent direct. Long term. Thanks, Mike
Got spark??Give the plug a clean and a squirt if engine start before polling pump a part.2s only 2 things can go wrong no spark or fuel
I'll need a bigger wheelie bin
I had issues this week after the rain. Turns out water in the fuel, very little and easily purged with the drain screw. 4hp Yamaha 4st
Oceanographerd use oranges to study currents.
2 stroke, but all good comments, thanks. It was serviced about 6 months ago, out west. I would have thought that the fuel would be clean, and is fresh, but I guess you don't really know. I'll strip down and clean the carb. And go for new pump membranes.
I still assert that even the report says "as likely as not", meaning 50:50, and for a prosecution you need to be beyond reasonable doubt. Note I've not been saying the capsize occurred where the skipper said, but I've been saying you can't rely on the location being where the modelling said. It could have been fairly much anywhere. But anyway, lets move on. What does it mean for the case if the capsize occurred where the modelling suggests it did? - as opposed to anywhere else other than where the skipper thought he was, which could be anywhere. They were heading in to anchor, in how
To roll a boat you need the following conditions; Wave height must match the beam of the boat (risk of knock-down and rolling) The boat needs to be broadside or oblique to the wave The boat needs to be struck by a breaking wave: unless the wave is breaking, the boat should ride up and over the wave regardless of the wave height in comparison to the boat length and the boat’s orientation to the wave When the wave height reaches 50% of the boat length, there is a high probability of capsizing, with more than 60% the boat is going to be capsized every time of course only
Beyond reasonable doubt. Which is why the issue of relative culpability will be important.
You must have missed the bit where the EPIRB track lined up with the drift modeling - proving that the Easterly turn wasn't Aliens but was actually the expected/modelled tidal drift. I think you have a better chance of convincing people that it was Aliens which moved the EPIRB, the Flybridge and all the debris from 1mile north east of the EPIRB activation point into the Northern tidal stream at the 10m contour. Cause you'll never convince anyone who knows anything about the tide, that a 1Nm wide eddy was moving at 6knots in a WSW direction.
I have begun to draw the conclusion that you have not actually read the report. You'll be pleased to know it wasn't Aliens. So, RCC were using a model at the time of the incident that said this is exactly what would happen - low and behold it is exactly what happened. The report further clarifies how the commission determined the location of the capsize: I am no expert, but from my simple calculations - for the flybridge to have drifted from the location the skipper claims the capsize occurred to the point where the EPIRB was activated and attached to the Fly Bridge,
"About as likely as not" As in 50:50. Yes, I have read the report. Most of it when it first came out and parts of it in the last few days.
How do you define an expert? I can be an expert in anything if you want to pay me enough. That's how it works isn't it? I do have reasonable knowledge of modelling and I know that sh*t out of a computer / model is only as good as the sh*t in. I have enough knowledge of surf beaches to know rips / strong outgoing currents can be just meters away from incoming waves / strong incoming forces. Whilst sailing I have seen tide lines with measurable currents going in random directions, normally 90 deg to the current I was in. Whilst spearfishing / snorkelling around reefs and head
I was assuming the fully spec'ed auto inflating with 250n of bouyance, auto-deploying sprayhood, light and double crutch straps, as per the ones I have on my boat. It didn't occur to me that the fisho's would be using the old manual variety. But yes, there is a wide range of opinions on LJ's, especially around risk of entrapment in upside down boats. If I were in the sea, I'd want my fully pimped LJ on, if I was inside an upside down boat with it on, well, perhaps I'd be reaching for the inbuilt strap cutter
Island Time started following Mariner 5hp outboard giving me grief
4 stroke, right? They have very small jets, it's VERY likely a carb blockage. Take the jets out and clean them - they are very small in these motors, and will block with older fuel that has gelled a little.... Empty the fuel into your car, clean the fuel system, and fresh fuel, it will go fine....
Is this an expert opinion? Or one of those everyone-has-one opinions? If the former, then I strongly suggest you get in touch with the defense team, as they have produced no expert witness to discredit the tide modelling, and no other people that have local knowledge of the area have come forward to discuss phantom eddies. I also don't know how it was done, but that doesn't mean it wasn't and it certainly doesn't mean that I am qualified to discredit the people/teams/companies that did.
The jets in those carbs are tiny ( ours is worse, it's the 2.5hp version) so even invisibly small crap can block them. Fresh fuel less than 3 months old helps. TBH, if it hasn't been serviced in a while just drop the whole thing in to Ray Bryant and let them sort it. Then you are good for another year.
I disagree with your opinion My opinion is that seasoned fisherpeople, going on the trip of a lifetime to the Three Kings, would be smart enough to know not to inflate their LJ's until they are outside.
Flooding wasn't the issue, still wont start, but sounds like it's the thing to do. Cheers
I pulled mine apart when I feel like a pleasant easy job in the shed, dismantle the carb and soak various bits in CRC carb cleaner, then put it back together how it came apart. Starts second pull cold start and first pull every time, 2hp Yamaha. Doing that addresses things like a sticky float, grease / wax build up in the bowl and sh*t in the jets and what not. If you think you flooded it, it might just be that, but an easy strip down and clean of the carb is probably the first diagnostic step in identifying any other issues that you have mentioned.
C'mon, what else is there to the case? I'm keen to know. Do you mean the other fishing vessel that was called as a key witness that said it was too rough to leave the anchorage, but was found under cross examination to have been fishing all day? In contravention of their own SoP's if the wind was as high as they said, that one? Or the Predict Wind forecast that said 20knts easing, or the observed 10 to 12knts at the time of capsize? What more is there to the case?
