erice 732 Posted May 4, 2018 Share Posted May 4, 2018 gauge could be temp. or pressure does it have any units on the scale? does it move when you pump? does it move when oven going? the front of the stove in pic doesn't seem to show a valve... if it is a tank pressure relief valve does it hiss when opened after pumping? Quote Link to post Share on other sites
rmiker 15 Posted May 4, 2018 Share Posted May 4, 2018 I bought a packet of about 50 of those little tea light candles for a few dollars haven’t tried it yet but i would think burning 5 or 10 of them safely in a pot or similar would help heating in a small boat with adequate ventilation Not much of a financial commitment to find out. Ummm. The interior of your vessel will turn black.. slowly but surely.. and so will your lungs Do not do it.. Please.... Quote Link to post Share on other sites
rmiker 15 Posted May 4, 2018 Share Posted May 4, 2018 Ummm. The interior of your vessel will turn black.. slowly but surely.. and so will your lungs Do not do it.. Please.... Tis the soot.. Candles are a very inefficient way of burning fuel. Quote Link to post Share on other sites
southernfreedom 0 Posted May 4, 2018 Author Share Posted May 4, 2018 gauge could be temp. or pressure does it have any units on the scale? does it move when you pump? does it move when oven going? the front of the stove in pic doesn't seem to show a valve... if it is a tank pressure relief valve does it hiss when opened after pumping? hi. I will get a look at it on Sunday and sort a photo Quote Link to post Share on other sites
southernfreedom 0 Posted May 4, 2018 Author Share Posted May 4, 2018 thats similar but a lot smaller Quote Link to post Share on other sites
erice 732 Posted May 4, 2018 Share Posted May 4, 2018 they're very simple really the classic yacht guys know all about them you'll get sorted Quote Link to post Share on other sites
ex TL systems 63 Posted May 4, 2018 Share Posted May 4, 2018 Tis the soot.. Candles are a very inefficient way of burning fuel.. Okay I’ll just put a woolly hat and jumper on or better still head north for winter. Quote Link to post Share on other sites
erice 732 Posted May 4, 2018 Share Posted May 4, 2018 ^ or make an alcohol stove out of a beer can https://www.youtube.com/results?search_query=beer+can+stove blue burn is GOOD and burn meths (methylated spirits for americans, sepporated by a common language ) but don't fall asleep without a hatch open and put it in a clay pot in case it falls over Quote Link to post Share on other sites
DrWatson 375 Posted May 4, 2018 Share Posted May 4, 2018 ^ or make an alcohol stove out of a beer can https://www.youtube.com/results?search_query=beer+can+stove blue burn is GOOD and burn meths (methylated spirits for americans, sepporated by a common language ) but don't fall asleep without a hatch open and put it in a clay pot in case it falls over These things are awesome and surprisingly easy and rewarding to make. a good pocket knife and a six pack is all you need. A ruler helps. Also you get to drink at least two beers to make one. ...Actually the more I think about it, the more beers you drink while making them, the more beers you have to drink 'cause you keep wrecking the next can... Quote Link to post Share on other sites
Priscilla II 392 Posted May 6, 2018 Share Posted May 6, 2018 Anything like this one which I have. Burners and valve kits all readily available. Quote Link to post Share on other sites
vic008 17 Posted May 6, 2018 Share Posted May 6, 2018 Did someone say burners cheap as chips in Fiji? About $200 here I think. Quote Link to post Share on other sites
southernfreedom 0 Posted May 11, 2018 Author Share Posted May 11, 2018 sorry team. its a mariner duchess Quote Link to post Share on other sites
Neil C 1 Posted May 11, 2018 Share Posted May 11, 2018 Have you lifted/hinged up the cook top and found the kero filler cap on the LHS ? 1 Quote Link to post Share on other sites
southernfreedom 0 Posted May 17, 2018 Author Share Posted May 17, 2018 filler under door. goes really well Quote Link to post Share on other sites
idlerboat 116 Posted May 18, 2018 Share Posted May 18, 2018 Like with any fuel burning stove , make sure you have good ventilation (and dont use it as an overnight heater). Overtime kero burning will give your boat a distinct smell. Most owners dont notice it.. You can now get diesel heaters (external flue, blower types for under $300 !!) There are thousands of them being made in China and are basically webasco copies. And to to the tilley lantern heaters.....beware !! the original mantels of the heaters are asbestos. (I collect Tilley lamps : ) ) Quote Link to post Share on other sites
Priscilla II 392 Posted May 18, 2018 Share Posted May 18, 2018 Idler each to his own. Chinese and 300 bucks is definitely not the way to go just cheap crap with all the usual lack of warranty and support. Sticking with my Tilley and if asbestos is your worry what do you think municipal water supply pipes are made of. Quote Link to post Share on other sites
