NZTiger 20 Posted June 14, 2021 Share Posted June 14, 2021 Mainly for the catamaran crowd but i'm sure the issue crops up on trailer-sailers and boats with similar solutions for extending and retracting appendages. After a few casual conversations I'm getting some mixed advice on ways to ensure daggerboards slide in their cases well. There seems to be a few camps: - Don't use anything - Silicone - Grease or the like - Some exotic concoction that i've never heard of I'd be keen to hear what other sailors use and how you go about applying it correctly. I'm wanting to keep it environmentally friendly. Quote Link to post Share on other sites
waikiore 501 Posted June 15, 2021 Share Posted June 15, 2021 Lux liquid 😉 Or as KM would say KY.... Quote Link to post Share on other sites
armchairadmiral 411 Posted June 15, 2021 Share Posted June 15, 2021 What's happened to KM ? Quote Link to post Share on other sites
MartinRF 76 Posted June 15, 2021 Share Posted June 15, 2021 I use nothing. The trick is to realize there is no need for a very tight fit and apart from the exit hole in the bottom of the hull the fit can be quite sloppy. For support higher up in the dagger board case you can use synthetic carpet material or astroturf to take up the slop and avoid noise. I use this both top and bottom in my rudder sleeves. Adding a wear protecting 'rail' (my English failed me) to the rear of the dagger board case is nice as that edge of the board can be a bit 'aggressive'. Rudder sleeve seen here: http://hem.bredband.net/b262106/pages/index.html /Martin Quote Link to post Share on other sites
Fish 0 Posted June 15, 2021 Share Posted June 15, 2021 1 hour ago, armchairadmiral said: What's happened to KM ? I've been wondering the same. Maybe he's working on getting the reptile back in the water? Wheels mentioned he was working on something big? Perhaps he's taken up working for a living? Perhaps he got banned? Or perhaps he is the Editor, and he is foxing us. Although it is more likely he got abducted by aliens. Either that or there is no interweb at banana bread bay. 1 Quote Link to post Share on other sites
NZTiger 20 Posted June 15, 2021 Author Share Posted June 15, 2021 2 hours ago, MartinRF said: I use nothing. The trick is to realize there is no need for a very tight fit and apart from the exit hole in the bottom of the hull the fit can be quite sloppy. For support higher up in the dagger board case you can use synthetic carpet material or astroturf to take up the slop and avoid noise. I use this both top and bottom in my rudder sleeves. Adding a wear protecting 'rail' (my English failed me) to the rear of the dagger board case is nice as that edge of the board can be a bit 'aggressive'. Rudder sleeve seen here: http://hem.bredband.net/b262106/pages/index.html /Martin Thanks Martin. I haven't used anything so far and haven't really needed to. However, It does give me grief when the boat is going fast and we need to slow it down to raise the windward board - so I thought i'd see what others are doing. Quote Link to post Share on other sites
MartinRF 76 Posted June 15, 2021 Share Posted June 15, 2021 4 hours ago, NZTiger said: Thanks Martin. I haven't used anything so far and haven't really needed to. However, It does give me grief when the boat is going fast and we need to slow it down to raise the windward board - so I thought i'd see what others are doing. Off-loading the board is what I do: a quick bear-away synchronized with pulling the board up. Slowing down is safer though. /Martin Quote Link to post Share on other sites
Black Panther 1,776 Posted June 15, 2021 Share Posted June 15, 2021 13 hours ago, Fish said: I've been wondering the same. Maybe he's working on getting the reptile back in the water? Wheels mentioned he was working on something big? Perhaps he's taken up working for a living? Perhaps he got banned? Or perhaps he is the Editor, and he is foxing us. Although it is more likely he got abducted by aliens. Either that or there is no interweb at banana bread bay. #3 Quote Link to post Share on other sites
Adrianp 137 Posted June 16, 2021 Share Posted June 16, 2021 11 hours ago, MartinRF said: Off-loading the board is what I do: a quick bear-away synchronized with pulling the board up. Slowing down is safer though. /Martin Having raced cats for years, this is about the only practical method to get them up if underway. The best way is to get them up/down when tacking but often there aren't enough hands onboard to achieve this. If short tacking, then just leave both down, it doesn't seem to slow you down much. Be careful with GBE boards if your cases aren't well reinforced inside the boat. They really need to be all the way down or at the top of the case, as they are known to break the case if halfway down and the top of the board is in a unsupported part of the case, Quote Link to post Share on other sites
2flit 52 Posted June 16, 2021 Share Posted June 16, 2021 We have a mixture of Teflon dust and epoxy as a final coat on our dagger board, worked the charm on two trimaran dagger boards owned so far. Quote Link to post Share on other sites
Black Panther 1,776 Posted June 16, 2021 Share Posted June 16, 2021 KY? Quote Link to post Share on other sites
Clipper 375 Posted June 16, 2021 Share Posted June 16, 2021 I used to wet the boards of my GBE with seawater before putting them down. Once I sprayed them with dry glide or similar, but be aware if you do that, painting and repairs etc need really really good prep. I found wet and dry them nice and smooth and wet them and that was enough. Could never move under load, dont worry about that. Quote Link to post Share on other sites
NZTiger 20 Posted June 18, 2021 Author Share Posted June 18, 2021 Thanks for the advice team. I'll try the wetting down approach and see how we go. I'm reluctant to put anything on them that's going to have adverse environmental consequences for the sake of convenience. Sounds like moving them up and down rapidly while underway seems to be out of the question in a GBE once you achieve trotting pace. Cheers, Justin Quote Link to post Share on other sites
