Island Time 1,360 Posted November 22, 2021 Share Posted November 22, 2021 6 minutes ago, TCat said: what brand and model is that? Milwaukee M28 with the ultimate cranker chuck replacement bit... Now hard to find, the M28 range is discontinued. However you could buy the M18 replacement and one of these... https://www.ebay.com/itm/233961905681 Quote Link to post Share on other sites
Adrianp 138 Posted November 22, 2021 Share Posted November 22, 2021 Fosters do the bits but they don't look as heavy duty as the ultimate cranker. https://fostersshipchandlery.co.nz/products/ironsea-winch-bit https://fostersshipchandlery.co.nz/collections/winches/products/harken-drill-adapter-powered-crank-handle 1 Quote Link to post Share on other sites
JackRussel 0 Posted November 23, 2021 Share Posted November 23, 2021 On 23/11/2021 at 12:05 AM, Adrianp said: Fosters do the bits but they don't look as heavy duty as the ultimate cranker. https://fostersshipchandlery.co.nz/products/ironsea-winch-bit https://fostersshipchandlery.co.nz/collections/winches/products/harken-drill-adapter-powered-crank-handle-betpokies Have you tried using them? How do they work? Quote Link to post Share on other sites
B00B00 361 Posted November 23, 2021 Share Posted November 23, 2021 I would just like to get one of those which handle fittings to try in my battery drill. Anyone know where you can get them? Quote Link to post Share on other sites
B00B00 361 Posted November 23, 2021 Share Posted November 23, 2021 Hold that thought, I see you can get them from Fosters in westhaven. https://fostersshipchandlery.co.nz/products/ironsea-winch-bit Quote Link to post Share on other sites
Adrianp 138 Posted November 23, 2021 Share Posted November 23, 2021 I brought one of the fosters bits a while ago and tried with with my Ryobi battery drill. The battery drill just didn't have the grunt to lift me up, even on a 2:1 halyard and a Harken 40 winch. Maybe a better battery drill would but I'm thinking the smarter way for me is to use a 240v drill off my inverter - just way more grunt. Quote Link to post Share on other sites
Jon 413 Posted November 24, 2021 Share Posted November 24, 2021 Just remember booboo “once the smoke comes out of the wires there’s no putting it back” Quote Link to post Share on other sites
Clipper 382 Posted November 24, 2021 Share Posted November 24, 2021 On 22/11/2021 at 10:51 AM, Adrianp said: Has anyone found a cheap 240v tool that can do this job? I'm thinking for the rare time we need one of these to get me up the mast, we could plug in and run off our 3kw inverter. Cant you just climb up like a normal person? 🤣 Quote Link to post Share on other sites
CarpeDiem 587 Posted November 24, 2021 Share Posted November 24, 2021 3 hours ago, Adrianp said: I brought one of the fosters bits a while ago and tried with with my Ryobi battery drill. The battery drill just didn't have the grunt to lift me up, even on a 2:1 halyard and a Harken 40 winch. Maybe a better battery drill would but I'm thinking the smarter way for me is to use a 240v drill off my inverter - just way more grunt. Most 230v drills have relatively low torque and high RPM. The Milwaukee M28 and the M18 are 122Nm The WinchRite is 130Nm and the Ewincher is 90Nm The electric high torque Makita drill is 50Nm - that might be enough... You probably want something that is at least 60Nm... Quote Link to post Share on other sites
Island Time 1,360 Posted November 24, 2021 Share Posted November 24, 2021 In my experience the winch handle devices are not much use. My neighbour has one, and when he saw my ultimate cranker, he went and ordered one. No comparison with the one he had. My ultimite cranker will lift me to the masthead (circa 82kg, about 16m ) 3x on one batt. Quote Link to post Share on other sites
alibaba 88 Posted November 26, 2021 Author Share Posted November 26, 2021 Job done, for reference for others whose transducers stop working: looks like most just need new bearings - 10 dollars each from Gofish - good service there. Make sure that you get them unlubricated. Grant at gofish lubricates them as they are used in fishing reels which is great. BUT- the anemometer is slowed down by even a small amount of lube. If you need new rotating cups or wind direction swivel, discount marine has the kits. Thanks again for the help 1 Quote Link to post Share on other sites
Vivaldi 66 Posted November 26, 2021 Share Posted November 26, 2021 On 18/11/2021 at 1:52 PM, Rgvkiwi said: Sweet thank you, the boat came with a bosuns chair but at 100kg's neither of us were sure a Ross 830 mast will handle that much...any thoughts (liability free! ) A good tip on the shackle, would never have thought of that. I’ve been up that rig - it’s pretty skinny at the top Quote Link to post Share on other sites
Rgvkiwi 15 Posted November 28, 2021 Share Posted November 28, 2021 On 26/11/2021 at 8:57 PM, Vivaldi said: I’ve been up that rig - it’s pretty skinny at the top Haha, yes and hence the fear of hoisting a 102kg person up there!!! Quote Link to post Share on other sites
