reinajune 2 Posted March 2, 2022 Share Posted March 2, 2022 Hi all, I noticed I have a small tear in the outer layer of my Gill wet weather jacket. I'm pretty handy with a needle and thread so won't have any trouble stitching it up but just wanted to check here to see if anyone has any tips before I go poking holes? Thanks! Quote Link to post Share on other sites
Steve Pope 243 Posted March 2, 2022 Share Posted March 2, 2022 44 minutes ago, reinajune said: Hi all, I noticed I have a small tear in the outer layer of my Gill wet weather jacket. I'm pretty handy with a needle and thread so won't have any trouble stitching it up but just wanted to check here to see if anyone has any tips before I go poking holes? Thanks! Just check the inner coating, I have had 2 Gill OS jackets that have shed their white rubbery coating, basically rendering them useless as waterproofs. Otherwise stitch away! Quote Link to post Share on other sites
Black Panther 1,584 Posted March 2, 2022 Share Posted March 2, 2022 I bought a raincoat at bunnings for $12 Quote Link to post Share on other sites
aardvarkash10 958 Posted March 2, 2022 Share Posted March 2, 2022 lots of good youtube clips of repairing gortex and other technical fabrics. Most are self-adhesive patches, not stitched. Quote Link to post Share on other sites
Zozza 293 Posted March 2, 2022 Share Posted March 2, 2022 2 hours ago, Steve Pope said: Just check the inner coating, I have had 2 Gill OS jackets that have shed their white rubbery coating, basically rendering them useless as waterproofs. Otherwise stitch away! How long did it take for the coating to shred? I was thinking of buying.a set of Gill WW gear but you have given me pause... Quote Link to post Share on other sites
Steve Pope 243 Posted March 2, 2022 Share Posted March 2, 2022 The first set (well used) about 3 years, the second set (my wifes) that had seen very little use and spent most of its time on a hanger onboard as she often had better things to do, was first noticed around 4 years but may have been shedding the coating as there was white bits below in the hanger locker. It took a while to join the dots. Gill may have done an upgrade since then? These ones were bought around 10 years ago. but they certainly appeared to have a limited life span, heavily used or not. 1 Quote Link to post Share on other sites
wheels 543 Posted March 2, 2022 Share Posted March 2, 2022 The only issue with any waterproof type fabrics is that when poking a needle into the fabrick, you create holes water will seep through. You can spray a water proofing compound over the repair, but it will be visible. A product is available that canvas workers use to waterproof seems. But a tin of it is waaay too much for a little repair. The product is pretty much the clear stop leak in a spray can you see advertized. A light spray of that will seal the stitching for you. It's just a flexible Polyurathane skin coating. You could create a little puddle of it a small container and use a finger in a glove and wipe it onto just the stiching. Quote Link to post Share on other sites
Psyche 630 Posted March 2, 2022 Share Posted March 2, 2022 repairing with a needle and thread would work, but seal the seam with some wetsuit type neoprene goo seam sealer or even RTV for the basic version, for a gucci job you really need some kind of iron on patch. I think it would not be unfair to say that average recreational wet weather gear is overpriced for the quality, and it wears out fast. My Gill was pretty much useless after a season, but high end gear is excellent HPX etc but you pay, I think I paid 3k plus or something that I dont really want to think about again! For harbour and coastal use when it comes time to upgrade, you could do a lot worse than exploring the world of motorbike gear. 2 Quote Link to post Share on other sites
ex Elly 197 Posted March 2, 2022 Share Posted March 2, 2022 You can use sail repair tape (stickyback) to patch up holes. I have seen the white liner shedding on Line7 and HenriLloyd gear, so it is not a Gill specific problem. 1 Quote Link to post Share on other sites
Black Panther 1,584 Posted March 2, 2022 Share Posted March 2, 2022 My $12 raincoat is waterproof. 1 Quote Link to post Share on other sites
aardvarkash10 958 Posted March 2, 2022 Share Posted March 2, 2022 45 minutes ago, Black Panther said: My $12 raincoat is waterproof. spendthrift. GarbageBag-RainCoat : 4 Steps (with Pictures) - Instructables 1 Quote Link to post Share on other sites
Psyche 630 Posted March 3, 2022 Share Posted March 3, 2022 1 hour ago, aardvarkash10 said: spendthrift. GarbageBag-RainCoat : 4 Steps (with Pictures) - Instructables meh, Quote Link to post Share on other sites
ynot 45 Posted March 3, 2022 Share Posted March 3, 2022 3 hours ago, Black Panther said: My $12 raincoat is waterproof. Haha I like the way you roll. Quote Link to post Share on other sites
reinajune 2 Posted March 3, 2022 Author Share Posted March 3, 2022 Thanks for all the advice, not sure a trash bag is gonna cut it on the bow 😜 Looks like getting a small patch might be the way to go as the inner white lining is still intact. I have also experienced the shedding problem with Henri Lloyd gear - so annoying. Definitely looking to upgrade to some decent offshore gear but $$$ has me dead. Cheers! Quote Link to post Share on other sites
wheels 543 Posted March 3, 2022 Share Posted March 3, 2022 The "shedding" happens with any brand. it is the type of material used. Open Ocean gear is great new. But no one ever has said it it great for long term use. So be aware, the cost far outweighs the return you will get. Last year I bought a High Vis jacket directly from the manufacturers here in NZ. They advertise on Trademe. It was a factory second. Supposedly had a slight mark. I could hardly see it. It is a fanstastic Kacket that I paid $35 dollars for. It is not lined with the Fleece, but it does have the inner lingins to promote air movement and reduce moisture from a sealed outer fabric. It works just as well as my Gill Coastal Jacket. I love it. 1 Quote Link to post Share on other sites
Steve Pope 243 Posted March 3, 2022 Share Posted March 3, 2022 I have found motorcycle gear far superior in the wet compared to marine stuff available, both in price and longevity. Not that I have used it onboard, and only at speeds of up to 100k's +- on my bike. The downside is that in hot weather like we have had this summer it is difficult to get sufficient cooling while still reasonable protection from road rash. Whereas on the yacht you can strip off the WW gear as the temperature warms up. Kaiwaka gear was (is?) reasonably priced. I often think that you need to see what the longline and crayfishermen are wearing for durability and waterproofability. 1 1 Quote Link to post Share on other sites
Ex Machina 365 Posted March 5, 2022 Share Posted March 5, 2022 Kaiwaka will hopefully be releasing sailing specific gear before winter Quote Link to post Share on other sites
Zozza 293 Posted March 5, 2022 Share Posted March 5, 2022 On 4/03/2022 at 10:17 AM, Steve Pope said: I have found motorcycle gear far superior in the wet compared to marine stuff available, both in price and longevity. Not that I have used it onboard, and only at speeds of up to 100k's +- on my bike. The downside is that in hot weather like we have had this summer it is difficult to get sufficient cooling while still reasonable protection from road rash. Whereas on the yacht you can strip off the WW gear as the temperature warms up. Kaiwaka gear was (is?) reasonably priced. I often think that you need to see what the longline and crayfishermen are wearing for durability and waterproofability. You could be onto something Steve. If MC gear works well at 100K on a bike, it is sure to work even better on my speedy vessel roaring along at 5 knots Edit: Where's KM when you need him? He flies around on an MC too. I hear he even keeps a eye on this forum 😉 Quote Link to post Share on other sites
Psyche 630 Posted March 5, 2022 Share Posted March 5, 2022 one difference with bike gear is that it doesnt have a hood, so you would need something like: or Quote Link to post Share on other sites
