Black Panther 1,586 Posted February 1, 2018 Share Posted February 1, 2018 Is there a rule of thumb for what size for different sized boats? Quote Link to post Share on other sites
Priscilla II 392 Posted February 1, 2018 Share Posted February 1, 2018 BP, here is a Wallas listed on trademe. Wallas are great heaters and this could well be a good buy. https://www.trademe.co.nz/Browse/Listing.aspx?id=1534107769 Quote Link to post Share on other sites
w44vi 17 Posted February 2, 2018 Share Posted February 2, 2018 I would have thought 4kw would be bit small ? Quote Link to post Share on other sites
Fish 0 Posted February 2, 2018 Share Posted February 2, 2018 4 kW in a boat sounds fairly big to me. But I would have thought the big variables would be where the boat is going to be (climate) and how well insulated it is. Big difference between Auckland in the winter, Fiordland, the Sub Antartic islands or Patagonia. Boats have much smaller air volume than houses to heat, but have a substantially different environment obviously with moisture, ventilation etc. I'm not aware of any rules of thumb though. I would think there are too many variables with location, climate and type of boat. Quote Link to post Share on other sites
Island Time 1,235 Posted February 2, 2018 Share Posted February 2, 2018 I have a 2kw in Island Time. She is well insulated, but in temps under 5 deg, the heater is barely adequate. Go for a 4kw at least! Quote Link to post Share on other sites
Black Panther 1,586 Posted February 2, 2018 Author Share Posted February 2, 2018 Thanks for that link, looking seriously Quote Link to post Share on other sites
Priscilla II 392 Posted February 2, 2018 Share Posted February 2, 2018 BP check that the unit is complete including the exterior exhaust fitting. Installation is pretty straight forward. Wallis also do a nifty cooker come heater, not cheap though. Ducting, vent grills and other bits and pieces if required can be purchased easily. Quote Link to post Share on other sites
Priscilla II 392 Posted February 2, 2018 Share Posted February 2, 2018 Heatspace Ltd in Christchurch are Wallas and Eberspacher importers. Quote Link to post Share on other sites
Black Panther 1,586 Posted February 2, 2018 Author Share Posted February 2, 2018 i was wondering if I could tee the exhaust into an existing above water thru hull? Or does it get really hot? Quote Link to post Share on other sites
Black Panther 1,586 Posted February 2, 2018 Author Share Posted February 2, 2018 And I would need minimum two vents Quote Link to post Share on other sites
Island Time 1,235 Posted February 2, 2018 Share Posted February 2, 2018 The exhaust gets pretty hot. Quote Link to post Share on other sites
southernman 73 Posted February 3, 2018 Share Posted February 3, 2018 We have 4kw in a 43footer ducted and it's toasty warm, BP you'd need a big heater for your boat. Quote Link to post Share on other sites
ex TL systems 63 Posted February 3, 2018 Share Posted February 3, 2018 We have 4kw in a 43footer ducted and it's toasty warm, BP you'd need a big heater for your boat. unless you can shut a few doors so you don,t need to heat the whole boat Quote Link to post Share on other sites
darkside 61 Posted February 3, 2018 Share Posted February 3, 2018 Yes targeted areas is good. Get the duct outlets with louvre ends you can close off heat to areas not being used. I have one ducting pipe that runs under the floor of the shower and loo that makes the floor nice and warm first thing. Quote Link to post Share on other sites
Black Panther 1,586 Posted February 3, 2018 Author Share Posted February 3, 2018 My boat is not much bigger than most 45 fters. It is just distributed differently. Quote Link to post Share on other sites
Bad Kitty 252 Posted February 4, 2018 Share Posted February 4, 2018 Or you can get an Eberspacher that heats glycol rather than just air, & circulates it thru little heater matrixes. Put a few of those where you want. You can even run it thru some pipe in the head & have a heated towel rail. On Bad Kitty it runs thru the hot water cylinder also, heats the water. Quote Link to post Share on other sites
Jon 360 Posted February 4, 2018 Share Posted February 4, 2018 Can’t go past 4 x 2kw heat pumps 3 reversible Works in the tropics and the not so tropic One of the up sides of an AWB production shitter 1 Quote Link to post Share on other sites
Black Panther 1,586 Posted February 4, 2018 Author Share Posted February 4, 2018 sh*t. That would work in Antarctica. I'll look up ebersp........ Quote Link to post Share on other sites
Black Panther 1,586 Posted February 4, 2018 Author Share Posted February 4, 2018 The one on trade me is looking interesting. If I could have two vents and could open and close them. Warm the main cabin most of the time and the aft cabin at bedtime. Quote Link to post Share on other sites
Myjane 40 Posted February 4, 2018 Share Posted February 4, 2018 I have a gas cabin heater old but never used if some one is after one Quote Link to post Share on other sites
