Neil 35 Posted January 31, 2018 Share Posted January 31, 2018 Over the Christmas period, I've been having a few problems with our Volvo-Penta 2003T (43hp turbo) with air in the fuel lines. It's a bit of a long story and I'd thought I'd got it fixed twice, but no. I think my question here is am I missing something? Is there some other reason for this problem? Anyway here's the timeline: May 2017 – November 2017: No issues with engine including during engine test/check during pre-purchase checks November 2017: Serviced - filters and oil changed. December 2017: Used for two weekends away no issues (including one long motor) January 6th 2018: Motored to Kawau (no wind). For 4 hours no issue but in last half an hour slight hunting on revs. Throttled back and all good into Kawau. January 7th 2018: Motor to Gt Barrier from Kawau (still no wind). Again, all good until last hour or so with same issue, slight hunting on revs. Throttled back and then all good. January 8th 2018: Motoring around FitzRoy, all good. January 9th 2018: Motored to Kawau from Gt Barrier (still no bloody wind!) all good, didn’t miss a beat. January 10th 2018: Motored out of Kawau, engine behaving erratically, hunting revs all over the place and stalling at idle. Diverted to Gulf Harbour to get sorted. Engineers diagnosed sucking air in fuel (no surprises there) due to deteriorating fuel line from primary filter to lift pump. Suspect fuel line and copper washers on banjo connectors replaced. January 13th 2018: Returned boat to Westpark from Gulf Harbour. Sailed at last! Motor out of Gulf Harbour and motor into Westpark up channel no problems – yea, she’s fixed. January 19th 2018: PCC’s R&R Friday night race. All good until returning to Westpark when same old story, hunting revs etc. Stopped and bled air from fuel line (lots of manual pumps before done). Restarted and motored up channel to marina just fine. January 21st 2018: Scratching head and wondered maybe the primary filter? So did the following: · Bled air from fuel line · Ran engine under load (pulling the marina hoping my lines were strong enough) for 10mins · Stopped and re-bled lines – about 20 pumps. · Replaced primary filter with spare and also the 5 o-rings in the assembly · Re-ran engine under load for 10 mins · Only 2 pumps required to squirt out diesel from bled screw. So maybe fixed? January 26th 2018: Headed to Mahurangi from Westpark (no bloody wind again!). For 4 hours+ ran sweet then would you believe it the same again. Just about to enter Mahurangi and hunting revs again! Bled lines of air and motored into Mahurangi just sweet. January 27th 2018: Motored from Sullivan’s Bay to Scott’s landing. Rebled lines afterwards needing about 20 pumps. January 28th 2018: Sailed Home, great breeze! Bled air from system just before motoring up channel to marina – about 10 pumps. Ok, now the questions: 1) In a normal engine, how many manual pumps of the lift pump would you expect to do before diesel squirted out of the breed screw on the secondary filter? One, two, ten, what is normal? 2) The air must be coming in somewhere between the tank and the lift pump right? 3) Why would it work just fine for hours at a time then be a problem? Seems odd to me. I guess my next option is to replace the line from the tank to the primary filter and also the shut-off valve on the tank. Once I’ve done that then the whole line from tank to primary filter to lift pump to the secondary filter will have been changed. Am I missing something? Is there any other reason air could be getting in? Any ideas? Quote Link to post Share on other sites
Dtwo 157 Posted January 31, 2018 Share Posted January 31, 2018 Maybe a little out of box thinking, but is your breather into the tank blocked? I've had that happen and it gives you some weird symptoms. 1 Quote Link to post Share on other sites
harrytom 698 Posted January 31, 2018 Share Posted January 31, 2018 If you track from injectors to pump and pump to filters/tank is there any wetness or smell of diesel? When was the pump last serviced? is tank above pump height or below? if below I would suspect pump. Quote Link to post Share on other sites
Neil 35 Posted January 31, 2018 Author Share Posted January 31, 2018 Maybe a little out of box thinking, but is your breather into the tank blocked? I've had that happen and it gives you some weird symptoms. Thanks, I'll check that out. Should be simple check to make sure that's ok (or not) Quote Link to post Share on other sites
Neil 35 Posted January 31, 2018 Author Share Posted January 31, 2018 If you track from injectors to pump and pump to filters/tank is there any wetness or smell of diesel? When was the pump last serviced? is tank above pump height or below? if below I would suspect pump. Thanks. No obvious signs of diesel (other than when a squirt it everywhere when bleeding). No idea when the pump was last serviced. Pump around about the same level as the top of the tank so diesel is definitely having to be pumped uphill. Is the lift pump itself a possible source of the air? Is there any simple way I can test the pump itself? Quote Link to post Share on other sites
Kevin McCready 83 Posted January 31, 2018 Share Posted January 31, 2018 One of the diagnostic tables in Nigel Calder, Marine Diesel Engines: Maintenance, Troubleshooting, and Repair might help. I haven't got my copy close to hand. Quote Link to post Share on other sites
jonathan 4 Posted January 31, 2018 Share Posted January 31, 2018 i would remove the secondary filter (after lift pump and put another in.... just in case seals not good, not much to those seals, any diesel on engine around injector pump? Quote Link to post Share on other sites
wheels 544 Posted January 31, 2018 Share Posted January 31, 2018 Nah we don't need no Nigel Calder. Crew is full of very capable people Dtwo has a great possible. Definitely check the breather.Yes the pump can cause the issue too. I assume the lift pump is the engine driven diaphragm type?? Two things to check here. There is a bolt in the middle of the cover. Remove that and then right behind that, there should be very fine gauze filter. This can block. Then check the diaphragm itself. You will need to unbolt the pump body to do that though. They crack/perish around the outer edge, and under the small metal plate in the middle. Very hard to see at first glance. You have to take the diaphragm out and then pull the rubber and any pin holes will open up. If it looks even slightly suspect, then replace it. The diaphragms are cheap. Moving along.....Even though most all fuel systems work by suction to pull the Fuel through the line, through the filter, from the tank, it actually is not the best way to get Fuel to the engine. Everything tends to work best when under pressure rather than vacuum. Great work on trying the Orings on the filter by the way.If there is a restriction to the fuel entering the line at the Tank for some reason, then enough suction could then suck in air through something that would normally be sealed. Some Filter Housings are designed for fuel to be pushed through them rather than sucked and some are designed for suction rather than pressure and some are OK either way. So if a blockage in the air breather, or the fuel intake at the tank connection, then enough vacuum could be created to eventually start sucking in air at some joint that would normally be just fine. And most certainly the Fuel line. Is the fuel line rubber? Check all Hose clamps are tight. The rubber hoses can shrink and then the clamp does not hold the hose tight on the fitting anymore. Another possible is the Shut off Valve at the tank. They can wear around the shaft and then under vacuum, let air seep in. I imagine that everything runs fine till such time a the Fuel gets to a certain level in the tank after the 4 hrs of running and there is then a little extra work and the fault then causes enough suck to then let the air in somewhere. While frustrating, the fuel system is fairly simple and certainly logical. So just start at the beginning and work along the line. Quote Link to post Share on other sites
John B 117 Posted January 31, 2018 Share Posted January 31, 2018 Given what you've done it makes me wonder if there might be some crap in the tank. Can you see in through an inspection hatch? That,vent as suggested above,stop cable vibrating to shut off position, and the tank pick up being where it should be and clear. Quote Link to post Share on other sites
Neil 35 Posted January 31, 2018 Author Share Posted January 31, 2018 Thanks for the replies. This group has some great knowledge out there and I've got some more avenues to investigate now I had an hour to spare this morning so went to the boat to check the breather on the tank. I managed to get the breather pipe off the tank easily enough and gave it a blow and suck. It did seem a little restricted at first but after a couple of puffs it did take air in and out pretty easily. I may have imagined it but it's possible I did dislodge something partially blocking the pipe. It would take more time and effort than I had to spare this morning to investigate further as the breather pipe run to the through-hull is incredibly awkward to get to. Just to access the inside of the hull fitting I'd have to remove the autopilot ram and the large bracket it's mounted on just to be able to get far enough inside the lazarette to reach it - but what did I expect, it's a boat. ***warning - breathing in and out through a breather tube can give you one hell of a diesel headache*** Anyway, over the weekend I'll go down and do some more investigations and tests. If I have cleared the breather I'll see if that makes a difference. I'll report next week. Quote Link to post Share on other sites
ballystick 83 Posted January 31, 2018 Share Posted January 31, 2018 Temporarily using clear hose to find air bubbles is something I've used to visually spot where the air is getting in, usually around the filter housing area on motor vehicles. Quote Link to post Share on other sites
wheels 544 Posted January 31, 2018 Share Posted January 31, 2018 ***warning - breathing in and out through a breather tube can give you one hell of a diesel headache*** It is also most important that the very first thing you do is blow, not suck And as silly as that sounds and the fact that I have seen it as a silly comedy bit in movies, I did exactly that once. Not on purpose. I just took a deep breath to blow with the hose an inch or so away from my mouth, and the hose was fill of light dirt and sucked straight down the back of my throat. Quote Link to post Share on other sites
Clipper 382 Posted January 31, 2018 Share Posted January 31, 2018 I am not going to explain how (too embarrassing), but a few weeks ago while doing boat related maintenance, i manged to suck boiling water up a tube I was working on into my mouth. Ouch. Quote Link to post Share on other sites
wheels 544 Posted February 1, 2018 Share Posted February 1, 2018 Well that is at least far better than the Fuel thief that was siphoning fuel from cars in a street one night. Came to a camper van and there was the Fuel container and hose dangling out of the pipe on the Camper and a pool of vomit on the road. He had dropped the hose down the Blackwater holding tank and sucked. 4 Quote Link to post Share on other sites
Battleship 100 Posted February 2, 2018 Share Posted February 2, 2018 That's awesome ???? Quote Link to post Share on other sites
mcp 36 Posted February 2, 2018 Share Posted February 2, 2018 Well that is at least far better than the Fuel thief that was siphoning fuel from cars in a street one night. Came to a camper van and there was the Fuel container and hose dangling out of the pipe on the Camper and a pool of vomit on the road. He had dropped the hose down the Blackwater holding tank and sucked. Haha!! That is gold! Quote Link to post Share on other sites
Neil 35 Posted April 2, 2018 Author Share Posted April 2, 2018 Update. Wheels and John B were on the money. I removed the tank and cleaned it, plenty of crap in there which must have been causing a restriction in the flow and then downstream causing the problems with air getting in the system. New inspection hatches added so I will be able to see and sort any further problems without removing the tank. I'm going to be super tuned in to any changes in the engine sound for a while but -touch wood - she hasn't missed a beat since we did this. Now for the next set of issues to sort Quote Link to post Share on other sites
wheels 544 Posted April 3, 2018 Share Posted April 3, 2018 Great job. Quote Link to post Share on other sites
