aardvarkash10 962 Posted August 18, 2020 Share Posted August 18, 2020 Are you up for a global circumnavigation without any instruments? https://www.nytimes.com/2020/08/17/sports/sailing/marvin-creamer-a-mariner-who-sailed-like-the-ancients-dies-at-104.html?action=click&module=Well&pgtype=Homepage§ion=Obituaries Quote Link to post Share on other sites
Kevin McCready 83 Posted August 18, 2020 Share Posted August 18, 2020 Great purple prose. But I smell a rat. How the hell do you estimate latitude 56°55’? Quote Link to post Share on other sites
CarpeDiem 430 Posted August 18, 2020 Share Posted August 18, 2020 38 minutes ago, Kevin McCready said: Great purple prose. But I smell a rat. How the hell do you estimate latitude 56°55’? Heh, I spotted that too.... looking at a chart, that's where the continental shelf rises from a depth of 4000m to 1000m and then goes abrupty back to 4000m and the pacific and atlantic mix. I suppose it is like crossing a reef or a tide line where you can see the colour changes in the water? Thanks for linking - a good read. Quote Link to post Share on other sites
erice 732 Posted August 18, 2020 Share Posted August 18, 2020 He completed that voyage anyway, steering by the stars. And if it was possible to navigate without instruments by night, he reasoned, perhaps it was possible to do so by day. “By the time I got back to shore two and a half weeks later, I had figured out that daytime steering was no problem at all,” he said. “We would use the wind as a reference; we would use the waves as a reference.” doesn't sound very efficient during the day, but wasn't this pretty much how they believe oceania was navigated before 1500? but with the advantage of good charts Quote Link to post Share on other sites
Black Panther 1,591 Posted August 18, 2020 Share Posted August 18, 2020 I remember when he did this. Interesting to read his account alongside David Lewis ' book. Quote Link to post Share on other sites
Jon 360 Posted August 18, 2020 Share Posted August 18, 2020 Latitude of Canopus I believe or near about, supposedly the Chinese did similar in 1421ish IIRC Quote Link to post Share on other sites
MartinRF 53 Posted August 19, 2020 Share Posted August 19, 2020 This made me remember an anecdote told to me by a fellow at usenet news rec.boats when that forum was still active. My source had worked either for the U.S. Navy or the Coast Guard in southern California back in the day when hippies were a thing. One day they came across this sail boat heading straight out into the Pacific Ocean and since they were already some distance from the coast they decided to check things out. The boat was crewed by a bunch of young, bearded men claiming they were heading for Hawaii. Sure enough they had food and water to last the trip but very little navigational aids and no radio. "How are going to find your way to Hawaii?" "Easy", said one of the crew and pointed at the con trail of a jet liner passing over head. /Martin 2 Quote Link to post Share on other sites
MuzzaB 14 Posted August 20, 2020 Share Posted August 20, 2020 Some facts: He rounded Cape Horn without hitting it. Cape Horn lies at 55 degrees 59 minutes S. He had charts. He had a sandglass. He didn't see land during the rounding. He estimated his latitude at rounding to be 56.9S, in round numbers, one degree of latitude (60NM) south of the cape. Reasonable assumption: He knew his boat and was able to estimate speed through the water - he may even have been using a traditional log line, which would have been consistent with his navigation approach. He wasn't racing, so his course would have been considerably north of the cape until it was necessary to get south and around it. You will not be aiming to make landfall at the cape but you DO want to make landfall before you approach Cape Horn. But, with prevailing westerly winds that can be dangerously strong, you do not want to get closer to the coast than you have to. There is a peak of about 1,700 feet (518m) 16 NM north of the cape. 7 NM north of the cape is a 1,000 foot peak. The cape itself is not high, and the land immediately to the north does not exceed 500 feet. So starting with Cape Horn and in ideal conditions, and assuming an eye 10 feet above the waterline, these points of land might be seen 36 miles south, 35 miles south and 30 miles south respectively. In other words from the south you would see land behind the cape before you see the cape itself. From 60 miles south of the cape you would need land of around 2,500 feet in elevation to see it in perfect conditions - and there is none. However there is plenty of land of that altitude and higher around Isla Thomas (and not far inland), 89 NM north west of Cape Horn. What does this mean? You cannot rely on seeing land from a safe distance off when rounding Cape Horn, even in the event you get ideal weather. Without accurate navigation, you need a good fix off the land north of Cape Horn before you put sea room between your boat and the cape itself. Because you cannot rely on good weather, you need a period of time - perhaps a week - in advance of rounding Cape Horn - to establish your position well north of the cape by reference to high points on the land. Now speculation: You need to round Cape Horn without GPS, sextant, compass, weather forecasts etc and you are in a small boat. You are going to want two things - plenty of sea room and a good departure fix. (You young folk may have to look that one up). You will make landfall something like 600 NM north of the cape, and the coast at that point is also considerably west of the cape. Assuming perhaps 120 miles a day or less, you will keep the coast at a safe distance and approach - weather permitting - only close enough to make observations of high land until you believe you have correctly identified that land. This is done primarily by reference to height above sea level on the chart and sufficient observations of points of high land over a couple of days to achieve a match on the chart as you sail south. You now have a fix as to latitude and, by observation of loss of a high point below the horizon (in good weather) you also have distance off (approximate - because you have to estimate the bearing). This is a fix - with errors but a fix nonetheless. You then continue to proceed down the coast - with the land in sight intermittently depending on the weather. There be mountains here - so in good visibility the high points can be seen well out to sea, where they appear as distant "islands" above the horizon. From the chart you have an expectation of which high points will be seen, and when they are seen, you use these to update your position. Again - you approach closer to the land when the weather permits but probably never closer than an estimated 30 NM. There are probably extended periods with no horizon and clouds down to almost sea level, so patience is needed and frustration is certain. You may heave-to at night if safely offshore, or sail a reciprocal track so that you can confirm a high piece of land with a second or third look. Over three days you have comfort that you have a reasonable position and track. Now you need sea room and you need to get south. You abandon any sight of land and note your final departure fix. Perhaps this uses the snow covered mountain peaks around Isla Thomas if the weather is good. Your plan is simple, by DR and steering by the waves, sun and stars you run due south if the wind allows. You log your estimated speed through the water every hour or so, and you adjust for currents (noted on the charts) and estimated leeway. Using your departure fix as your starting point and your DR track you note when you believe you are at about 56S (approximate latitude of Cape Horn) and judge that you want one degree of latitude between you and the Horn. You continue to sail, time and distance, until you believe you have run a further 60 miles south. You turn to port and attempt to maintain the same latitude until you believe you have passed the Horn. So your plan is to pass the Horn at 57S, using DR from a fix about 24 hours old. You continue to update your DR track and for whatever reason estimate some northing and note 59.9S in your log. Years later, this log entry is quoted in an obituary. I don't see purple prose or trickery here. I see logic. This is much the same as coming back from the Islands and planning a landfall at Cape Brett even if the destination is Auckland. In the days before Transit, and then GPS, we always aimed at high land in order to have the best chance of establishing a position line from the coast before we got close. Quote Link to post Share on other sites
Black Panther 1,591 Posted August 20, 2020 Share Posted August 20, 2020 In prevailing westerlies possibly picked up changes on waves well before seeing SA. Similarly waves would change again as he aligned with Drake Passage. Id like to read the book now. Must see if the library has it. Quote Link to post Share on other sites
Above-the-Fold 15 Posted August 20, 2020 Share Posted August 20, 2020 to answer the question: nowhere near as good. Quote Link to post Share on other sites
Kevin McCready 83 Posted August 20, 2020 Share Posted August 20, 2020 WOW. Muzza that was an excellent post and I thank you for it. I learned a lot. I think it should go down as one of the best ever on this crew website. Just to clear up one point. It was the purple prose of the journo I was commenting on. Quote Link to post Share on other sites
MuzzaB 14 Posted August 20, 2020 Share Posted August 20, 2020 Thanks for the kind words Kevin. BP, to your point, I recall an approach to the Cook Strait area from the Tasman in the days before Sat Nav and GPS. The weather had closed in and the wind was fresh from the south west. I had no sextant sight for 24 hours and we had not seen land. We were still north of Cape Egmont. Over the space of about 30 minutes there was a very noticeable change in the waves and the motion of the boat. One of the crew even had a little panic because he had not experienced this before and convinced himself we were about to run ashore. Our DR coincided with the rapid reduction in ocean depth as shown on the chart, but we only had a simple depth sounder on board which was useless at those depths. This was still the days of RDF and Cape Egmont broadcast a good signal. I had a B&G Homer RDF and headphones and got a good null off Cape Egmont. The position line from the RDF passed close enough to the DR position to give me comfort that we were crossing the shelf and experiencing the sea change from the rapid change in depth. This was at about the spot shown on my crudely drawn attachment. RDF signals are more subject to a polarization error at night (and it was night) so I was a tad concerned, but the ducks seemed to be in a row. Now we just look at the chart plotter - but the old tricks still work. Quote Link to post Share on other sites
Black Panther 1,591 Posted August 21, 2020 Share Posted August 21, 2020 Yep. I went through the Tuamotus at night. Passing to leeward of 5 mile long reef the waves went aft, then flattened out, then reappeared on the bow. As expected and a useful confirmation of an evening star fix. Quote Link to post Share on other sites
rossd 16 Posted August 22, 2020 Share Posted August 22, 2020 I thought Joshua Slocum achieved that a long while back in Spray. Quote Link to post Share on other sites
MuzzaB 14 Posted August 22, 2020 Share Posted August 22, 2020 Slocum used a sextant and tables. He even claimed to have used the lunar distance method to determine longitude though this may have been more of a tall story. Slocum took regular meridian passage sights but may have relied on DR more than he let on for longitude. Quote Link to post Share on other sites
