Jon 413 Posted May 19, 2021 Share Posted May 19, 2021 18 hours ago, ex Elly said: - Boats must be either a Monohull yacht bigger than 7.923m or a multihull yacht 10.0m or bigger, and must hold a current Category 3 Safety Certificate for the duration of the race. All other entry requirements as detailed in the Notice of Race must be met. We are looking into this, most likely it’s a data entry issue with the cert or possibly info supplied incorrectly Weather the boat is capable of handling the conditions that could be encountered will be the next step we will work through. Just because a boat has been entered doesn’t mean the entry has been accepted For the last RNI we required extra proof of suitability from some of the let’s say more marginal boats. We are still hoping to get a few more boats off the wait list, but probably not all unfortunately. Quote Link to post Share on other sites
B00B00 347 Posted May 19, 2021 Share Posted May 19, 2021 26ft = 7.9248m Good for heaps! 2 Quote Link to post Share on other sites
raz88 98 Posted May 19, 2021 Share Posted May 19, 2021 Legacy is in. Can't wait! 1 Quote Link to post Share on other sites
ex Elly 277 Posted May 19, 2021 Share Posted May 19, 2021 1 hour ago, Jon said: Weather the boat is capable of handling the conditions that could be encountered will be the next step we will work through. Not sure why, but SSANZ has specifically excluded monos of 26 feet or less. Possibly because they are too slow, and will hold up the others at the stopovers? A Reactor 25 successfully completed the Solo Trans Tasman race in 2010. And the very first RNI race was won by a Mummery 25, with a Raven 26 third. All of these are excluded from the Northern triangle. So they are perfectly capable of sailing to Mangonui or Tauranga. Quote Link to post Share on other sites
Steve 61 Posted May 19, 2021 Share Posted May 19, 2021 2 minutes ago, ex Elly said: Not sure why, but SSANZ has specifically excluded monos of 26 feet or less. Possibly because they are too slow, and will hold up the others at the stopovers? A Reactor successfully completed the Solo Trans Tasman race in 2010. And the very first RNI race was won by a Mummery 25, with a Raven 26 third. All of these are excluded from the Northern triangle. Yes, its a pity. I note, however, that Trish finished over a week after the 2nd to last boat into Mooloolaba. That sort of thing tends to strain the volunteers a wee bit. I also know of a Raven 26 that used to regularly cruise the Pacific. I guess times have moved on. That was back when men were men and sheep were nervous. 1 Quote Link to post Share on other sites
Jon 413 Posted May 20, 2021 Share Posted May 20, 2021 7.926 is 26 ft and it’s boats under this However we can and have taken boats smaller it was always based around Raven 26 being the smallest Doesnt mean we won’t exclude a larger boat if it’s deemed unsuitable Quote Link to post Share on other sites
Shimmer 43 Posted May 22, 2021 Author Share Posted May 22, 2021 Stoked to see Stewart 34s and Beale’s make it into the N truck angle race those boys on Open Country showed all the displacement keelers the way on the enduro race. Shaping up to have some good racing at the slow end of the fleet! recon the 3 Young 11s will have some cool racing too Quote Link to post Share on other sites
Norwegian Blue 15 Posted May 23, 2021 Share Posted May 23, 2021 Some clarification needed from the NoR please. 1.4 Yachts must produce evidence from Maritime Radio that transmissions from their VHF and AIS have been received clearly at a range of no less than 20nm from the nearest Maritime Radio Antenna. Isn't 20nm for AIS Class B transponders a bit of a stretch? Most info I can find has the nominal range for the 2W transponders at 5nm - 7nm and the new 5W transponders at 10nm - 15nm. Does that instantly rule out the 2W versions? Won't you only get 20nm in perfect conditions from a 5W transponder (and less on a short mast), or again does this mandate a transponder that supports the SAT-AIS / Message 27 which I assume provides huge range? Quote Link to post Share on other sites
Island Time 1,350 Posted May 23, 2021 Share Posted May 23, 2021 23 minutes ago, Norwegian Blue said: Some clarification needed from the NoR please. 1.4 Yachts must produce evidence from Maritime Radio that transmissions from their VHF and AIS have been received clearly at a range of no less than 20nm from the nearest Maritime Radio Antenna. Isn't 20nm for AIS Class B transponders a bit of a stretch? Most info I can find has the nominal range for the 2W transponders at 5nm - 7nm and the new 5W transponders at 10nm - 15nm. Does that instantly rule out the 2W versions? Won't you only get 20nm in perfect conditions from a 5W transponder (and less on a short mast), or again does this mandate a transponder that supports the SAT-AIS / Message 27 which I assume provides huge range? Yes, that is pretty close. Std Class B can sometimes do 20nm, but often not. An the reception is often not to Maritime NZ antennas anyway.... but the nearest shore station, many of which are private... Quote Link to post Share on other sites
Jon 413 Posted May 23, 2021 Share Posted May 23, 2021 Full details will be sent to competitors but effectively you need to do a radio check with Maritime Radio on VHF at a range of no less than 20nm from their transmitter ( Waitakere for Auckland Maritime or Great barrier for Barrier Radio ) Westhaven is only 12nm from Waitakere so Motuihe or Tiri or the likes are mid 20s. Call Maritime asked them for a radio check and also ask them if your visible on AIS including your recent track, ask them to email you a copy of this check, job done. Maritime doesn’t use the private receivers, all their data comes off their sites or via satellite so idea is it must work better than directly under a Marine Traffic site. I recently installed a new VHF in my boat at Westhaven, so I did a radio check with MR on Akl Maritime they said I was coming through 4/4 which is what I’d expect at that range, I then asked them if I could call on GB Maritime, this came through 3/4. I then had confidence that I’d be received at upto 50nm from a land based receiving station. hope this helps Quote Link to post Share on other sites
Norwegian Blue 15 Posted May 24, 2021 Share Posted May 24, 2021 12 hours ago, Jon said: Full details will be sent to competitors but effectively you need to do a radio check with Maritime Radio on VHF at a range of no less than 20nm from their transmitter ( Waitakere for Auckland Maritime or Great barrier for Barrier Radio ) Westhaven is only 12nm from Waitakere so Motuihe or Tiri or the likes are mid 20s. Call Maritime asked them for a radio check and also ask them if your visible on AIS including your recent track, ask them to email you a copy of this check, job done. Maritime doesn’t use the private receivers, all their data comes off their sites or via satellite so idea is it must work better than directly under a Marine Traffic site. I recently installed a new VHF in my boat at Westhaven, so I did a radio check with MR on Akl Maritime they said I was coming through 4/4 which is what I’d expect at that range, I then asked them if I could call on GB Maritime, this came through 3/4. I then had confidence that I’d be received at upto 50nm from a land based receiving station. hope this helps Thanks Jon, that makes sense. Quote Link to post Share on other sites
Island Time 1,350 Posted May 24, 2021 Share Posted May 24, 2021 Just so its clear, class B AIS was never intended to provide satellite tracking. Its not 100% reliable, and can drop in and out. Class B is only 2watts. To get real satellite tracking you need a 5w unit, the SOTDMA ones, or class A. Virtually no yachts have these - yet. But if the antenna is mounted on a spreader, or a decent splitter is used, a standard Class B will (usually) do 20 miles if the antenna is properly installed, in good order, mounted high, and there is a direct line of sight to the receiver station. Quote Link to post Share on other sites
Boatworks 25 Posted May 27, 2021 Share Posted May 27, 2021 A few more on the wait list... Lanny Walker Radioactive chris dent Simply the best Mike Paauwe Penury Treguier David Poulpito Quote Link to post Share on other sites
waikiore 523 Posted May 27, 2021 Share Posted May 27, 2021 That Shimmer fella is probably hoping for weather like the Three Kings race a few years ago -when the old kauri Towngirl came through and wupped them on handicap! Quote Link to post Share on other sites
Jon 413 Posted May 27, 2021 Share Posted May 27, 2021 First foreign boat on list also Quote Link to post Share on other sites
raz88 98 Posted May 27, 2021 Share Posted May 27, 2021 3 hours ago, waikiore said: That Shimmer fella is probably hoping for weather like the Three Kings race a few years ago -when the old kauri Towngirl came through and wupped them on handicap! I was on that townson. Was a long slow race but we worked pretty hard. It suited us in the end. Iirc the race started Thursday, and prize giving was scheduled for the Sunday night. But at the appointed time I think only Vodafone was finished - the rest of us were still out there. Quote Link to post Share on other sites
RushMan 31 Posted May 27, 2021 Share Posted May 27, 2021 37 minutes ago, raz88 said: I was on that townson. Was a long slow race but we worked pretty hard. It suited us in the end. Iirc the race started Thursday, and prize giving was scheduled for the Sunday night. But at the appointed time I think only Vodafone was finished - the rest of us were still out there. We held discussions on board OF about when the iron headsail was to be deployed so crew could make it to work in the morning (Monday morning). “We retire at 1am”... luckily the wind arrived at midnight, the kite went up and we sailed on, claimed monohull line honours and had rum for breakfast. Quote Link to post Share on other sites
raz88 98 Posted May 27, 2021 Share Posted May 27, 2021 10 hours ago, RushMan said: We held discussions on board OF about when the iron headsail was to be deployed so crew could make it to work in the morning (Monday morning). “We retire at 1am”... luckily the wind arrived at midnight, the kite went up and we sailed on, claimed monohull line honours and had rum for breakfast. I phoned the boss on Monday morning at 8am as we were still off whangarei to say I wouldn't be coming in that day. Quote Link to post Share on other sites
Steve 61 Posted May 27, 2021 Share Posted May 27, 2021 Was that before or after breakfast? Quote Link to post Share on other sites
waikiore 523 Posted May 31, 2021 Share Posted May 31, 2021 Maybe there will be another Three Kings Race ........ Quote Link to post Share on other sites
